Question about Moen 7437 Chateau Single Hole Kitchen Faucet with Side Spray Chrome...
I installed A new kitchen faucet and when I turned the water on I got all this black stuff out of it and then it all but quit running. The sprayer works fine but the faucet doesn't.
    President:
  • 512 Answers
Unscrew end of faucet where water comes out. It is probably plugged. They put extra screens in it, so remove some of them, turn on before replacing and let water run to get out remainder of sediment.
Posted on May 03, 2010
American Standard Kitchen Faucet Low water flow
I had the same issue with an American Standard faucet that I installed new 6 months ago. The diverter can be the issue if you have a sprayer attachment. Try unscrewing the sprayer head from the hose it's attached to. Now run the water full pressure with the hose pointed into the sink, obviously :~). After running the water for about 1 minute, connect the sprayer head back onto the hose, make certain the flat rubber washer and ring gaskets are seated in their grooves properly, and tighten until you have no water leaking from the sprayer head/hose connection. Now try the water through the faucet. If the problem was a temporary diverter issue, your pressure should be fine now. Good luck
Oct 31, 2011 | American Standard Kitchen Faucet 6310 020...
Installed new kitchen fauce. no water running though faucet but is running though sprayer. what could be the problem?
Sounds like the diverter that transfer water from faucet to sprayer is bad or stuck. Try turning water off and removing handle and remove spout to acess the diverter is near the base of the body of the faucet. Below is a link with a exploded view that will show you a parts breakdown hope this will help.
http://www.moen.com/shared/pdf/ca87530pt.pdf
Jun 26, 2011 | Moen 87530 Touch Control Single Handle...
Sink sprayer hose makes noise
hello, you may have a air pocket in the line try shutting of the water supply and then sqeeze the handle and slowly turn the water supply back on with the hose handle squeezed on till the air is forced out, hope this helps
Jun 07, 2010 | Moen 87530 Touch Control Single Handle...
Water running in Moen single-handle kitchen faucet suddenly stops
There is a small diverter valve on the faucet underneath where the hose connects too it needs to be replaced depending on the age of the faucet I usually recommend replacing the entire faucet with another Moen product
Oct 18, 2009 | Moen Plumbing
Installed brand new marielle kitchen faucet with matching srpay and soap... sprayer is not working. please help
If you used the teflon tape to seal the threads on the sprayer connection. Make sure the tape is has not blocked the line.
Check for any kinks in the hose and it is not pinned against something.
Turn on the cold water and hold the sprayer over the sink and activate.
If nothing happens while still holding the sprayer move from cold water to hot. If still no water there maybe something in the line preventing the sprayer from receiving water.
Highly doubt there is anything mechanically wrong but it has happened before. See if you can swap it for a new one.
Oct 06, 2009 | Price Pfister Marielle Kitchen Faucet with...
Moen kitchen faucet set wsprayer can't shut sprayer.
there is always water pressure on the sprayer when water is on. if sprayer is leaking check if trigger is stuck in . best to just change the sprayer handle it comes off at the base of the handle
Jul 20, 2009 | Plumbing
New faucet, sprayer hooked up right, no water going into hose?
check the sprayer handle by disconnecting and blowing into it and pressing sprayer handle and/or for possible kink at main body or hose by disconnected sprayer point hose into sink and turn on water. If no water the the diverter in main body is not working properly and needs to be reassembled or replaced
Jul 01, 2009 | Price Pfister Marielle Kitchen Faucet with...
Kitchen sprayer stays running and won't shut off
From your description it sounds like the sprayer is stuck open. Replace with a new sprayer or rebuild. Higher end faucets rebuild. Lower end faucets replace. Without the Brand or Model# this is my best guess.
Be sure to rate this response and Good luck, Phil
Dec 24, 2008 | Delta 2402 Classic Single Handle Kitchen...
Faucet/sprayer coordination
If you have a Delta faucet your diverter may need to be replaced. The diveter is located under the spout (see diagram)(this is not your faucet but works the same)
Here are the instructions:
  1. Turn off water to faucet.
  2. Remove handle.
  3. Remove top cap.
  4. Turning spout back and forth gently lift and remove.
  5. Remove and replace diverter.
Hope this helps and please remember to rate this!
Nov 15, 2008 | Delta 2402 Classic Single Handle Kitchen...
Moen 7437 Chateau Single Hole Kitchen Faucet with Side Spray Chrome... Logo
113 people viewed this question
Top Moen Plumbing Experts
john h
Donni Steen
Don Numinen
Don Numinen
Are you a Moen Plumbing Expert? Answer questions, earn points and help others
