Question about Husqvarna "Chain Saw - 16" Bar, 3 Hp
Can't figure out how to get to the fuel filter
    President:
  • 2,220 Answers
Insert a hooked blunted wire through the filler hole. You should be able to gently draw the filter and hose through the opening.
If you have more questions or need additional help please reply below and I will get back to you. HTH & Good Luck.
Lou
Thank You for using FixYa.
Posted on May 03, 2010
1997 dodge ram van 2500 fuel filter location
There is no replaceable inline fuel filter on your vehicle. Its fuel filter
is in the tank and is part of the pump assembly.
Sep 21, 2014 | XTM Fuel Filter Stone Filter
Where is fuel filter located on a 1998 saturn sl2 2.2 liter engine?
fuel filter and fuel pressure regulator located bottom of the vechicle near the front left corner of the fuel tank.
Sep 12, 2012 | XTM Fuel Filter Stone Filter
1999 chevy silverauto quits running no fuel pressure. new fuel pump new filter. Can't figure it out
might be a bad fuel regulator.. or your fuel pump relay might be going bad.. and also where did u get your fuel pump from.. i ran into a problem where i had to replace a fuel pump 3 times before i finally got on that worked right..
Apr 29, 2012 | Chevrolet Cars & Trucks
I have a clogged fuel line (filter?) I do I remove the bushing without damaging it?
FUEL FILTER
(For 40/55/60/70/110/115/155/165 Models
Only)
1. Remove side cover screws using 5/16" nutdriver.
2. Remove side cover.
3. Pull upper fuel line off fuel filter neck (see
Figure 15 or 16).
4. Carefully pry bushing, fuel filter, and lower
fuel line (110/115/155/165 Models only) out
of fuel tank (see Figure 16).
5. Wash fuel filter with clean fuel and replace in tank.
6. Attach upper fuel line to fuel filter neck.
7. Replace side cover.
Jan 20, 2012 | Reddy Heater-70,000 BTU Kerosene w/T'stat
I'm tuning the ole truck up and I figured I'd go ahead and buy a new fuel filter, but I can't seem to find the fuel filter on the truck.
The filter is located inside the frame under the drivers side door. Do not try and open the clamp, diconect the fuel lines and gently slide the filter out.
Feb 25, 2011 | 1998 Chevrolet K1500
How can I tell if my fuel filter needs to be replaced. My mower the ys 4500 quit running the other day so I figured it was the fuel filter or line but how can I tell if it is the problem
Hello. IF your spark plugs are good, and your air filter is clean, and your fuel tank is not close to empty, the next thing to check is the fuel line and the fuel filter. As a general rule, I change the fuel filter every 40 hours and the fuel line every 200 hours. J.
Jul 06, 2010 | Craftsman 21 Hp 42" Deck, Ys 4500 Lawn...
Component locater looking for fuel filter
the filter which should be along the frame rail on the driver side about midway. there will be clips on either side of the filter that secure the fuel line to said filter. they will be the quick connect type and there are a few different kind so you will have to figure that for yourself. (they are real easy so don't fret, I'm sure you can figure it out.)
Jul 22, 2009 | 1998 Jeep Grand Cherokee
Basic service
Here are detailed instructions on the location, removal, and re-installation of your fuel filter. Hope it helps and have a great day!
REMOVAL & INSTALLATION
Carbureted Engines
These vehicles use two replaceable fuel filters. A small one is in the fuel line under the hood; a larger one is located at the rear, just inboard of the left rear wheel.
Whenever the filter(s) are replaced, take great care to avoid the entry of dirt into the lines. Also, pay attention to the correct installation position. It is possible to install the filter backwards.
FRONT
See Figure 2
  1. If applicable, disengage the filter or hose from its retaining clip.
  2. Using two fuel line clamps, pinch off both fuel lines. Take care not to crush the lines; just clamp them shut.
If the fuel hoses are hard or cracked, it is necessary to replace them.
0900c1528005f267.jpgFig. 2: Front fuel filter used on carbureted engines
  1. Loosen the fuel line clamps and slide them back.
  2. Using a twisting motion, remove the fuel lines from the filter.
  3. To install, use a new fuel filter and reverse the removal procedures. Start the engine and check for leaks. Correct any leaks immediately.
REAR
See Figures 3, 4, 5 and 6
  1. Raise and safely support the rear of the vehicle. Remove the left rear wheel.
  2. Remove the bolts securing the filter and its basket to the fuel tank.
0900c1528005f268.jpgFig. 3: Remove the bolts securing the filter and its basket to the fuel tank ...
  1. Push the fuel filter retaining tab and release it from the basket.
0900c1528005f269.jpgFig. 4: ... then release the basket from the filter
  1. Using two fuel line clamps, pinch off both fuel lines. Take care not to crush the lines; just clamp them shut.
0900c1528005f26a.jpgFig. 5: Clamp the fuel lines shut. If the lines are hard, cracked or brittle, they must be replacedIf the fuel hoses are hard or cracked, it is necessary to replace them.
  2. Using a twisting motion, pull the fuel lines from the fuel filter; remove the filter.
0900c1528005f26b.jpgFig. 6: After sliding the retaining clamps back, the filter can be removed from the linesTo install:
  1. Use a new filter and reverse the removal procedures.
  2. Make certain the retaining tabs are engaged when the filter is installed in the holder. Tighten the bolts until snug.
  3. Install the left rear wheel. Lower the car to the ground.
  4. Start the engine and check for leaks. Correct any leaks immediately.
Fuel Injected Engines
See Figures 7, 8, 9, 10, 11 and 12
The canister fuel filter is located in the engine compartment. When buying the new filter, also buy new washers for the banjo bolts and the service bolt. Failure to replace these washers invites high-pressure fuel leaks. Replacing the washers is required, not recommended.
  1. Disconnect the negative battery terminal.
  2. The fuel system is under pressure. Release pressure slowly and contain spillage. Observe "no smoking/no open flame" precautions. Have a Class B-C (dry powder) fire extinguisher within arm's reach at all times.
  3. Disconnect the banjo bolts and/or threaded fuel line fitting from the fuel filter. Use of a flare nut or line wrench is recommended for disconnecting and attaching this fitting.
0900c1528005f26c.jpgFig. 7: Fuel filter used on fuel injected Accords through 1989 0900c1528005f26d.jpgFig. 8: Fuel filter on 1990-93 fuel injected Accords 0900c1528005f26e.jpgFig. 9: Fuel filter used on fuel injected Preludes through 1991
  1. Loosen the fuel filter clamp bolt, then remove the filter.
To install:
  1. Install the new filter and secure the clamp bolt.
  2. The upper and lower washers on each banjo bolt and the washer on the service bolt MUST be replaced whenever the bolts are loosened. Install the washers and banjo bolts. Tighten the banjo bolts to 16 ft. lbs. (22 Nm) on all models except 1992-95 Preludes. On these models, tighten the bolt to 20 ft. lbs. (28 Nm). If applicable, tighten the threaded fuel line fitting to 27 ft. lbs. (37 Nm).
0900c1528005f26f.jpgFig. 10: Fuel filter used on 1992-95 Preludes 0900c1528005f270.jpgFig. 11: Fuel filter used on 1994-95 4-cylinder AccordsIt will be necessary to use a crow's foot attachment on a torque wrench to properly tighten the threaded fuel line fitting.
  1. Tighten the service bolt to 9 ft. lbs. (12 Nm).
  2. Start the engine and check for leaks. The engine may crank longer than normal until full fuel pressure is developed. Correct any leaks immediately.
0900c1528005f271.jpgFig. 12: V-6 Accord fuel filter
Nov 23, 2008 | 1985 Honda Accord
Previous periodic stalling, now won't start
Almost sounds like a faulty fuel regulator. I've seen that happen without triggering the OBD codes. I'd check the wiring on the fuel pump as well as it may not be running correctly. Also, check out the fuel filter. A clogged up fuel filter won't register the OBD either.
Sep 10, 2008 | 1996 Chevrolet Blazer
Fuelfilter
go to your nearest auto parts store and look in the tools section and you will find a fuel line tool made to remove the fuel filter
Jun 14, 2008 | 1999 Ford Ranger SuperCab
Husqvarna "Chain Saw - 16" Bar, 3 Hp Logo
43 people viewed this question
Top Husqvarna Garden Experts
Phil Walker
Phil Walker
Roland W VanLue
Roland W VanLue
Are you a Husqvarna Garden Expert? Answer questions, earn points and help others
