Question about Philips Televison & Video
No display there is sound there a voltage from flyback also the G2
    Problem Solver:
  • 18 Answers
Your problem is in the video section of the motherboard. With the eraser end of a pencil touch the components, one at a time, in the video section by slightly wiggling the eraser and checking for a picture to come up on the screen. If needed, you can place a large mirror in front of tv to see picture while you are behind the television. If the picture comes up then the component you are wiggling has a loose solder joint and just needs to be resoldered. Hope this helps
Posted on May 03, 2010
How do i fix my crt sharp 21G2-s tv whose screen is total black when switched on?
Check and replace damaged component/s at its horizontal scan output section circuit. Check the LOT (Line Output Transformer) too for damage. Replace the horizontal scan output transistor. Check the input voltage to LOT. If the voltage is absent check the feeder resistor; if any. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts.
Type in the brand name of your device, in the search box [at the top right] of the display window and the Search will start at once as you type in, and will show you all the related posts. It will make surf easy.
Feb 18, 2015 | Sharp 21" Multi System Stereo TV
Tip
How to test Flyback Transformer Without taking it off the Boarda) Basically it...
a) Basically it has to be acted upon by a supply voltage of at least 95V
to work.
sample picture:
b) Of course, assuming the horizontal deflection oscillator works, same
with the horizontal drive and horizontal output transistor
sample of H out transistor
It would generate output voltages on the secondary terminals
and 200V line will be active sending voltages to the
Video Drive circuits. Of course high voltage will be generated
ranging to at least 30 KV and there will be voltages on the G2 of the CRT.
c) The easiest test point to look when it is oscillating, is the CRT heater
voltage, the heater lit when flyback is good ( mostly at night times when it
is dark ) and you can hear sounds, too ( if speaker is connected).
• Heater : marked with letter H and H1
• Green Arrow for the G2 voltage
d) Having a B+ voltage reading of 75 V or lesser ( primary pins )
indicates a bad or partially shorted flyback, assuming your
horizontal output transistor and power supply are good & OK.
• These only applies to CRT type TV's.
on Jul 31, 2012 | Philips Televison & Video
Tip
A) basically it has to be acted upon by a supply voltage of at least 95V to...
a) basically it has to be acted upon by a supply voltage of at least 95V
to work.
sample picture
b) of course, assuming the horizontal deflection oscillator works, same
it would generate output voltages on the secondary terminals
ranging to at least 30 KV and there will be voltages on the G2 of the tube.
c) the easiest test point to look when it is oscillating, is the CRT heater
is dark ) and you can hear sounds, too.
here is a sample image
d) having a B+ voltage reading of 75 V or lesser ( primary pins )
sample of H out
on Dec 24, 2009 | Music
Black screen, sound ok.flyback lines when G2 turned up
Never tune G2 voltage too up to a state, to appear retrace lines on screen. it is bad. It might make the CRT damaged. Check the video output card, and the voltages comes to it. This card can be located at the neck of the picture tube itself, will directly plugged to its back of the neck. Reduce the G2 voltage, in such a way that, there is no retrace lines appear. Be careful. To get some details, http://electronicshelponline.blogspot.com/ Pull up older posts
Dec 12, 2013 | Televison & Video
Sony KP-57WV700
Hi. It seems that the g2 voltage of the picture tube is too high, resulting in a white screen, often with white horizontal lines. The g2 (= second grid) voltage is derived from the flyback high voltage. The voltage divider is mostly integrated in the flyback trafo housing.(including the adjustment knobs). A failure in this divider may lead to this defect. The static you hear may come from sparking in the divider. The flyback trafo is soldered onto the main printed cirrcuit board. Sometimes, one of the pins sits loose in the soldering pads.
Turn on the set and observe for any sparking around the entire flyback circuitry, and, or the flyback trafo itself
The screen turns black after a while, as a too high beamcurrent is detected. The set disables the flyback. Stand-by blinks meaning that there is a fault condition.
Be carefull with the high voltages. The flyback voltage is very high (20-30 Kilovolts !) and may be lethal !!
Jul 02, 2012 | Sony KP-57WV600 57" Rear Projection...
My tv wont turn on the light on the power button blinks and the lamp turns on in the back but the screen dont light up
check if crt screen voltage correct (g2) try to adjust screen settings at flyback transformer and monitor if g2 response, some model if vertical ckt down monitor have black signal only can determine if screen adjustment knob in flyback transformer turn increase. vertical line appear.
Mar 26, 2010 | Samsung HLR5667W 56" Rear Projection HDTV
TV SCREEN FLICKER
If this is a tube tv. It could be have something to do with the G2 voltage, could be the g2 filter capacitor.Or the screen and focus adjustment on flyback is giving up. But check for dirt built up. If focus and screen is faulty best is to replace the entire flyback.
If your not inclined in electronics better to have it check by the expert. High voltage inside.
May 22, 2009 | Memorex Televison & Video
I paid 9.95 for assistance and did not get a responce but charged
From your description it sounds like G2 voltage on the green picture tube is too high.
Are you confident about adjusting it yourself? There are high voltages in places which can kill. I will not take any responsibility of you getting an electric shock so I suggest calling in a qualified TV technician.
Any TV technician should be able adjust this voltage and it should not take long to do it unless the cases are hard to remove and hard to access the flyback transformer where the G2 (screen) adjustment is located.
Otherwise it may be a faulty green picture tube and this is expensive as you need to get the tube replaced.
Hope this helps
Nov 21, 2008 | Televison & Video
Trintron tv
Dear Lammy,
Turn the G2 control up, or clockwise just a hair, and see if the piture returns. The G2 or screen control is one of two controls located on the flyback, or high voltage transformer.
Please let us here from you!
Toprol
Nov 08, 2007 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Televison & Video Logo
29 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
