Question about Roper RAS8445KQ Top Load Washer
Agitator's range of motion is extremely short
Spinning works fine, only the agitator is having a problem
  • Roper Master
  • 8,220 Answers
Old style
New style
Posted on May 03, 2010
Kenmore 80 Series 110.27802690 agitator barely moving
It's the transmission that's bad. The motor turns one direction to spin and the opposite direction to agitate. The transmission converts the constant belt speed from the motor into the back and forth motion. In the other direction, the transmission stops and the whole system spins.
(I don't suspect you have it set to "delicates")
Jul 20, 2016 | Kenmore Washing Machines
What needs to be replaced? I installed a new motor but my washer still won agitate or spin.
check / replace the start run capacitor for the motor
have a electrician do it or a service technician if you do not recognize it
it is normally up near the control panel
Oct 19, 2015 | Haier HLP21N Washer
I own a Whirpool Washer machine model LSC6244AW0. I noticed that when the machine is on, the washer agitator spins while the Agitator Auger does not spin. It usually sits in place and sometimes, when
jason,it sounds like your agitator dogs are worn out.you can try just the dogs,part#80040 for about 3 bucks or do the cam kit part#285811 for about20.appliance parts pros.com has a video to help you find the right part for you.hope this helps.
Nov 20, 2014 | Washing Machines
My washing machine is only 6 or 7 mths old everything still working fine it just isnt spinning its still pumping water out though!
Chances are extremely good that you just have a broken coupler. These parts range from $15 - $25 on average. Were there any signs of foul play before this problem? Does your washer agitate(plastic fin in the middle rotate back and forth and wash the clothes)? Basically, if the coupler is broken, the machine with neither agitate or spin. However, you do not need a coupler to pump water out :)
I would definitely have it repaired. You should spend a little on the part + labor. Those are excellent washers and they do not make them anymore!
May 16, 2010 | Washing Machines
Agitates but wont spin
You will probably find this useful, particularly sections 2 and 7.
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/ec2a315861edab6e8525729c005736f0/$FILE/Maytag_Atlantis_III.pdf
Note how one motor is used to produce the agitation when it rotates in one direction and the spin when it rotates in the other. The manual describes how the motor spin is transferred through the transmission and other elements. You need to consider each step from whether the motor is spinning to whether the tub is turning and see where the motion is being lost. The motor itself is probably just fine since it produces agitation. Something is probably either jammed (if the motor isn't turning) or disconnected (if it is) when it should be spinning.
Oct 30, 2009 | Maytag Atlantis MAV6000 Top Load Washer
Amana washer not agitating, moter spinns fine
Well at least you know your motor works. your motor is connected to the tub and transmission with a coupler actually I believe its two of them one is probably broke
Sep 03, 2009 | Washing Machines
Kenmors 110 keep spining
The tranny should either spin or agitate not both
Nov 02, 2008 | Kenmore 24032\24036 Top Load Washer
Kenmore Mod 110 keep spinning
the holes are sapose to be there it filters the lint out.it sounds like you have a bad transmission.
Kenmore 90 Series
The agitator has four small teflon (I believe) plastic grips inside the upper portion called "agitator dogs". They have small teeth on them to grip the inside ring of the agitator. You can replace them for less than $10 for a pack of 4. Your local appliance repair shop should carry them, or be able to order them for you. Let me know if this helps.
Jun 26, 2007 | Kenmore 22422 Top Load Washer
Grinding niose from agitator.
If the fill and drain functions correctly, AND the spin cycle works correctly, AND the cycle itself starts and completes correctly, the problem being that the back and forth motion of the agitator starts the loud grinding noise, it will likley be broken gears in the transmission. The single most expensive part in the washing machine.
Feb 04, 2007 | Maytag Atlantis MAV6451 Top Load Washer
Roper RAS8445KQ Top Load Washer Logo
67 people viewed this question
Top Roper Washing Machines Experts
Dan Webster
Dan Webster
Mike
Are you a Roper Washing Machine Expert? Answer questions, earn points and help others
