Hi my washing machine doent switch on I plugged it in, checked the fuse the plug but its just not turning on. wat swrong with the washing machine?
    President:
  • 1,382 Answers
If the lid switch is defective, your washer can't spin and may not function at all. The switch is inside the washing machine main housing near the door frame. Often you have to raise or open the top or front of the washer to get to the switch. If it's defective, you need to replace it. Some machines have a special lid-switch fuse near the lid switch, inside the control panel. If this fuse blows, the unit won't fill with water until you replace the fuse.
P.S: provide more details like brand name etc so that you can get a clear solution for your problem..
Thank you!
Posted on May 10, 2010
I have a fisher pakel washing machine GW711 ,power shut down just before the end of the spin cycle and won't turn back on
Hi Jeffrey.
Remember that the power starts at the consumer unit (fuse box); make sure that a fuse hasn't tripped.
Next, check the plug socket; the best way to confirm that there isn't a fault with the plug socket is to plug another electrical appliance such as the kettle to see if it boils as it should.
If all is ok with the consumer unit and the socket next you now need to confirm the wiring to the plug looks good and there are no kinks or breaks in the wire, and check that the fuse in the plug is ok.
Check the washing machine door Again, often overlooked but it's a simple mistake to make. Check your washing machine door is closed and closed properly. All washing machines have what's known as a door interlock. It is designed to stop the door from being opened when the machine is switched on, and unless the door of your washing machine is fully closed and latched, it won't start.
you can go to this link and read up some more on this matter.
Common Washing Machine Problems Ransom Spares or this one.
power shut down just before the end of the spin cycle and won turn back on...
Jul 03, 2018 | Fisher Washing Machines
Hi just wondering Where do i locate fuse in my 2015 samsung 6.5 kg top loader washing machine.. thanks
did not know they had fuse. if possible only use recepticale for washer. unplug washing machine and check your electrical source. plug in someting else in the washer's wall receptacle. if not working reset breaker or replace fuse at main house's electrical panel.. be responsible, no wet hands etc.
if receptacle is ok, plug in washer and look for any indication that electricity is coming into machine, perhaps a light or similar. your lid locking switch may have failed or has become loose. if timer is set by twisting and makes
clicking sound, your timer may have been at end of a
previous wash. if your timer is electronic, there may be
a fuse on one of your machine's computer boards. please
check your owner's manual.
Mar 03, 2018 | Samsung Washing Machines
My Bosch 1244E will not go on I plug it and no power?
Washing Machine Won't Start - White Goods Help
www.whitegoodshelp.co.uk > ... > DIY Washing Machine Repair Help
Jun 21, 2013 - If wall socket & fuse are OK but washing machine won't start ... didn't work - so I tried plugging my Hoover washing machine into another plug and all systems are go! ... I have a bosch washing machine which is 16 months old.
Washing Machine Fault Diagnosis - How to repair
www.how-to-repair.com > Home > Washing machines
Nov 11, 2014 - Washing machine will not start, no power. ... So begin at the plugand make sure that there is power to the socket and that the fuse is okay ... I have aBosch washing machine which is leaking from underneath and the water is coming out the front at the bottom. .... It washes but won't go into rinse or spin.
Washing Machine Will Not Start - What To Check - How To Fix
removeandreplace.com/.../washing-machine-will-not-start-what-to-check...
Apr 10, 2015 - Be sure the washer is plugged into the electrical outlet in the wall. ... If the lid switch is faulty, then the washing machine will not start. ... If the lid switch is being pressed but no power is being supplied to the washers motor, ..... October 28, 2014; Bosch Washing Machine Error Fault Codes October 28, 2014 ...
Dishwasher Will Not Turn On - How To Fix ...
Jan 19, 2016 | Bosch Washing Machines
Thers no power to my washing machine.changed the fuse and theresstill no power.what do i do ? thank you emma
Hi emma... Unplug the machine from it's current outlet and use a heavy duty extension cord to plug it into another outlet that you know works [plug a blow dryer in to check it].
If the washing machine works then you know the problem is in the outlet or the wiring to the outlet. IF the washing machine still doesn't work you know the problem is within the washing machine itself. Possibly the lid switch or a fuse within the machine. J.
Aug 02, 2011 | Indesit Washing Machines
Washing machine trips electric when fills with water
From the symptons described, I would suspect that the heating element is faulty, disconnect the heater, and try it again, if it does not trip, then replace heater.
Please rate my solution.
Thanks.
Aug 15, 2009 | Washing Machines
Washer will not turn on. The knob moves but nothing happens when I turn it on. I've checked the breaker, the water, the plug/outlet, and hoses. Everything looks fine. But nothing happens.
If your washer doesn't seem to work at all, check these:
No power
Lid switch
No power Check to see whether power is getting to the washing machine. Is it plugged in? Has a fuse blown or is a circuit breaker tripped?
Lid switch If the lid switch is defective, your washer can't spin and may not function at all. The switch is inside the washing machine main housing near the door frame. Often you have to raise or open the top or front of the washer to get to the switch. If it's defective, you need to replace it.
May 05, 2009 | Whirlpool LSR9434PQ Top Load Washer
Kenmore top loading washing machine
check the outlet to make sure that power is getting to the unit. This can easily be done by plugging in a lamp or some small appliance. If you have power at the outlet, it is most likely the lid switch.
The switch is inside the washing machine main housing near the door frame. Some machines have a special lid-switch fuse near the lid switch, inside the control panel. Unless you are familiar with working inside the housing I would call a technician.
Mar 09, 2008 | Kenmore 22422 Top Load Washer
Zanussi aquacycle 1050 not turning on
First try another gadget, a lamp or something on the wall plug, to see if the point is live. Then check your washer plug, could be that the fuse in the plug has blown, check out your washer wire....
Jan 06, 2008 | Zanussi FJS1225W Front Load Washer
Washing Machines Logo
21 people viewed this question
Top Washing Machines Experts
