Question about Whirlpool DU1055XTS Built-in Dishwasher
I have a Whirlpool DU1055XT. The unit will not work
I have a Whirlpool DU1055XT. The clean light is flashing. The manual says the dishwasher has malfunctioned. Check the heater circuit. Is the heater circuit inside the cabinet or elsewhere? How hard is this to repair?
    President:
  • 949 Answers
The flashing light indicates the water is not heating, there could be several reasons for this, I have created instructions on how to reset the dishwasher so you can use it and why it may have occurred. If you follow these and still have trouble let me know and we can dig into it deeper.
http://www.fixya.com/support/r4628906-flashing_or_blinking_green_clean_light_7
Posted on May 03, 2010
Whirlpool adp 6515ix dishwasher start button is flashing in 4 time cycles-what does this tell me please. None of the manuals indicate what the flashing could be signalling.
Error CodeConditionCheck/RepairShop PartsClean light blinks 7 timesHeater circuit failure. Control didn't detect the expected rise in water temperature.Check the heating element and related components (wiring and control board) in that circuit.
Heating element, Electronic control board, Thermistor, Circuit wiring
Console light blinks rapidlyThe control detects a stuck button on the control panel.A failed control panel or a malfunctioning electronic control board can cause this code. Check the buttons on the control panel using a volt/ohm meter. In most cases, the control panel must be replaced. If that doesn't solve the problem, the electronic control board might be at fault.
Control panel, Electronic control board
Start/Resume light blinks slowlyIf the dishwasher door is opened or power is interrupted during the cycle, the dishwasher won't start again until the door is detected as closed and the Start/Resume button is pressed.Check the door latch and switch assembly. A failure in the Start/Resume button also can cause this problem.
Door switch assembly, Control panel, Electronic control board
Clean light stays onThe dishwasher won't start a new cycle unless it detects that the door opened after the previous cycle.Turn off power to the dishwasher by shutting off the breaker and restarting. If that does not work, the door switch assembly is stuck and must be replaced.
Control lock LED is on but not accepting key pressesAccidentally turned on or control detected keypad problem.Press the Heated Dry key for 5 seconds to turn off control lock feature. If that doesn't work, replace keypad.
Keypad
Sanitized LED blinks at end of cycleControl couldn't confirm that the dishes were sanitized.Check voltage to the dishwasher and the temperature of incoming water. Check the diverter motor, the heater and the OWI/thermistor.
Diverter motor, Heater, Thermistor
May 23, 2015 | Whirlpool Dishwashers
Whirlpool GU1200 XT Dishwasher Will not
Press the [Menu] Soft key in standby mode and press
[*] key within 3 seconds to lock the keypad. Keypad lock
remains unlock if [*] is press after 3 seconds.
May 30, 2008 | Whirlpool Dishwashers
Dishwasher will not sustain a start up, purchased in 2010 and seldom used
It is very likely the door springs are too tight and causes the door latch to come off. Maybe the dishwasher needs to be levelled properly or adjustment done to springs.
Check pages 16 and 17 in this installation manual.
http://www.whirlpool.com/digitalassets/MLPDF/Installation%20Instructions%20-%20W10401503.pdf
Apr 02, 2014 | Whirlpool DU1055XT 24 in Builtin...
can you hear if the water is coming into the washer? if not then your problem may be the water inlet valve. it is located where the water line connects to the unit.
I have a whirlpool adp6600 dishwasher. the green light just keeps flashing (i think it's 7 times in a row each sequence) and the cycle won't start. have tried turning it off at the wall, clean
Dishwasher is in fault mode hold start/pause button for a few seconds this will reset the unit run your cycle again if dishwasher faults again call you local service man.good luck
Aug 02, 2012 | Whirlpool Dishwashers
The Clean light is flashing and unit will not start. Manual says it is a heating circuit malfunction call a repairman. Heating element tests good, wiring appears fine. What is needed?
Hi, the reason why you are getting the flashing light is because the dishwasher failed to detect a 4 degrees rise in the water temp during the first 8 minutes of the cycle. Some reasons for this is a faulty heater, door switch,(heater runs through the nuetral side of the door switch), lack of water, d/w not filling correctly, should be just below heating element. Clear the fault by pressing following order. .
The dishwasher will go through a cancel cycle (drain the tub) and will then let you start it up again.
Jun 13, 2011 | Whirlpool GU2400XTP Built-in Dishwasher
The clean light is flashing on a whirlpool dishwasher-model du1048. The manuel says the dishwasher has malfunctioned and to check the heater circuit. How do I do that?
Hello & Welcome to FixYa
Flashing clean light is reset by pressing two buttons in sequence 3-4 times, to reset your kenmore press these buttons in sequence:
High temp wash-heated dry-high temp wash-heated dry
Please get back to me if you have any other questions.
Kevin
Feb 17, 2011 | Whirlpool 24 in. DU1055XTP Built-in...
The clean light is blinking and it wont turn on
There is a malfunction and it is recommended to call for repair, tell them what is happening the manual suggests to call for service to check heater circuit. I am sorry if this is not much help.
Jan 02, 2011 | Whirlpool 24 in. GU3200XTP Built-in...
I have a quite partner 2 and it is stuck on the clean cycle and the light is blinking on and off. It will not work when I push any other buttons.
whirlpool dishwashers sense the water temperature in them the clean light flashing 7 times means either the heater element is not working or the water temperature going into the unit is to cold, start the water at the sink before starting the dishwasher now to get rid of the flashing light press the hi temp wash button and then the sani rinse button press one then the other over and over until all the lights come on it will then go in to a test mode when it completes the flashing light will go out that will solve your problem
Apr 03, 2010 | Whirlpool Dishwashers
Whirlpool DU1055XTS Built-in Dishwasher Logo
586 people viewed this question
Top Whirlpool Dishwashers Experts
Oloyede Monsuru
Mike
Are you a Whirlpool Dishwasher Expert? Answer questions, earn points and help others
