Question about Mr. Heater Mr Heater Portable Buddy Propane Heater
Why does my Mr. Heater shut off after a couple of minutes in lo and high?
I have a nexgrill propane patio heater the pilot light works but when i turn it to lo or high after a minute or so the pilot light stays on but the burner wont light
Propane Patio Heater Troubleshooting - YouTube
? 6:54
www.youtube.com/watch?v=BqYIWuDUZOUDec 12, 2008 - Uploaded by PatioShoppers Great tips about troubleshooting your outdoor patio heater. ...Pilot Light Won't Stay Lit - How to Replace a Broken Thermo Couple on Furnace ...
May 12, 2014 | Williams 2509612 Ceramic Mid-Size Heater
Shuts off on its own after a short running time
You more than likely have a high temp sensor opening up the circuit when it reaches its limit. It would have to cool down to close again. Either that high temp sensor is bad or your heater is getting too hot.
Dec 12, 2013 | Enerco Brands Mr. Heater ENEMH55FAV...
PRESSURE REABING
high side approximately 1500kpa and lo side about 400kpa depending the outside air temp. Mitsubishi high side been known to run higher on some units though
Jun 13, 2013 | Mitsubishi Mr. Slim MXZ30TN Air...
Runs for about 1-1/2 hours (on either lo or hi) and shuts off. will not restart. try again in the morning and it starts... want to return as it's the first time to use and it doesn't work!!!!
heater has an oxigen sensor,if it i used in a small closed room and oxigen levels are getting low, heater will shut off for safety reason. Try to open doors or windows for a while and see if heater restarts.
Oct 04, 2010 | Mr. Heater Mr Heater Portable Buddy...
Mr Heater MH12T noise and little difference in heat settings
HI Check out mr heater wed site there has been some recalls on some of there heaters if not take it back .............
Feb 09, 2010 | Mr. Heater MH9B Ceramic Utility
Heater shuts off , it shuts down after a minute or two looks like low flame and its blue in color i do hear a popping sound when it shut off
The heater thermostat senor for this heater could be bad or indicating a abnormal temperture shutting it down. You might want to return item if still under warranted
Nov 06, 2009 | Mr. Heater (F274825)
Heating & Cooling Logo
598 people viewed this question
Top Mr. Heater Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Mack Baxter
Are you a Mr. Heater Heating and Cooling Expert? Answer questions, earn points and help others
