Question about Dell Latitude D800 Notebook
Hi! my dell d800 wont turn on. I have take then battery out and such and then put it back in but it still wont work. I have put the charger into the computer and the computer says its not charging the battery. What should I do?
    Sergeant:
  • 195 Answers
The battery is damaged..replace the battery with a new one or you will have to run your laptop straight from a eletric power source with the battery removed.
Posted on May 03, 2010
Dell motherboard not coming on
For latitude there's not much to do. check the power adaptor/connecting pin --- if any problem. If not than u need to replace the board.
May 02, 2014 | Dell Latitude D800 Notebook
Dell latitude d800 not switching on ?
I may have addressed this question earlier. If your Dell shows absolutely no sign of life... no LEDs, no nothing and you know for certain the battery and/or power adapter is good then...
If you have access to a docking station (ANY Dell dock that will mate with the bottom connector on your D800), put the D800 in the dock and use the power button on the docking station.
If the laptop powers up, you may have a simply problem with the laptop "Press to turn on" button.
ABOVE THE LAPTOP KEYBOARD...
Use a small flat screwdriver blade to remove the Center Control Cover (just beneath the display/cover hinge and above the F1-F12 keys). Locate the cover's flat ribbon cable connector above the Page Up key. Pull off and carefully reinstall. Try the power button now. If it works, put everything back together. Otherwise seek profession help.
Hi, Dell D800 won't start up.
Can you F7 or F8 or whatever your system uses to get into the bios setup screen? If you can accesss that, you can install an operating system. If not, you have an issue. Put an operating system CD in to see if it is recognized for starters.
Apr 21, 2010 | Dell Latitude D800 Notebook
Dell Latitude D800 Wont Power Up
Check the status of the battery directly from the battery. Turn the laptop over and on the batter is an battery indicator button and lights to tell you if it's charged. If it is charged then you have an problem internally. Wiggle the tip of the power cord at the laptop connection to see if it is loose, if it is then you have an loose connection on the motherboard which can be fixed by an experienced tech that can solder or the motherboard will need to be replaced.
IF THIS HELPS PLEASE VOTE.....GOOD LUCK AND THANKS..
Nov 12, 2009 | Dell Latitude D800 Notebook
Dell D800 Won't power up at all?
Bad news, this most likely indicates a problem in the charging circuit on the mainboard. To be sure, remove the battery and try again, if the same thing happens, then the problem is on the mainboard, if not, replace the battery. I have encountered this problem on an older Dell laptop before, removing the battery did not help and replacing the charger did not help. If the problem is on the mainboard, replacement is rarely practical. The cost of the board and the labor to replace it usually exceeds the cost of replacing the laptop.
Hopefully someone else has a better solution.
May 24, 2009 | Dell Latitude D800 Notebook
I have a dell D800 it won't power on at all the battery show full
Try removing the battery and plugging it into the wall. then turn it on, if it turns on your battery is bad or connected improperly.
Dec 11, 2008 | Dell Latitude D800 Notebook
D800 will not even boot
Okay, I had that problem with my HP less than a minute ago.
Maybe it is the same problem. See if the battery light comes on. Press the power button again and again if it doesn't start, for some time. It may show the boot screen and hang. Now, the battery must be charged. Shut it down directly and switch the AC off.
Now, switch it on and see if the battery light comes on. If it does, it is the same problem as mine. Now, turn the PC over and remove the battery carefully. There may be switches for that.
Now, plug in the AC and start it without the battery in. If it does, you're done. Now, plug in the battery again.
Nov 28, 2008 | Dell Latitude D600 Notebook
Dell D800 Problems!!
Could be a short in the battery, Dell batteries are notorious for this. Try running it without the battery for a while. If the problem goes away, then it'e tome for a new battery.
Jul 05, 2008 | Dell Latitude D800 Notebook
NO POWER!!!HELP
Is the voltage meter directly on the Battery?? What model Dell is it?? I have found that on the D800 models for some reason the connection from the power button to the Motherboard comes loose. You need to remove the Keyboard cover to check this.
Jun 06, 2008 | Compaq Evo N610C Notebook
Latitude D800 wont boot
ok now it sounds to me the power pack on the back has shat its self so ufourtanetly u need a new one if u still have a valid warrenty ring dell or go to their web site at www.dell.com and they will happiley help u there number is also their but if u dont have warrenty go to their website and see how much it costs for a new battery but see a friend who has a dell laptop and plug in the power cord it might be your power cord not your com or battery so give it a wirl and if u have any problems email me at mid.nightclub@hotmail.com
Dec 31, 2007 | Dell Latitude D800 Notebook
Dell Latitude D800 Notebook Logo
152 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
