Question about LG WM1814CW Front Load Washer
WM0642HW model of LG front load washer giving digital messge LE; have read online that others unplugged machine & 15 mins later it was fine. Not working, tried turning the drum, taking clothes out....still get message. PLEASE HELP machine in only 5 or 5 years old.
  • dj88fansmd May 03, 2010
    being that it's Sunday, can't get the part now at 8:30 p.m. but have printed out instructions and will do tomorrow after work. Thanks
  • 8,197 Answers
Solve LE error by replacing Hall Sensor. Buy part #5016501KW2002A at Sears parts store.
Iinstructions on how to replace:
1 Open rear panel. Take 17mm nut off (it's the only one)
2 Pull off what looks like a goofy hubcap (it's held by magnets)
3 Unscrew the six 10mm bolts and gently lower the coils
4 Remove and replace the Hall Sensor (plastic comb looking thing)5 Plug inWM0642HW model of LG front - 2_bing.gif the sensor and re-install the coils and cover.
30 minutes for me.
Test spin cycle if desired by following chart on page 19 of service manual at http://www.appliancefactoryparts.com/content/pdfs/125448.pdf
(note lower models skip step 10 (heater test).
Hall Sensor Part labelled as K351 in diagram on page 41 of service manual.
Posted on May 03, 2010
LE error on washer. What can I do without a tech?
The *dreaded* "LE" error is overwhelmingly caused or triggered by incorrect type detergent **OR** too much *HE* detergent (a special low sudsing detergent).
In all LG washers-when too much detergent has been used-this will cause the "LE" error to be displayed & the wash cycle will be interrupted. Unplugging the washer for more than one minute will cause the MAIN BOARD (computer) to power down and re-boot when the washer has been plugged back in.
On LG washers built *before* 2008-after several "LE" error events-the error *cannot* be reset by unplugging the washer. This indicates that the HALL EFFECT SENSOR has failed and will need to be replaced.
On all LG washers built during and after 2008-a more robust resistor was used in the HALL EFFECT SENSORS-which eliminated damage caused by higher electrical loads placed upon the sensors due to oversudsing. HALL EFFECT SENSORS virtually never fail in 2008 and newer LG washers but the "LE" error will still occur if too much or the wrong type of detergent is used. This will be "resettable" by unplugging/replugging the washer.
The CORRECT amount of HE (High Efficiency) detergent to be used is as follows:
HE : (2) Tablespoons Per Wash Load
HE 2X : (1) Tablespoon
HE 3X : (1) Teaspoon
USE THESE AMOUNTS RELIGIOUSLY-NO EXCEPTIONS-IN ALL FRONT LOAD WASHERS WITH 3.0 cu ft DRUMS AND LARGER
Read more: The Dreaded LE Error Code in LG Washing Machines: Diagnosis / Troubleshooting, Root Causes, and Repair ' Washer Repair ' Fixitnow.com Samurai Appliance Repair Man http://fixitnow.com/wp/2010/08/03/the-dreaded-le-error-code-in-lg-washing-machines-diagnosis-troubleshooting-root-causes-and-repair/#ixzz2nlabX1Gv
Follow us: fixitnowsamurai on Facebook
Dec 17, 2013 | LG WM2233H Front Load Stacked Washer /...
Hi i have a LG washer and dryer combo, and it gives me and LE error, i have tried to fix it by reading articales online like to trne the power off and wait 5 min then turen it back on but nothing works....
Hello & Welcome to FixYa
LE error in your LG front load washer is displayed when either the motor is not working or the control board thinks that the motor is locked up. A Hall effect sensor is used in these washer which monitors the speed and direction of the motor and then forwards this information to the control board. Hope you understand by now that this LE error is displayed when their is an issue with the motor or when the hall effect sensor sends wrong signal to the control. Conclusion is you'll have to check both motor and hall sesor and replace the part# that is bad, usually I have seen the sensor going bad. Please get back to me if you have any other questions.
Kevin
Mar 08, 2011 | LG WM-2277HW Front Load Washer
I have an LG Tromm washer. I start it up it start
LE code stands for locked motor error. When this error code appears in your front load washer it indicates a fault in the motor unit.
1 . Check the connections to the Coil/Stator at the rear of the unit possibly it should be something like a broken wire.
2 . Coil/Stator Assembly will be defective preventing the drive to operate.You should go for a replacement of that assembly.
Thank you !!
Jul 25, 2010 | LG WM0642H Front Load
"UE" error code LG washer wm0642hw
This is an Imbalance code. Your issue may be with:
  • The load is too small
  • The appliance is tilted
  • Laundry is gathered to one side
  • Non-distributed things are put into the drum
Try adjusting the load size, and make sure the unit is level.
Aug 07, 2009 | LG WM1814CW Front Load Washer
LE light is on and washer wont run. Model LG wm0642hw
I would suggest unplugging for 12 hours. If you plug it back in and it works again then order a new main control module. If it still doesn't work after unplugging for 12 hours then you probably will need a new hall effect sensor. check out pa rtstore . com for parts. Good luck!
Jun 15, 2009 | LG WM-2277HW Front Load Washer
LG Tromm washer WM2077CW reading code LE
LE means "Overload in Motor" Unplug the washer, remove clothes, wait 15 minutes for motor to cool down. try again. If problem persists you'll need a certified technician.
May 31, 2009 | LG WM-2077C Front Load Washer
LE error code on LG WM0642 FL washer
LE is a locked motor error code.
It is usually associated with a loose motor connector wire or a defective Hall Sensor.
Mar 08, 2009 | LG WM-2277HW Front Load Washer
LG WM0642HW washer gives error during spin cycle and stops.
I have this problem and you can find the solution on this same web page by searching. It is likely the Hall Sensor that needs to be replaced (see proflevy posting on Jul 16, 2008). According to the postings, it is from soap build up on the sensor and replacing it costs $18 for the part and is easy (many responses on this). I am waiting for the part and will try to fix mine soon.
Mar 06, 2009 | LG WM-2277HW Front Load Washer
LG Washer LE Error
Yes this is the same Hall sensor as in the WM 2277
You can Order them HERE and have them within a few days.
Easy fix
Jun 14, 2008 | LG WM-2277HW Front Load Washer
Error message when trying to wash
Unplug the machine and spun the drum few times by hand, wait 10-15 min. and plug it back. Good luck!
Aug 06, 2007 | LG WM-2077C Front Load Washer
LG WM1814CW Front Load Washer Logo
283 people viewed this question
Top LG Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
