I need to change the aspect ratio on my polaroid TV
I need to change the aspect ratio on my polaroid 42'' hdtv. I bought the TV 3 years ago. When I bought the TV, I worked for a satellite TV provider. So I just hooked my receiver into the TV. I now use my off air antennae for TV. (lost my job) But the aspect ratio is incorrect. The picture is too big for the screen The remote that came with my television has an aspect ratio adjustment button. But the remote is defective. Apparently the geniuses at Polaroid decided that the remote would be the only option for changing the aspect ratio. Using the menu button located on the side of the TV, I can not locate the aspect ratio adjustment. I once heard someone say that ''you get what you pay for''. And this was the cheapest 42'' TV available 3 years ago. If anyone has any ideas, other than buying a new TV, please let me know. Thanks
5 Suggested Answers
taran_2005
  • 10515 Answers
SOURCE: Wrong aspect ratio LCD tv: Model Polaroid FLU-1911S
Hey,
Folowing is the link for the service manual for FLU 1911 s :-
http://www.retrevo.com/s/Polaroid-FLU-1911S-TVs-review-manual/id/2894bh033/t/1-2/
I hope it wld help u :)
Posted on Nov 25, 2008
ward_knutson
  • 64 Answers
You cant change the aspect ratio. Polaroid built this unit with a non-standard format. Here is what I found:
Don't be thrown off by other wide-screen aspect ratios. When shopping for wide-screen displays--especially flat-panel LCDs--you may see aspect ratios such as 15:9 or 16:10. They are, for all intents and purposes, close enough to 16:9 to be considered synonymous. Unless you're extremely sensitive to geometry, it's doubtful you'll notice the slight stretching or squashing they introduce.
Sorry!
ripleymojica
  • 643 Answers
SOURCE: Polaroid TV with
tuner is bad. they dont make spare parts for that tv.
Posted on Jul 06, 2009
gopakumarg43
  • 74136 Answers
SOURCE: how to change aspect ratio on lg rz-32lz55?
Try this link to download the user manual to your TV. It has all details about the adjustments.
Posted on Dec 18, 2012
Aspect ratio selection
On your remote control there is a button that controls the aspect ratio on you television. Push the button to change the aspect until you get to the desired ratio.
May 21, 2014 | Polaroid 22" Class 1080p 60hz LED LCD HDTV...
A simple question - My new 42" LG tv is fine -
You should be able to change the aspect ratio to fit the size of your screen. This will be the 16:9 4:3 16:10 settings.
You can access these by going to MENU---> PICTURE -----> Select ratio that works----> exit out and watch TV.
IF this will not fix it you need to look into the signals being fed to the TV as sometimes they can have a funny effect on the output picture. Some cable boxes will alter the picture and then it won't come out right on the TV. If it is all inputs doing this tho then changing just the Aspect ratio on the TV should solve the problem.
Jun 07, 2011 | LG 32LG30 32 in. LCD HDTV
How do I get the screen bigger as in not having the black stripson the side?
change the aspect ratio from 4:3 to 16:9 you can do this by going to the menu then picture then size or aspect ratio.
May 22, 2011 | LG 42LC2D 42 in. LCD HDTV
Letterboxes on my LG 42" LCD HDTV...
Have you tried the Aspect Ratio button on the remote control, this will change the oicture size through 4:3/16:9/ etc.
Mar 22, 2010 | LG 42LC2D 42 in. LCD HDTV
LG 47'' LCD HDTV 120Hz - Incorrect Picture Width
I just had this problem and got it solved. The issue is that your cable box is likely set to the wrong aspect ratio, so your tv will not be able to display the picture properly without this setting changed. On my cable box(Pace), you need to turn the power off to the cable box using the remote. Then hit the menu button on the remote and a new menu will appear on the screen. Change the aspect ratio to 16:9 and you should be all set. Hope this works for you too.
Feb 22, 2010 | LG 47LC7DF 47 in. LCD HDTV
EEP RESET changed my picture to wide screen.
Go into Menu and look for Video section and find wide,panorama,16x9 and 4x3. gottas be there. then click on normal thnen click on what you want..
Please rate!!
Mar 16, 2009 | Polaroid TTM-2004 20" TV
Akai LCT3201AD 32 in. LCD picture stretched around the corners
This set has several differant aspect ratios, could you have unwittingly change it to a zoom or expand by mistake?
Feb 07, 2008 | Akai LCT3201TD 32 in. LCD Television
Heads cut off and no score...
Try your setting on your cable box (Screen position)
also maybe wide mode try switching to wide zoom good luck
Dec 10, 2007 | LG 42LC2D 42 in. LCD HDTV
Aspect ratio
Problem is solved. I unplugged my DVR from my receiver for about a minute, reconnected it, and the that solved the problem.
Dec 08, 2007 | Audio Players & Recorders
Televison & Video Logo
852 people viewed this question
Top Televison & Video Experts
Electro Med Services...
