Question about Kenmore 23913 Progressive PowerMate Bagged Canister Vacuum
Kenmore Progressive Model # 116 25914507
A sock was sucked into the vacuum only wrapping around the roll brush. I immediately cut the vacuum off and pulled the sock out (the sock was not sucked into the hose). When I turned the vacuum back on the motor is not turning over. The main floor attachment is not turning for carpet use. The vacuum suction still comes on however the brush never turns. Please help.
  • 5 more comments
  • Anonymous Mar 26, 2008
    I have the same problem. I accidentally sucked a small cord into the vacuum and turned it off and removed the cord. Everything looks fine and the vacuum will still **** air but the brush will not turn. HELP! =(
  • Anonymous Jan 04, 2009
    Sucked in a rug and brush topped. Pushed the reset but still will not turn, Vaccum sucks from the upper unit. Pushed the reset again and again but brush will not turn. Help. Model 116
  • Anonymous Mar 23, 2009
    yes the great sock thing happened to me just looking around. The reset button dosent help me...
  • annmarlx Apr 05, 2009
    I sucked up a ribbon, no apparent damage done, but the carpet attachment will not function anymore. It still has suction but the wheel doesn't run.
  • Anonymous Mar 14, 2014
    When I turn the yellow dial to 'floor' I get no suction.. if I turn the dial to 'Tools' I get good suction.
  • Anonymous Mar 15, 2014
    The "Power Brush" attachment for upholstery doesn't spin or pick up anything. Have disassembled the attachment, nothing clogged or stuck in it and there's nothing clogging the vacuum or hose. Vacuum works fine on floors and if just using hose without the attachment it has good suction. As soon as I put the "Power Brush" attachment on, there's no suction, the brush inside the attachment doesn't move... basically it does nothing.
  • Anonymous Mar 29, 2014
    The vacuum is plugged in, but when I push the button to turn it on it does not turn on. The attachment for the carpet turns on.
I had the same problem with my vacuum. I called in for technical service and was told to push the "reset button". It turns out that there is a small red button right next to the dirt indicator light. I pushed the button, plugged the vacuum back in and started it up and it worked like a charm! :) Hope this helps!
Posted on Mar 26, 2008
What do you do when the brushes stop moving - sucked up something
Remove the bottom cover and check the belt. You may have to remove the beater bar or brushes as you call it.
Mar 11, 2015 | Vacuums
Sucked up a string and now roller isnt moving
turn the unit off and unplug it - get a razor blade - turn the unit on its side or back which is easier for you to see the bottom of the cleaner and the string wrapped around the ball and connecting area - use the razor blade to cut only the strings and remove the string from the ball
Jan 15, 2013 | Kenmore 23612 Progressive PowerMate Bagged...
I sucked up a sock into the carpet attachment of my electrolux 3500 series and the carpet attachment cut off. After the sock was easily removed (it was only wrapped around the brush part) I reattached the...
Did you press the reset button? There will be a reset button either on the back of the unit just below the bulkhead or on the top side of the base.
Locate the reset button and press; this should allow the carpet attachment to resume operation.
If you require an Owner's Manual try downloading the Epic 3500 manual from this site:
http://www.aerusvacuums.com/support/manuals/index.cfm
May 01, 2011 | Electrolux Epic 3500 Vacuum
Kenmore direct drive model 116 31912100 lost vacuum
Check the inlet where the dirt is first sucked in for a clog, also your hose may be clogged.
Sep 01, 2008 | Kenmore 31913 Progressive Direct Drive...
Kenmore 35913 Progressive
Go to sears.com, click on the parts link, enter your full model number, then scroll down and there are several options to clikc on, a parts list and picture parts breakdown are there and if a manual is available, you can get it and parts thru this site. There is a overload switch for the brush roll motor, if tripped then it won't turn. Could be that the brush roll motor is bad. The motor and brush roll are put together as one unit, but you can get the motor by itself.
May 29, 2008 | Kenmore 31913 Progressive Direct Drive...
Kenmore progressive Direct Drive Vacuum w/Hepa
Check the hose and dirt inlet for a blockage. Also the brush roll, check it to see if you can turn it or not by hand. If not, then something may have jammed it.
May 03, 2008 | Kenmore 31913 Progressive Direct Drive...
How to take the brush out?
There should be screws on the bottom plate covering the brush roll, take those out and it should come off and then you can access the brush roll.
Feb 17, 2008 | Kenmore Progressive Bagless Upright with...
How do I take the brush out?
Most of these progressive drives have a bottom plate that you can take off, then you can get to the brush roll asm. There will be several screws.
Feb 17, 2008 | Kenmore 31913 Progressive Direct Drive...
Doesn't suck
you need too change the belt on the bottom where the brush is take off bottom cover and underneath is the belt if its broke replace it
Dec 22, 2007 | Kenmore 35912 / 35913 Progressive Upright...
Kenmore 23913 Progressive PowerMate Bagged Canister Vacuum Logo
2,604 people viewed this question
Top Kenmore Vacuums Experts
Chris Nomland
Chris Nomland
Are you a Kenmore Vacuum Expert? Answer questions, earn points and help others
