Question about Cycling
Metric or standard hex drivers for a Roadmaster Mt. Sport SX?
My son got a hand-me-down Roadmaster Mt. Sport SX 24" bike with no manual. Does it require metric or standard hex drivers for replacing brake pads, etc.?
4 Suggested Answers
  • 190 Answers
SOURCE: My daughters mt sport sx
phililisa03-
This problem is caused by improperly adjusted derailers/shifters, the mechanism that move the chain from one gear to the next. It is not uncommon for the derailers to be out of adjustment after sitting unused through the winter. Over time the cables that run between the shifters and the derailers stretch just a bit and the derailers no longer work as well without a little tuning up. Unfortunately, for the novice, adjusting the derailers is frustrating at best. The effort and patience it requires is nothing to take lightly. If you're game for giving it a try, there are a number of websites out there that will provide extensive guidance on the process - just "google" how to adjust bike derailers" and you will find plenty of options. My local bike shop will make adjustments like this for a small set price, around $20 or so - you may have a shop nearby that will do the same.
Hope this helps.
Regards,
DIYpro
Posted on May 03, 2011
dunnbiker
  • 8546 Answers
SOURCE: i have an older royce
No matter what size it ends up being you still need to find them. Is there a hardware store nearby? Take it there.
Posted on Jul 16, 2011
dunnbiker
  • 8546 Answers
SOURCE: where can I get a
What exactly are you needing instructions for? Most bikes are just static frames with a bunch of aftermarket (Shimano, for example) stuff hung on them.
Except for proprietary frames or technologies, everything on a common bike is found on just about any other brand of bike and the individual components are usually documented at the individual manufacturers' websites.
Places like http://www.parktool.com/blog/repair-help document many of the repair and adjustment procedures.
Search Engines will find tons of How-to videos for assembly and adjustment if you just type in the basic question.
Any of the major cheapo bike manufacturers will have a basic or comprehensive generic manual. No one makes manuals for individual models unless they are unique.
Posted on Aug 10, 2011
Hi I recently bought a used roadmaster mt sport sx bike and the rear gear that's attached to the wheel is moves like in circles... is that supposed to happen... if not how can I fix it?
Lots of things on a bike move in circles. If you mean it moves when you pedal but does not "catch," so the bike does not move forward then that is a problem with the rear gear cluster. You need to have a mechanic look at it. If that's not what you mean you need to get help in providing a more clear explanation.
Oct 12, 2016 | Roadmaster Cycling
Do you have Roadmaster bike manuals
The only thing I can recommend is go to Walmart, ask them. Or look for a Roadmaster on their shelves, look for a website in the booklet hanging on thebike
Sep 29, 2014 | Roadmaster Mt Fury Bicycles
Replace rear tire
Remove rear wheel from bike. Deflate tube by removing valve stem. Tire should remove easily by pulling rim of tire over the rim. IF difficult, take to local bike shop for assistance
Jul 29, 2014 | Roadmaster Mt sport sx
I need an owners manual for roadmaster granite peak 24" girls mt bike
Wow, really? Just tell her to get on the bike and pedal. No need for a manual...are you kidding me?
Jul 05, 2014 | Cycling
Graco pack play
Hi Carol, remove the fastener from the opposite side of the one that is missing and take it to a Home Depot or Lowes in your neighborhood. Some well stocked hardware stores may also be able to help. They have both metric and standard threaded screws and bolts and I believe the Graco uses metric. They have boards in the hardware department that should tell you which type you need.
It doesn't usually need to look the same to do the job but if they have nothing to help you out, you will at least know if it's standard (for example 10/24 x 1" which means the screw or bolt is size 10 with 24 threads per inch by 1 inch long) or metric (M5 x 0.8 x 1" which is the metric size closest to a 10/24 x 1") and the type of head, hex or bolt head or a screw driver head, Phillips or flat-bladed.
Armed with that information you'll be able to locate the exact replacement from hardware providers on the internet.
(If the head is unusual, take a picture)
Hope this helps,
The Tinker
Nov 30, 2013 | Baby Gear
Where can I get a manual for mt sport roadmaster 18 speed bike
Aug 10, 2011 | Cycling
I own a 1976 AMF H/D SX175, and I have two questions. 1. I would like to order a shop manual so I can rebuild the bike, where can I find one? 2. My bike is #6,818. How many SX 175's were producwd in...
Your SX-175 is one of the Aermacchi-built Harley-Davidson lightweight bikes built between 1961 and 1978. There were lots of the SX-175's built. Matter of fact, I know where there's one still in the crate.
There are only a few places left that have the parts to repair the bike and it takes some special tools to work on them. I'm not talking about metric hand tools but special tools necessary to split the case and to pull the crankshaft back into the cases if you take it out. The cylinder on the engine is "Nikasil-ed". This means that you cannot bore the cylinder out as only standard sized pistons were available from Harley. You'll have to purchase a new piston and then send it and the cylinder off to have it re-Nikasil-ed. The crank is just a standard two-cycle engine crank.
The best place to find the parts and the manual you want is Moto-Italia. Leslie is a good guy to do business with. http://www.motomacchi.com/ There is also an Yahoo Aermacchi group online. http://autos.groups.yahoo.com/group/Aermacchi/ Since this forum is not dedicated to the Italian Harleys, contact me directly at wd4ity@bellsouth.net and I'll help you as much as I can. The knowledge base for those bikes is very limited.
Good Luck
Steve
May 04, 2011 | Harley Davidson XLS 1000 Motorcycles
My daughters mt sport sx roadmaster bike keeps changing gears and making a clicking sound. What causes this?
phililisa03-
Hope this helps.
Regards,
DIYpro
May 03, 2011 | Roadmaster Cycling
Can I raise up the handle bars on my 26" Ladies'
No, but a bike shop can assist you in selecting and fitting a stem with a higher rise.
Feb 24, 2011 | Columbia Sportswear Columbia 26" Ladies...
I need an owners manual for a roadmaster mt storm by huffy
The best I can do is to provide you with the manual that Huffy provides for multiple bikes. The manual below is for multi-speed and freewheel bikes.
Huffy Multi-speed Manual
Hope this helps. Thanks for using Fixya.
Note: If the manual link above is not useful you may contact Huffy directly at:
Huffy Bicycle Company
6551 Centerville Business Pkwy
Centerville, Ohio 45459
(800) 872-2453 customer service
Monday - Friday: 8:00AM - 12:00PM; 1:00PM - 4:30PM EST
Jul 13, 2010 | Huffy Men Mountain Bike (26")
Cycling Logo
88 people viewed this question
Top Cycling Experts
Michial Gueffroy
Andrew Taylor
Andrew Taylor
Are you a Cycling Expert? Answer questions, earn points and help others
