Question about CyberLink SW- DVD Software Power DVD (SWPOWERDVD) DVD Drive
Will not burn to disc - CyberLink SW- DVD Software Power DVD (SWPOWERDVD) DVD Drive
  • 3 Answers
I had the same problem. your disc is the wrong format, or your burner is not working correctly. i hope this helped
Posted on Jun 14, 2010
After running a CD burn, PC treats it as a blank disc
Try putting the burned disc into another computer to see if it reads it. If not then it could be an issue with the disc burner itself. The laser could be going bad and that would cause the burner not to burn discs properly.
Dec 24, 2011 | E-Machines eMachines Desktop PC
My MW2 got laser burn PLEASE HELP
Laser burn is particularly nasty so common household disc cleaners won't do the job. GAME stores usually have an industrial strength disk cleaner which only costs £3 to repair discs. There is no guarantee any amount of disc repair will work, as laser burn can be fatal on discs, but this is your best bet. To avoid laser burn, lay your console flat (not standing up) and make sure its on a level and sturdy surface. Any vibration through the console can cause the laser to over-focus, and then you'll get burn.
Feb 20, 2010 | Microsoft Xbox 360 Console
How do you burn a cd on this notebook?
  1. Insert a writeable CD or DVD into your computer's CD or DVD recorder.
  2. In the dialog box that appears, click Burn files to data disc.
  3. In the Burn a Disc dialog box, type a name for this disc, and then click Next.
    It might take several minutes for the disc to be formatted in the default Live File System format. When the formatting is complete, an empty disc folder opens.
  4. Open the folder that contains the files you want to burn, and then drag the files into the empty disc folder.
    cdb4d559-8825-47a1-8175-79020965d91c.pngYou can copy files to the disc folder by dragging them to the disc icon or to an open disc folder As you drag files into the disc folder, they are copied automatically to the disc.
But I recommend you to use any CD or DVD burning software like Nero, BurnAware etc. There are lots of free burning tools available on Internet too.
Why I recommend third party software is because you can select burn speed plus minimum disc burning error.
Feb 02, 2010 | Toshiba Qosmio F45-AV412 Notebook
Laser burns on disc
Laser burn, looks like complete or partial circular scratches around your disc, also known as “the ring of death”. This occurs to discs when the games console has been moved whilst playing, from an upright to a horizontal position or vice versa or simply knocked against or the wires may have been just tripped upon. Discs are then impaired by a ring of laser burn, which is a circular scratch into the disc. Some home remedies may help with very light scratches on some discs but professional disc repair services is normally rerquired to restore disc laser burn damage back to "As Good As New Condition".
For further help on Xbox & Xbox 360 laser burn disc repairs or to get discs professionally repaired, visit:
www.discREPAIR.ie
You can send your discs off to this Disc Repair Service and the discs shall be sent back as good as new.
Dec 25, 2009 | Microsoft Xbox 360 Console
Cant make a back up of my dvd's for the kids to use. with shrink and decripter. when i do now it says, when i play it, it says no menu.
Step 1
Be sure to erase all data on the disc, if media is rewriteable, by going up to the "Recorder" drop-down menu and clicking "Erase Rewriteable Disc." A box will pop up on which you need to choose the correct recorder from the top menu, quick or full erase (best option), and a maximum erase speed is fine.
Step 2
Choose your recorder drive on the top right drop-down menu on the main screen. The drive icon next to this menu allows you to set advanced options. (Not needed here.)
Step 3
Click on the "Burn" icon in the middle of the main toolbar. This opens up the "Burn Compilation" box.
Step 4
Click on the "Multi-session" tab on the "Burn Compilation" box. Choose "Start Multi-session disc", if the disc is to be added to later. Choose "No Multi-session disc," if the disc is to be completed with the current burn. The other options are good at the default settings.
Step 5
Click on the "Label" tab on the "Burn Compilation" box to give the disc a title that will be seen in the drives list, such as Windows Explorer, when the disc is loaded. Choose "Automatic Disc name" and enter the desired name without spaces. For spaces, add underscores (shift+hyphen).
Step 6
Click on the "Burn" tab on the "Burn Compilation" box to set desired burn and writing actions. "Determine maximum speed" lets Nero determine the recorder and disc speeds, if they are unknown. "Simulation" performs a test virtual test burn to see if all goes well. "Write," of course, burns the disc. "Finalize disc" means that the disc will be burned, so that no more can be burned on it. (For the example, check the boxes for "Write" and "Finalize disc," which is probably already checked.)
Step 7
Set "Writing speed," if known, "Writing method" as "Disc-at-once" and "Number of copies".
Step 8
Click the "Burn" button at the bottom on the "Burn Compilation" box to begin the actual burning process and the "Writing to disc" window will open.
Step 9
Check the "Verify written data" box on the bottom left of the "Writing to disc" window. This will have Nero read the disc, after it is done burning, to verify that all of the data has been properly burned to the disc. This is an important optional step, especially with really important data. If all goes well, a box will pop up stating that "Data verification completed successfully."
Step 10
Run the disc in a drive or DVD player to make sure it runs correctly. If it does, the original files on the hard drive may be deleted, if desired.
Dec 11, 2009 | Computers & Internet
Dvd drive will not read burned discs
The laser is weak and its not burning discs properly to begin with. Get a new drive put in there and that will take care of the problem cause a new drive will have a new laser in it.
Aug 22, 2009 | Gateway Computers & Internet
Laser burns
For further help on Xbox & other laser burn disc repairs or to get discs professionally repaired, visit:
www.discREPAIR.ie
Jun 05, 2009 | Microsoft Xbox 360 Console
Burned DVD video couldn't play
are the videos you are rying to burn store bought
Mar 25, 2009 | Ricoh MP5240A (RICOHMP5240A) DVD+RW Burner
Repeat burn process lengthy
I discovered after some research that this issue can be resolved by hitting the format button. It burns the disc without going through all the other processes.
Sep 25, 2008 | Apple DVD Studio Pro 4 for Mac
DVD+RW problem
When burning CD/DVD use a lower burning method... as not to rush data to burn and make sure that before burning the let it verify or test the data burned on the CD/DVD... it takes time, but be patient, after all it is your data.
Dec 10, 2007 | LaCie d2 DVD-RW Burner
Computers & Internet Logo
Top CyberLink Computers & Internet Experts
Sunil Pratap Singh
Sunil Pratap Singh
Are you a CyberLink Computer and Internet Expert? Answer questions, earn points and help others
