Question about Microwave Ovens
Hi I have just plugged in my beko washingmachine . nothing happens .it doesnt turn on, I have checked the fuse, plug and socket. whats wrong with it?
  • 10,319 Answers
The timer that you set is at fault. If it will not start in any mode replace it
Posted on May 02, 2010
Plugged it in an nothing happened . I checked the fuse , and it was fine . what could be wrong with it ?
What fuse did you check? The main House fuse?
The internal electronics probably has it's own fuse or the circuitry has gone kaput. You will need a tech to look at it with a multimeter to see where the AC electric input comes to a halt.
Apr 02, 2015 | In Microwave Ovens
This is samsung smh9207. No power. Checked the fuse, unplug and plugged again. Nothing happens. The microwave has been used for 4 months. What could be wrong?
Here is a tip that will help you to figure out what is wrong with yourMicrowave Oven....
Microwave Oven Basic Troubleshooting Tips
heatman101 ;'
Apr 14, 2011 | Microwave Ovens
Cooker is not working checked fuse and plug socket was working then just stopped
heatman101
Sep 28, 2010 | Microwave Ovens
I have taken the microwave oven out of the box. I have plug the equipment into the mains supply. Absolutely nothing happens. Mains supply o.K. Main 13 amp fuse O.K. Is it me or is this equipment u.s.
If your sure that the socket you are plugging it in to (try something alse in it) is ok and the fuse in the microwave plug is ok and the microwave is not powering up at all then take it back to where you bought it for an exchange.
hope this helps.
Iain
Oct 15, 2009 | Microwave Ovens
Try to start, no respond, no light digital number...No sound. Already check Electric plug is fine.
microwave ovens have a unique problem that shows itself once in a while .. they cant afford to put in a transformer thats big enough to handle two cycles of input power that have the same phase.. there is circuitry in there that tries to make sure that doesnt happen .. it remembers the "turn off" phase and makes sure the next time its turned on it uses the opposite phase.. this is to prevent transformer saturation .. this is kinda technical but anyhow its going to mess up once in a while .. the results will often be a tripped main circuit breaker ... you can check this (if the microwave plugs in) by simply plugging in a lamp to the same outlet .. if it lights then the circuit breaker is ok .. if it doesnt then thats your problem .. find your fuse box and look for a circuit breaker that is in a different postition than the rest .. you have to switch that off then back on again to reset it .. if power is ok and it still doesnt work then you may have a blown fuse inside the microwave ... thats not a place you want to be unless you really know what your are doing .. the voltage and current inside is enough to quickly kill ..
if you or someone else knows how to work with this dangerous stuff .. then they would first make sure its unplugged for at least 5 min .. then look for a bad fuse or fusable resister in the low voltage power supply (usually 12 volts) .. that supplies power to the computer and display .. nothing else will work if the computer is not working .. there is also a thermal fuse inside that will trip if the thing gets toooo hot .. that can happen if air flow is blocked or you try to use the oven with nothing in it ...
Sep 04, 2009 | Sharp Microwave Ovens
Hi Yes I have a Whirlpool MIcrowave Oven Model # MH7140XFB-1 And It was working fine this morning I went to use it this afternoon and the panel is not working no lights work nothing the fan under neath...
check for a blown ceramic fuse behind the panel. If the fuse is dark in color it is probly bad. you can get one at radio shack store or on line
Apr 16, 2009 | Microwave Ovens
Power outage now microwave won't work
Most likely blew internal fuse. Pull the top/side cover off and check the line fuse. It should be behind the control panel in that area.
Nov 08, 2008 | Kenmore 62622 Microwave Oven
It just seemed to turn off
yes,unplug the unit ,remove the outer case ,follow the plug inside to the fuse ,read the amperage ,test the fuse with an ohm meter should read shot or 0 ohms if not replace whit same type and amperage,
Dec 01, 2007 | Emerson MW8168B Microwave Oven
Microwave Ovens Logo
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
