Question about Epson Stylus 2200 InkJet Photo Printer
EPSON 2200 - Waste Ink Pad Replacement
Can I replace the waste ink pads in the epson 2200 myself?
On other forums, other people have mentioned washing the waste ink pads under cold water and letting them dry out and then putting them back in.
How do I get them out?!
I've reset the counter, but am worried that the waste ink pads will overflow if I keep printing.
thanks.
  • 5 Answers
You can replace the pads yourself.... I wouldn't really mess with it though. There are other ways Google search "Waste Ink Epson 2200" to see how to setup an external tank.. I have mine setup this way and its been no problem.... If you're set on taking them out remove the screws from the sides and middle and the bottom will drop away and reveal the pads.
Posted on Apr 16, 2009
My printer is epson tx650.the problomis that it say 'the printer's ink pad is at the end of their service life'. please assist me with the solution.says RAKITA
Sadly the other solution is the usual corporate party line regarding "Parts at the end of their service life" and is intended to encourage printer owners to purchase new printers.
The reality is quite different.. Epson printer are generally capable of upwards of 3 to 10 years or service with minimal care unless the printer is being hammered 24/7 with almost constant printing, which is very unlikely.
Waste pads however are an achilles heel that do need some form of action to either replace or work-around to resolve.
The options available are either:
1. Go to a service centre where it is indeed prohibitively expensive to have the printer disassembled to replace the pads and have the waste counter reset.
OR..
2. Get an external waste ink kit to redirect any waste ink to an external tank (it doesn't remove the current pad contents) and obtain the relevant tool (either a compatible AdjProg service program) or WICReset tool with a key (one needed per reset) so you can reset the printers internal waste ink counter.
The cost of the latter option is around 20-25(GPB) total (including shipping) so compared to the tooth sucking Epson Customer "Care" option it's not exactly rocket science as to which is more cost effective.
Please ignore the rubbish about other parts being near the end of their service life... About the only other thing to note is that the printer gears might need a little grease but beyond that and flimsy plastic paper guides the printer can easily last 5 years with a little care.
Mar 05, 2011 | Epson Stylus Photo RX700 All-In-One InkJet...
I have a problem with my printer epson stylus C90. may i know what todo when parts of my printer are near the end of their life service.?how can i fix it?
It means waste ink pad full or nearly full. Reset waste ink counter using SSC ver 4.30. Find at indoreset.blogspot.com. Don' forget to replace pad, washing or extend outlite pipe to outside of printer.
Jul 23, 2009 | Epson Office Equipment & Supplies
Epson stylus CX5500 series, 2 red lights are blinking and we can not print or copy.
you can download a reseter just to be sure you also replace or wash the ink pad... replacing or washing the pad is difficeult bcoz you should dismantelle the cx5500 coplettely you should have an advance technician skills to do it...
Jul 21, 2009 | Epson Office Equipment & Supplies
Error message saying parts have come to the end of their life. Does this mean the whole printer needs replacing
It mean waste ink pad full. Epson stop to prin to prevent waste ink flow from pad to other (power supply is nearest part). Replace pad, or wash pad. Or just extend outlet pipe to outside of printer. You must reset waste ink counter to make printer work again. Use SSC utility to rset it. Find at indoreset.blogspot.com.
Jun 30, 2009 | Epson Stylus C46 InkJet Printer
Printer won't printer as message says parts are
Part are end life cycle : waste ink pad full. Need to reset waste ink counter. SSc ver 4.3 support RX 620 and 640. U can try using printer model RX 640. Menu Protection Counter, Show current value for checking. Reset protection counter. Or Try to find RX630 adjusment at indoreset,blogspot.com. Don't forget to replace or wash the pad. Or extend outlet waste ink pipe to outside.
Jun 28, 2009 | Epson RX620 All-In-One InkJet Photo...
I have a warning that my ink pad is saturated and needs replacing contack dealer for assistance (help)
Ink means pad for waste ink nearly full. Epson program read and count all waste ink from head cleaning and ink charge. Next, you need reset waste ink counter, and replace or washing pad. You can extend outlet pipe to outside of printer, so next time you don't need replace pad again.
Jun 27, 2009 | Epson Printer
Need to replace ink pads for epson stylus rx620.printer. Where to buy and how to replace?
You don't need to buy the pad. Just wash with hot water. Is there a message to replace waste ink pad?. You need to reset waste ink counter. Use SSC utility to reset it. Extend outlet pipe to outside. You don't need clean pad again. If you wish to wash or replace pad, you must open case and diasemble all mechanics. Find SSC at indoreset.blogspot.com. And printer diagram at printersiam.com
Jun 21, 2009 | Epson Stylus C86 InkJet Printer
Need to replace waste ink pad epson C88
open up the printer and remove the waste hose to the out side of the printer and into a bottle.
Mar 25, 2009 | Epson Office Equipment & Supplies
Need replacement waste ink pad
Hi...
so bye bye waste pad... can't find any replacements but this is my recommendation for you a waste tank... It's what I did on my 2 Epson Printers... Click the link to get the idea...
waste tank
Or you can use some tissue papers to replace what was thrown away.
Happy Fixya...
Feb 28, 2009 | Epson Stylus Photo 925 InkJet Printer
Waste ink pad
to Reset Waste Ink Counter
  • RUN AdjProg.exe file Epson C90
  • choose Particular adjustment mode
  • select waste Ink pad counter
  • Klikinitialization
That’ all!
Jun 01, 2008 | Epson AcuLaser C900 Printer
Epson Stylus 2200 InkJet Photo Printer Logo
2,836 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
