Question about Apple iTunes
Device never shows up in ITunes when i plug my Iphone in to sync
SOURCE: iPhone 3G Error 0xE8000001
I just had this problem and it turned out to be... It didn't like my iPod cable. Switched to the iPhone cable and it worked.
Seems to be an iPhone 2.0 prob, or 3g prob, since I was using the iPod cable to sync my old iPhone just fine.
Posted on Aug 07, 2008
no_pc-gst
  • 58 Answers
SOURCE: iphone 2g wont sync
Please look here:
iphone Troubleshooting Assistant
http://www.apple.com/support/iphone/troubleshooting/phone/
Reset and Restore iPhone to Original Default Factory Settings with Recovery Mode iPhone display freezing? iPhone doesn’t detect by or appear in iTunes? iPhone cannot sync with iTunes on PC or Mac? Cannot make or receive calls, send or receive text messages, or access email or the web? Or worse, iPhone simply won’t turn on and does not respond to tap or button press? If the problem still persists after you have reseted the iPhone, or tried various iPhone troubleshooting, it may be worthwhile to invoke recovery mode to restore iPhone to default factory settings, the original state as when you first received and unwrapped the phone.
Restoration of iPhone to original factory defaults will likely to fix all problem, with the downside that all data and information stored on your phone will be lost. Normally iTunes will make a backup automatically when you connect and sync the iPhone with the program, however, it’s still a good recommendation to copy out and backup everything that you may need on the phone before proceed to restore the iPhone.
To restore iPhone and reset the phone to default factory settings, follow these steps:
  1. Turn off iPhone - Hold down the Sleep/Wake button for a few seconds until the red slider appears, then slide the red slider. Ignore this step if your iPhone is already off.
  2. Press and hold down the Home button for about 10 seconds until a yellow triangle with a text which says Please Connect to iTunes appears. iphone-recovery-mode.jpg
  3. Plug the iPhone into Mac or Windows PC. Release the button if you haven’t.
  4. Run and open iTunes if it’s not already opened yet.
  5. iTunes will prompt a message that says iTunes has detected an iPhone in recovery mode. Click OK.
  6. You will be taken to the iPhone pane. Then, click on Restore.
  7. Wait for the full restoration process to complete, and the iPhone will be back to the original settings state as when it left the manufacturing factory, typically a working phone again if you face any problem, unless it’s hardware related
http://www.mydigitallife.info/2007/10/04/reset-and-restore-iphone-to-original-default-factory-settings-with-recovery-mode/
Posted on Jan 02, 2009
  • 34 Answers
Where did you purchase your phone? however, you first need to update itunes to 8.0.2, that might solve your problem. Unless you have an unlocked phone then restoring your phone is useless because when you restore an iphone with itunes in the US without an att sim card it will actually lock the phone, but I do not think that is your issue. the two things you are seeing the connect to itunes and the emergency call system means that your phone is not properly activated. which is done by connecting it to itunes.
Posted on Jan 25, 2009
SOURCE: Error code #13019 iphone not syncing w/itunes
I googled this question and found out a lot of people are having this problem. Check this thread out for the solution. It worked for me.
http://support.apple.com/kb/TS2830
Posted on Jul 17, 2009
drifterK
  • 4924 Answers
SOURCE: itunes wont recognize my iphone
I see. maybe and this is more than sure ...this new update of the program doesn't have the drivers for the device ..or its an incomplete program ...or ..a trial ...if you can not do anything . just roll back to the old program ...and see if it works...if the problem persist try to look for a driver to install... I mean the phone driver but ...I believe its something strange cause it should have seen it like a storage device and at least work the charger
Posted on Jul 25, 2009
How do I sync my iPhone 5s with my desk top
1.Download iTunes to your Mac/PC
2.Plug in your iPhone to desktop
3.Open iTunes, it will find your iPhone
4.Click your iOS device
5.On the Summary tab, select "Sync with this [device] over Wi-Fi."
6.Click Apply, then disconnect the USB cable
7.Choose which items you want to sync, then click sync.
Sync your iPhone iPad or iPod touch with iTunes using Wi Fi
Dec 10, 2016 | Apple iPhone 5S
Transfer music to MP3 from my phone
Connect the phone to a computer and Windows Explorer _may_ show the folder of music as a removable volume.
On an iPhone you can see them in iTunes.
Jul 11, 2016 | Cell Phones
How do I sync my phone to itunes
You can sync iPhone with iTunes via Wi-Fi easily.
  1. Open iTunes. Make sure that you have the latest version. Use the USB cable that came with your iOS device to connect it to your computer.
  2. In iTunes, find and then click your iOS device. On the Summary tab, select "Sync with this [device] over Wi-Fi."
  3. Click "Apply" button, then disconnect the USB cable. Choose which items you want to sync, then click sync.
sync-phone-itunes-oxaxc0rwhkhzilrwacqreyis-3-0.jpg How to Sync iPhone with iTunes
Dec 13, 2015 | Apple iPhone 4S 64GB Unlocked - Never...
ITunes no longer recognizes my iPhone 5, running Windows 10
You may upgrade your iTunes to the latest version to have a try or you can use a nice alternative to iTunes for iPhone to sync your data to PC. Top 3 free iTunes alternative for iPhone
Oct 09, 2015 | Apple iPhone Cell Phones
Is there any way to transfer my iTunes music to my iPhone or do I have to pay just to have music on my phone
Use the power cord for the iPhone. It should be the USB connector on one end and the small plug on the other end. Plug the USB into the computer and open up iTunes. Under the FILE menu at the top, there should be a pull down sub menu that say "devices" SYNC.
Your iPhone will appear on the side bar once you switch to the "Playlist" page. You can drag a whole playlist into your phone icon or do individual tracks. At least, that's what I do.
Let me know if this works for you.
Mar 07, 2015 | Apple MacBook Pro Laptop Computer with...
IPhone deletes my contact names when I sync it to computer! Leaves the numbers, delete only names.
If you've set up automatic syncing, iTunes syncs your device by default whenever you connect your iPod, iPhone, or iPad to your computer. If you don't want iTunes to sync your device without being prompted, you can change this setting.
You can prevent unprompted syncing for any specific iPod, iPhone, or iPad; or for all iPod, iPhone, or iPad devices you connect to your computer.
To prevent unprompted syncing for a specific iPod, iPhone, or iPad:
  1. Connect your iPod, iPhone, or iPad to your computer.
  2. In iTunes, select your device (below Devices).
  3. Click Summary, and then deselect "Open iTunes when this Device is connected."
To prevent unprompted syncing for all iPod, iPhone, and iPad devices:
  1. In iTunes, choose Edit > Preferences.
  2. Click Devices.
  3. Select "Prevent iPods, iPhones, and iPads from syncing automatically."
    If this checkbox is selected, any connected iPod, iPhone, or iPad won't sync without being prompted.
To sync your iPod, iPhone, or iPad when unprompted syncing is disabled, connect your iPod, iPhone, or iPad to your computer, and then choose File > Sync "Device Name" in iTunes, or click your device (below Devices) and then click Sync.
For more information, see the iPod, iPhone, or iPad User Guide or the Apple Support website.
Dec 18, 2012 | Cell Phones
Can you sync iphone to your ipad?
iPubsoft iPad iPhone iPod to Computer Transfer is the best choice to backup the data betweent th apple devices, including iphone 3gs/ 4/ 4s/ 5s, ipad, ipod etc. iPubsoft iPad iPhone iPod to Computer Transfer
Apr 07, 2011 | Computers & Internet
How do you remove synced photos from the iphone?
You can do this in iTunes - with the iPhone connected select the 'photos' tab and deselect the folder containing the photos, then hit Sync to remove them.
Alternatively, just move the photos to a different location on your hard drive (out of any folder that is set to sync to iPhone), then connect to iTunes and hit sync.
Hope that helps!
Oct 30, 2009 | Apple iPhone 3G
I cant send any music from itunes to iphone how do i set it up to send muic to the phone i have opened up iphone
1. Download iTunes.
2. Connect your iPhone to the computer.
3. On iTunes, you should see your iPhone listed under Devices.
4. Click on your iPhone.
5. Go to the Music, Applications, TV Shows, and all those other tabs and set your preferences.
6. Click Sync.
Now you can send music from iTunes to iPhone.
Sep 26, 2009 | Apple iPhone Smartphone
Apple iTunes Logo
56 people viewed this question
Top Apple Computers & Internet Experts
marty morrison
marty morrison
Paul Carew
Martin Buck
Martin Buck
Are you an Apple Computer and Internet Expert? Answer questions, earn points and help others
