Question about Brother Multi-Function Center MFC-240C All-In-One InkJet Printer
Unable to CHANGE 51
Cannot turn printer off and can't find a solution to this. I have seen unable to CLEAN before, but never unable to CHANGE. What is this and how can I fix it? Model MFC-665CW.
Cannot turn printer off and can't find a solution to this. I have seen unable to CLEAN before, but never unable to CHANGE. What is this and how can I fix it? Model MFC-420 CN.
Posted on Jul 21, 2010
I have a Brother MFC-3360C printer and have an error. Clean Unable 51
Error 51 normally indicates a paper jam or a sensor problem. Check the paper path and the printer head movement zones (far left and right) for any foreign objects (even small pieces of paper). If there has been a paper jam, was the paper forcibly removed? If so, possibly one of the sensors has been knocked out of position or damaged. Dust, dirt, grease or spilled ink may also be contaminating a sensor. This is maybe one of the most elusive problems to solve..!
Apr 10, 2015 | Brother MFC-3360C All-In-One InkJet...
SeeTroubleschooting and Routine Maintenace chapter in user's quite.see clean unable 51 to MFC-230C
Hello and Welcome to FixYa!
"Unable 51" is most likely a print head issue. The print head is what the cartridges sit in inside of the printer. To attempt to resolve it, do the following:
(1) Open the printer
(2) Remove the ink cartridges from the print head.
(3) Use cotton swabs dipped in hot water or a mix of hot water and isopropyl alcohol to thoroughly clean the print head.
(4) Repeat this until there is no ink residue coming off on the cotton swab.
(5) Once finished, allow to dry and replace the cartridges
(6) Try to print something now
Your problem will be solved.
For any further help, you can take my valuable,professional help by taking my Service
Thank You for using FixYa
Mar 02, 2012 | Brother MFC-230c Printer
"Clean Unable 51" error. I
Click the link below to download the Service / Repair Manual ( Brother MFC-240C) :http://www.mediafire.com/?l39vz2fiqqkl73y
You must have Adobe Acrobat Reader installed to view PDF files. The reader is a free plug-in available at the Adobe web site
Jul 04, 2011 | Brother MFC 240C All-In-One InkJet Printer
How do I clear "Unable to Print 51" Error Code on a Brother MFC-665CW All in one Printer
51 error says that the purge assembly is stuck and not cycling properly. If you can power up and get the printhead to the center and unplug again, look with a flashlight in the far right corner where the printhead parks for any paper scraps or things that don't belong and remove them it might work again. Otherwise a shop repair to possibly replace the cleaning assembly.
Oct 02, 2009 | Brother MFC-665CW All-In-One InkJet...
Machine Error 51
More than likely you have a bad printhead, if its under warranty brother will pay to have it fixed, otherwise just play baseball with it and buy another one
Aug 22, 2009 | Brother Multi-Function Center MFC-240C...
"Unable to Print 50" BROTHER MFC-440CN
my brother mfc-440cn printer says, "unable to print 51" on the screeen after if off (which it woudn't let me do. I had to unplug it. It just won't work.
Aug 26, 2008 | Brother MultiFunction Center MFC-440CN...
Brother LC-51 unable to clean code 4F
The code 4F unable to clean comes up for paper jam, if no paper jam,TRY THIS MENU * 2864 VERY QUICKLY TAKES YOU TO MAINTANENCE MODE, ALL LIGHS FLASH... PRESS 82 SET, YOUR ERROR CODE WILL DISPLAY. THAT IS NEXT STEP.!!!!
Hope this may help;
Regards,
VOTIT
Jun 13, 2008 | Brother MFC 420CN All-In-One InkJet...
Clean unable 51
Ok Please follow this link and it has your answer.
Please rate me when it was a FIXYA
May 03, 2008 | Brother Multi-Function Center MFC-240C...
Brother Multi-Function Center  MFC-240C All-In-One InkJet Printer Logo
579 people viewed this question
CheckitRight
CheckitRight
Ron Dufek
Ron Dufek
James Cagle
James Cagle
