Question about Dryers
Dryer will not stay on unlessyou keep the on button depressed, even then no heat is generated.
  • 4 more comments
  • rodriguezdc May 02, 2010
    Is this an easy repair?
  • rodriguezdc May 03, 2010
    Is it called a start switch relay? The closest part I found is the power relay. Could excess lint or overheating cause this problem?
    Thanks, i'm concerned because the dryer was heating up quite a bit before it broke. there was a lot of lint in the cabinet. maybe it was a coincidence that the relay went bad. Are you pretty confident that it is the relay?
    If the moisture sensor is bad, would it have the same symptoms as the bad starter relay? my concern is that someone posted on partselect.com that a week after replacing the starter relay the dryer failed again...upon inspection he noted that the control panel was burned so he bought a new dryer. my dryer is fairly new, however we have had a ventilation issue (that i neglected) for quite some time. I am almost positive that the overheating was the culprit. Does that sound more like moisture sensor, relay or both?
    Thank you and God Bless...you have been very helpful.
    This expert was very helpful.
  • 10,319 Answers
The relay conjoining to the start switch is at fault. Replacing it will get this dryer going again
Posted on May 02, 2010
  • 3 more comments
  • frank thomas wilson
    frank thomas wilson May 03, 2010
    For some, yes
    I would GOOGLE the model number and the name of your dryer to see is a free service manual can be downloaded to help you through this repair
    Power relay is the same name for it. Lint will not harn it unless the lint was wet or moist that will short it out
    Since you have this apart replace the moister sensor as well. It may have degraded somewhat since the relay is out. The moister sensor is a safeguard item as well as a auto shut off switch when the clothes are dry. If the vents get full of lint the sensor will shut down the heat as well to prevent a fire to start inside of it
    That is why I suggested to replace both items for most dryers are neglected. If one item is replaced the other may go bad very soon also. Whe I first started to repair appliances my old boss told me to replace what was needed only. About half of the repairs lasted only a month or so when the customers called back stating the repairs were not done correctly. They were done correctly by my bosses directions although after 4 years working under him I found he knew other items were ready to go out as well. He would save parts and try to rebuild them as well and have me install then as new. After finding out what he was doing I quit and started my own business. I rather have happy customers that call me back with friendly questions and work for me than complaining how shabby my repairs work was done.
    Replacing both items will do the trick and you will save a lot of cash instead of calling a repair man out
    Take care now
    Your very welcome!
    God's speed to you on your repairs
    Frank
I have a Kohler Confidant 5, model 5ckm21 generator in my RV, serial # 326827, spec# 101228. It worked fine one evening and the next day it wouldnt stay started unless the start button stays depresse
no 14vac coming from generator to control board.--cause can be regulator board on end of generator---dirty brushes or worn out brushes==b1 and b2 winding open that outputs the 14vac--my problem was blown regulator board
Dec 05, 2012 | Kohler Electrical Supplies
Clothes Dryer won't stay on after switch is depressed.
some of them dryers have a switch other than the push button located behind the console. it also has an identical heat switch beside it. if that holding switch is bad it will not stay running. of the two identical switches the run switch is on the left. good kuck.
Jan 20, 2010 | Kenmore Dryers
Dryer will not stay on after pushing start button
There can be many reasons why your dryer2_bing.gif will not turn...
This tip that I wrote will help you to figure out what is happening...
Dryer2_bing.gif Repair - The Dryer2_bing.gif is not Turning
http://www.fixya.com/support/r4422207-dryer_repair_dryer_not_turning
Dryer2_bing.gif Repair ? The dryer2_bing.gif will not start
http://www.fixya.com/support/r4460438-dryer_repair_dryer_will_not_start
heatman101
Dec 21, 2009 | Kenmore 63942 Dryer
My Kenmoor dryer will not start. When pushing the
send model number, an even heat board would cause this,or you can unplug dryer and open console on top and see if the even heat board is in there,check it for burn marks,there should be a tech sheet in the console that will help you out but put it back,if you have to call someone in to work on your dryer and the tech sheet is gone they might not be able to help you, there is a relay part 3405281 could be in there,there are actually two of them,there is a heat relay and a motor relay,you can change them out as they are the same part and see if motor stays running,if so change out the motor relay, but i need model number to look up your dryer
Dec 10, 2009 | Kenmore Dryers
Will not stay started unless the start button is depressed
THERE ARE TWO RELAYS INSIDE THE CONTROL PANEL. ONE IS FOR THE HEAT, AND THE OTHER FOR THE MOTOR. SWAP THE TWO, IF THE MOTOR STAYS RUNNING AND THE HEAT DOESN'T COME ON, THEN YOU KNOW YOU HAVE A BAD RELAY
BOYNISMO@YAHOO.COM OR 714-334-1998
Nov 30, 2009 | Kenmore 62602 Electric Dryer
Dryer won't stay on. I press the start button and it won't work unless I keep the button depressed manually
Hi, your start push button is malfunctioning. simply replacing this start switch will fix your issue.
May 20, 2009 | Kenmore Elite Oasis 6808 Electric Dryer
90 series will not stay running or heat
DO NOT KEEP THE BUTTON PUSHED IN AND RUN IT...It's the motor relay and the even heat board in the console. By keeping the button in, you're bypasssing a safety feature and could cause fire. It won't heat like that anyway. Repl. the relay witht the small blue wires and the board in the console and you should be fine.
Jan 30, 2009 | Kenmore 659 Electric Dryer
Must hold start button to run. no heat
disconnect power and remove lid. Test the door switch w a volt meter do so opening and closing the door not pushing switch if circuit stays open try pushing switch with finger. If pushing closes circuit then adjust switch.If circuit stays open replace switch. If switch operates with no problems then it is the motor. Check all connections and vacuum lint from motor
How old is this dryer?
Dec 30, 2008 | Kenmore Dryers
Whirlpool dryer will not stay on, no heat, and timer acts weird
sounds like the motor or the even heat board is out i would say the even heat board is more likely
Dec 09, 2008 | Kenmore 62602 Electric Dryer
Dryer shuts off when releasing start button. Will run while pressing down start button, but no heat is generated. Sears repair man wanted to replace Even Heat Control Board for $350. I bought the part...
replace the motor, as you are holding in the start button you are making the dryer run in the start winding of the motor, it is designed to only stay in this winding untill the centrifigual switch on the motor automaticaily switches it to the run winding, when the motor switch knows that it is using the run winding it closes the motor switch contact for the heater to come on, replace the motor
Apr 12, 2008 | Kenmore 63942 Dryer
Dryers Logo
Top Dryers Experts
