Question about Hoover U6437-900 / U6439-900 Windtunnel Bagged Upright Vacuum
Where does the piece go to rise and lower the brush
  • 438 Answers
HI There,
The part that raises and lowers the height adjustment goes underneath of the hood on the vacuum cleaner, and is held on by the carpet height adjustment know on the top of the hood.
I've done a repair below that explains how to get the hood off of the roller brush housing, and replace the knob next to it which is the rug/floor selector knob which is the one right next to the height adjustment part. The repair on your machine will be the exact same process however. Hope this helped you:
If you've already changed the belts and the machine still won't run, it can really be only a few things.
The first thing you should check to make sure that the roller brush is good. You may do this by removing the bottom plate, and then taking the roller brush out of the vacuumwhere does the piece go to rise and lower the - 2_bing.gif. Hold the bar using just your fingertips on the very ends of the brush on the bearing caps. With just holding the bearing caps with your fingers, use your thumbs to try and spin the bar. Does it spin freely without any resistance? If no, then you'll need to replace the roller brush. Here's a direct link to the exact roller brush for your Hoover Windtunnel Self-Propelled:
Hoover Windtunnel Agitator Brush Part # 48414069
If the roller brush spins freely several times on each spin, then your machine may possibly have a bad Rug / Floor actuator arm. This part controls the internal pulley that stops the roller brush when you turn it from carpet to floor mode.
I'm guessing that this is probably a more likely cause of your brushes not spinning. Here's how you can check this part:
Step 1. Make sure that the vacuum is unplugged. Turn the machine upside down so that the brushes are facing upwards. I find the easiest way to do this is to put the brushes on top of a counter top or work bench with the handle of the vacuum resting on the floor. Remove the four screws that hold the bottom plate in place. Remove the bottom plate, both belts and then the roller brush from the machine:
Step 2. There are 3 screws that hold the top brush cover in place that need to be removed. On the right side the screw is down below the transmission to the right. There's also a screw in the agitator tray, in the middle that needs to be removed. NOTE: This small screw in the agitator tray is only present on some models, you's may or may not have this little screw, but all models will have all other screws circled. I have circled both screws that neewhere does the piece go to rise and lower the - a2c6df2.jpgoved:
The screws on the left side that need to be removed are also circled. One screw holds the upper brush cover on, and the other two screws secure the hose in placewhere does the piece go to rise and lower the - e00d104.jpgl three screws as well as the transparent hose cover:
Step 3. After all of these screws have been removed, there are two clips that are the last things holding the top brush cover onto the vacuum. Use a flat head screwdriver to push these clips off on both the left and right sides. The where does the piece go to rise and lower the - 2_bing.gif clip is near the pulley that the flat where does the piece go to rise and lower the - b39ff0c.jpgc="http://i.fixya.net/uploads/images/2_bing.gif" alt="2_bing.gif" class="h_mi" /> rides on, and the left side clip is next to the internal hose.
Step 4. Once both of these clips have been pushed so the unhook from the lower agitator housing, remove the top cover. On the top you'll see two selector knows, one for the height adjustment, the other where does the piece go to rise and lower the - 305a968.jpgls the rug / floor setting. Turn the cover over and look at the opposite side of the knob that controls the rug / floor selector. There should be an arm that extends out that looks like this:
Sometimes this arm will break off, which will prevent the actuator arm from activating the rug carpet setting. The machine basically will always be set to bare surface floor mode. Is this arm broken off on ywhere does the piece go to rise and lower the - a638606.jpgs, then here's how you can remove it from the machine.
Take your flathead screw driver, and place it underneath of the of selector knob on the top of the cover. Simply lightly pry upwards to separate the knob from the arm underneath:
Replace the actuator arm with a new one and see if this fixed your problem. If this was not the problem, there's really only one other possible thing it could be, but I rarely see this go bad. Please let me know if this fixed your problem, or if it is something else wrong. I'll be happy to then walk you through the last remaining possible problem.
I really hope that this repair was helpful to you. If you did find it to be helpful, help other Fixya users with the same problem find this repair by rating it helpful. You can do this by clicking on the thumbs up icons in the top of the repair.
Thank you very much,
Chris J.
Posted on May 03, 2010
  • studelska Feb 01, 2011
    I used this disassembly information to get to the metal band (on the right side, when facing the back) that loops over a portion of the top plastic housing. Tightening the two screws that affix this to the bottom vacuum housing restored the ability to position the arm of the vacuum in any vertical position without flopping.
Floor piece will not rise and lower to clean floor
Most mechanical problems with vacuum cleaners are caused by ingress of dirt causing seizure of moving parts.
Aug 17, 2014 | Vacuums
My dyson DC50 smells when hoovering
many things can make it smell bad wash filter top and lower in hot soapy water and rise well and dry well in sun
wash bin and all it's parts in hot soapy water and dry well
clean brush roll and check for any bad smells in head
could be from motor over heating or near to failing if above does not get rid of smell i would say it's the motor
May 31, 2014 | Dyson DC17 Animal Bagless Upright Cyclonic...
How do i replace the belt on my hover
lower handle to floor and flip entire unit over. In the bottom near the brush, there are 2 levers that hold the cover on. flip both levers and pull up on cover. It will come out of the 2 wire holders that hold down the 2 front tabs.With the cover removed you can easily access the brush. Firmly grasp 1 side of the brush and pull straight up. This may take a lot of force as the brush may have been seated for a long time. Pull both sides out and clean the area underneath the brush. Also make sure nothing is wrapped around the brush or motor.
After cleaning you're ready to install new belt. Place new belt around brush. After pushing brush through the new belt, with belt loosely around brush slide brush back into housing 1 side at a time. The brush fits in very tightly. The ends have 2 pieces of metal that act as springs, these are installed facing the top. Make sure the brush is pushed down tightly toward the bottom or the cover will not fit right. Once brush is in stretch belt around motor tip. Replace cover by placing the 2 tips into the wire clips and close. Flip the latches closed and turn machine over. Lift handle and you're good to go. You have now completed the worlds longest instructions for a vacuum belt...ever!
Jun 11, 2012 | Vacuums
The rotating brush is stopping
Two things you can do. 1- Remove the brush as if you were going to change the drive belt for it. Clean the brush as best you can and spray some WD40 on the hard rubber/plastic pieces at both ends of the brush. Rotate the pieces to work the WD40 into the space between the pieces and the brush axle. 2- If you have one available, as long as the brush is off, change the belt.
This should get your unit back in operation. If you find this solution helpful, I would appreciate a Thumbs Up from you. Thank you. Paul
Oct 08, 2010 | Dyson DC07 Animal Bagless Upright Cyclonic...
Where is the belt located?
The "belt" is normally the drive device that turns the beater brush found on the bottom front of the vacuum. Its purpose is to beat the rug and cause dirt and debris to rise up from the carpeting and be sucked into the vacuum. If the belt is missing, you may not see it. If the belt is in place, it will loop around the beater brush and back to a drive motor. Since belts can break on a regular basis any covers over it should be easy to remove via small slide levers or at most by removing a few screws from the bottom of the vacuum. The new belt must be attached properly in order for the brush to move in the correct direction. If you are going to replace the belt it is probably a good time to clean the beater brush and lubricate the end pieces of the brush with some WD40 as well.
Sep 12, 2010 | Riccar 8955 Upright Vacuum
Sebo X4 Extra brush light remains on despite changing brush, any solutions?
Sorry you've had to wait so long for a reply. Perhaps you no longer need help, but here goes anyway. Must confess I'm not certain about this, but my guess is that the automatic height adjust mechanism (let's call it the HAM for convenience) isn't working properly. The HAM works by sensing the drag of the brush roll against the carpet, and raising or lowering the front of the machine as necessary to maintain constant drag. So first you need to check the HAM, as follows: with the handle in the locked upright position, switch on and wait for a few seconds (there may or may not be any signal from the green UP or DOWN lights). Then, still switched on, lower the handle to the normal operating position and check that the green DOWN light comes on. Wait until the DOWN light goes off and then return the handle to fully upright (switched on all the time). When fully upright the UP light should come on for a few seconds and you may be able to see the handle tilt backwards as the front of the machine rises. If this is all working properly, we need to look elsewhere for a solution. The next thing I would look for is for a broken belt. Just turn the machine over while it's running and look to see that the brush is rotating (keeping fingers and clothing well clear, of course). Sebo belts usually last 15 years or more, but breakages are not unknown.
I realise this may not exactly solve your problem, but it should give you something to work on. If you need more help, post a reply here, saying what you've found so far, and I'll try to be more specific.
May 09, 2010 | Sebo X4 Bagged Upright Vacuum
Dyson curved piece at bottom keeps falling off how to reinstall?
Call me, doug in Riverside cali, pretty handy just rebuilt my stage 3 on my animal. I am incredibly gifted. 951-316-7071
Sep 26, 2008 | Dyson DC17 Animal Bagless Upright Cyclonic...
Cannot find replacement piece for the scrub brushes.
The part number for this brush block is 48437022, most repair shops will have or can get it for you.
Jan 22, 2008 | Hoover F5866-900 SteamVac Deluxe Wet/Dry...
ASSEMBLING BRUSH HOLDER TO STAY IN PLACE
try thehooverstore this online site has your machine with exploded diagrams. you should be able to figure out how it goes together
Apr 29, 2007 | Hoover Floormate H3000 Upright Wet/Dry...
Hoover U6437-900 / U6439-900 Windtunnel Bagged Upright Vacuum Logo
818 people viewed this question
Top Hoover Vacuums Experts
Gerry Harvey
Gerry Harvey
Are you a Hoover Vacuum Expert? Answer questions, earn points and help others
