Question about Canon PowerShot G9 Digital Camera
What do you do when sd card reads full and only has 4 pictures on it
  • kakima May 11, 2010
    What I would do is to immediately download the four pictures to my computer, then format the card in the camera. Then, if the card still doesn't work properly, I'd throw it away --- my pictures are too valuable to trust to flaky cards.
    What happens when you format the card on the camera?
    One Above All:
    The expert with highest point at the last day of the past 12 weeks.
    Top Expert:
  • Canon Master
  • 102,366 Answers
Having gone over a month with no response, I assume this is no longer a problem.
Posted on Jun 07, 2010
I have a Nikon D5300. I can see the photo count number increasing, but I cannot view the images and they are not going on the SD card. Where are they? The SD card is not full.
many small Nikon cameras have memory to store images ON THE CAMERA. If you have a memory card installed that the CAMERA CAN READ it will put images on the card. if the memory card is corrupted the camera will not use it.
First Backup all IMAGES on Memory Card to COMPUTER make sure you saved ALL images. This is IMPORTANT.
After you SAVED all images you PUT Memory card back in camera and FORMAT it (Format is in TOOL Menu that looks like a wrench)
Now if you can take an images and it saves to memory card you are done. To see if they go to MEMORY CARD. Turn off camera and remove MEMORY CARD and Check.
If it STILL does not work you may have a defective memory card.
Feb 23, 2017 | Nikon Cameras
What is the class of this card? 4 or 10
If on the card is no C with the 4 or 10 in it, it even can be worse. As you can see on the picture a Class 10 card sometimes only has a C with the 10 inside.
The 32 Mbyte card you show here, is an old SD card and in those days they only gave read and write speed in Mega byte / second, if it was a real good card. If it should be a class 10 card with say 40 Mb throughput a second you would have 0,8 seconds to completely fill the card.
In a modern photo camera with 12 or 16 M pix, it could hold 3 or 4 pictures and it would be full.
Jun 22, 2014 | Canon 32mb Sd Memory Card Sdc-32m
Mi pictures in my zte phone are not showing up why?
You may have corrupted the SD Card. Try shutting down the phone and remove the card. then re-install, If you have another device that will read it try that. And of course go to your file folder and see if your SD card is visible. Also try another SD card. Hope this helps Let me know Thanks!
May 14, 2014 | ZTE Score
D60 has SD card full message but the SD card is brand new and formatted.
Have you tried using it in another device that reads/writes SD cards?
It's possible it is a counterfeit SD card. Some counterfeit cards don't work or are not the true capacity. If it it a name brand like SanDisk it will have a serial number. The counterfeit ones typically don't have serial numbers.
Sep 02, 2012 | Nikon D60 Digital Camera
Memory full on SD card but still space left
FRIST, download the 83 pics u have and save them. your camera may be reading the internal memory. go to setup and change to sd card option. If that doesn't do it, and it's already looking at the SD card. Format the card. NOTE: see first line again!!!
Jul 31, 2012 | Fujifilm Finepix A600 6 3 Mp Digital...
I just got a samsung sensory pleasure nv3 i put a 4 gb memory card in it and it says memory full but the card is empty
Hi
Try formatting the SD card before using it.Also,check the storage destination of the pictures,could be they're storing on your camera and not in the memory card.Make the SD card the default storage device.
Hope it helps.
Feb 20, 2012 | Samsung NV3 Digital Camera
When taking a picture a message pops up that says "cannot be written to SD card"
Checks to make:-
1) Is there an SD card in your camera?
2) Is the SD card compatible with your camera?
3) Is the SD card write protected (Check notch top left hand corner of card)
4) Is the SD card full or nearly full?
5) Are you trying to write a file type (.raw) which is bigger than the capacity of the card or the remaining capacity on the card.
Nov 01, 2011 | GE X500 Digital Camera
Hi, got new kodak camera and 4gb memory sd inside. i only took 8 pictures so far and said internal memory full. i dont understand why? i want to keep 8 pictures and it should be plenty as using 4gb and...
4GB "SD" cards are almost always actually SDHC (high capacity) cards. SD and SDHC cards fit the same slots, but they are slightly different electrically. Many cameras won't work with SDHC cards. SDHC is not backwards compatible.
So your camera is not able to use the 4GB card, and is ignoring it and using internal memory only. That memory is tiny and won't hold many pictures, and when it is full, the camera cannot work at all. You need to delete the pics in the internal memory and get a memory card your camera can understand (2GB or less).
Jan 27, 2011 | Kodak Cameras
Display reads "images recorded in internal memory" but there are none and I can't take more than 4 pictures until the camera says the memory is full. Also the memory card says it is full after 7 pictures,...
hi, the memory card you are using is to small for the camera it has not got enough memory on it you need to get at least a 1gb memory card or 2gb memory this will then allow you to take between 500 and 1000 pictures the 16mb card you have in is not worth using it will only hold a couple of pictures so go to the well known auction site and buy a 2gb memory card of the same type such as sd card or micro sd or mini sd it should tell you on the 16mb card what type it is then just buy the same type but with either 1gb or 2gb or even 4gb of memory this will then let you take 1000s of pictures
the 16mb card is no good in your camera get a bigger card and your problem will be solved
let me know if you have any problems with the new card ok
Aug 15, 2010 | Fuji FinePix A800 Digital Camera
Memory card reads full
What size card is it a plain SD or MMC? is it less than 4 meg? is it 2 megs or less
2 meg or less it needs to be formatted. It is 4 meg the camera will not read it.
It happened to me on a Z740
Jul 24, 2009 | Kodak EasyShare C310 Digital Camera
Canon PowerShot G9 Digital Camera Logo
24 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
