Question about Dryers
Grinding sounds coming from the back. - Dryers
  • 10,319 Answers
The belt tensioner has a roller with a bearing on it. The bearing is dry and making this sound. Replace the roller and belt. The bearing will come with the roller
Posted on May 02, 2010
Not cooling refrig or freezer - all i did was pull the fridge away from the wall to paint and it stopped working - lights come on - i hear it grinding every so often but not cooling - only 5 years old
it cycles on its overload protector, that is why you hear grinding sound so often,check the motor or compressor if it is too hot, if it is,means your compressor is tripping intermittently,it might be a weak protector,if not it is the motor compressor,on the other hand where is the source of the grinding sound sir? if it is coming from the bottom or at the back it is from the motor, if the grinding sound is coming from inside, the evaporator fan is partially touching those melted ice or something, Those problem should be done or service by a qualified technician sir, check for the nearest service center in your area
Mar 19, 2010 | Refrigerators
Squealing or clicking sound and then next day grinding sound louder when you take foot off accelerator clicking sounds from right side grinding underneath 2002 grand cherokee
Squealing usually indicates that the brakes are in need of replacement. There is a small piece of metal that as the brake pads wear comes in contact with the metal rotor. When the pads get close to being worn away the tab touches the rotor and it squeals. The tab can also click.
When the pads are worn away completely the metal backing comes in contact with the rotor and it grinds. Grinding is bad. It means the car's brakes are metal to metal. This will cause damage to the rotors resulting in an even more costly brake job.
You should have it taken care of ASAP.
I hope this helps.
Oct 16, 2009 | 2002 Jeep Grand Cherokee
Grinding coming from Rear Wheel Driver side when I drive ...
its the brakesd you should change the pads from the back and for safety the ones int he front.good luck
Sep 17, 2009 | 2001 Mitsubishi Eclipse
Front end sqeek and grinding sound .goes away when i jack up the car check everything looks fine and tight but comes back in a few days thought it might be the shocks?
shocks wouldntt grind, grinding sound usually is the front wheel drive at wheels, check rubber boots for tears,remove front wheels, inspect gears.plz rate -bozcro
Sep 16, 2009 | 2001 Chrysler Sebring
There's still grinding like sound coming from the rotors.?
Is it a scraping sound or a grinding sound? Double check that everything is good on the brakes and the shields aren't draggin on the rotors.
Apr 07, 2009 | 2005 Chevrolet Impala
Grinding sound from trany or other
Check the brake backing plate, it may be touching, then while you have the wheel off check the CV joints for torn rubber boots or any excessive play..
Aug 18, 2008 | 2003 Chevrolet Malibu
Washer LAT9206BAE
the agitator shaft has come loose from the transmission. when you pushed it back down it probably didn't seat properly, thats why the grinding sound. you need a new transmission
Nov 14, 2007 | Washing Machines
Open Questions:
Dryers Logo
Top Dryers Experts
Dan Webster
Dan Webster
