Question about Craftsman 8.50 Torque Rating Dual Rotating Tine Tiller
My Sears rototiller will only start when I put gas directly in the carberator and then stalls out.
    Sniper:
  • 53 Answers
Sounds like you need to clean or replace your fuel lines. (Tubing/hoses) that model is pretty cut and dry with how its set up to pull start. Or maybe the gas in the tank is OLD? Try running a tube from a small can of fresh gas, to the carb. If it runs that's your problem!
Posted on May 06, 2010
My powermate rear tine tiller is getting gas into the oil it will start and run as long as im am putting fuel into the carberator once i stop putting fuel the engine stops what is the problem. the til
This sounds like the float is sticking in the carb causing it to flood . You need to take the carb off and clean it and put a kit in adjusting the float per the instructions
Jun 27, 2014 | Powermate 18 in. 196 cc 4-Cycle Rear-Tine...
1992 dakota v6 stalled while driving, won't start and not firing ?
Crank sensor.should be on back side of engine on passenger side were bellhousing is. controls spark and fuel pump.
Dec 06, 2012 | Cars & Trucks
Starts to stall when stepping on gas
if it has a carberator on it the little pump that injects gas when you step on it is bad and needs a new one.
Feb 22, 2011 | 1984 Ford F 250
MOWER ONLY RUN WHEN U PUT GAS IN CAB WANT START
Ok, so your not getting gas to carberator, or thru the carberator. Disconnect gas line from carberator, if gas is present thru fuel line, you have a carberator problem. Your rather meger with your mower information so this is all i can tell you. Wish i could be of more help.
May 29, 2010 | Husqvarna Lawn Tractor 48" Deck, 23 Hp,...
Sears Push Mower 6.0HP
Sounds like your Carberator is plugged up. Take out the main jet and clean it and be sure needle is not stuck and not allowing gas into the carb.
May 08, 2010 | Garden
I left gas/oil mixture in my Craftsman weed wacker for too long and now it won't start. Is there a simple way to fix it? I assume the carburator is crudded up. Thanks!
I add fuel stabilizer if fuel is still in mowers, etc. for the winter since it isn't easy to totally drain it.
Just a day ago, our rototiller was limbered up for the garden and I shot 'starter fluid' (ether) into the air intake before even trying it and it fired on the second pull. You can buy the stuff at any auto parts store and even dollar stores.
Mar 20, 2010 | Craftsman 25cc Gas Line Trimmer
My 89 toyota pickup 3.0 stalls unless i hold down the gas pedel until it gets warm then it runs fine. i changed the fuel filter and the mass air flow and checked the vaccum hoses for leaks.. Still nothing
hello. Your carberator injectors are partially gummed up. go to any auto parts store and get two cans of a product call seafoam. Follow the directions on the can regarding how much you use per gallon of gas in the tank. After you have run some seafoam through the carberator it will solve your problem.
Nov 25, 2009 | 1989 Toyota Pickup SR5
Sears rear tine rototiller 32-29978 manual
If you find one please let me know as I have the same tiller and no manual.
May 02, 2009 | Craftsman Garden
Craftsman 8.50 Torque Rating  Dual Rotating Tine Tiller Logo
420 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Jim Parker
Jim Parker
Dennis Key
Dennis Key
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
