Question about ASUS Premium Vista M2N32-SLI (M2N32-SLI PREMIUM VISTA) Motherboard
Motherboard will not power on. Onboard LED
Motherboard will not power on. Onboard LED blinks. Worked fine then won't turn on.
  • 267 Answers
Did you check power supply? are there any beeps during post? is the fan running on the processor? did you try removing everything and reassembling to see if it works. let me know and good luck
Posted on May 02, 2010
Testimonial: "I had figured it out but you nailed it. One dead pwr supply. Thanks!"
KDL-52w4100 won't turn on and LED blinks 6 times
Bus clock and/or data lines low at power on. 6 blinks of standby light denotes this. Actually, it should be a motherboard problem. Your TV need a thorough checkup before confirmation. If you wish to get more details about the blinking codes to Sony TVs, check this link.
Feb 19, 2013 | Sony BRAVIA KDL-52W4100 52 in. LCD HDTV
Cant get the power to turn on,worked fine last night, it got unplugged, this morning plugged in, won't turn on and the power button just flashse
Flashing is either an error code or the set trying to boot up--some of the Mitsubishi sets if power removed will blink for a minute and then stop--then the set can be turned on.
a model number?
Apr 28, 2012 | Mitsubishi Televison & Video
What does the red light mean next to the power button?
The red light next to the power button is usuall the hard drive led which should blink every time the hard drive is in use, there is normally a green or yellow light for the power that shoukld stay on constant when the computer is on.
Feb 09, 2010 | Intel Compaq EVO D500 (RBMDTCPQP42400) PC...
Acer aspire 4930 wont turn on
If the power LED on the Notebook is blinking but not turning ON then the issue is related to the power supply unit and service is required.
Nov 03, 2009 | Acer Aspire 4930-6862 Laptop
I just bought a used (or refurbished) MSI 845GE MAX MOTHERBOARD (478 pin, etc) and plugged in my Radeon 9550XL AGP 8x (4x compatible) card, (2) 512MB Sticks of Mushkin DDR2 (PC3200) RAM, Random IED HD, DVD...
Did you try another graphics card? If this motherboard does not have onboard graphics then try another card. AGP slots go bad sometimes too. I've had that happen.
Sep 18, 2009 | MSI 845GE Max-L Motherboard
Computer will not turn on
  • Blinking Amber/yellow: Initial state of LED at power up.
    Indicates system has power, but the POWER_GOOD signal is not yet active.
    If the hard drive LED is off, it is probable that the power supply needs to be replaced.
    If the hard drive LED is on, it is probable that an onboard regulator or VRM has failed.
Apr 28, 2009 | Dell Dimension 4600 PC Desktop
Ecs p4m800 m7 no display
On board video will likely be disabled if you plug in another video card.
Newer video cards require a connection from the power supply to provide additional power not available on the PCI bus to drive the GPU. It is possible that your 350W power supply does not have enough juice, or the rail is bad.
First guess, check the video card for a power connector. Second, check the power supply. Lastly, if you remove the PCI video card, onboard video will likely work again.
Good luck.
Mar 30, 2009 | EliteGroup ECS P4M800-M7(3.1) LGA775 ALL...
Cannot turn it ON
did u ensemble this mobo yourself into a case if so did you connect all the "power up" cables the right way onto the board and if it was working already check ur powersupply
Jun 15, 2008 | ASUS P5S800-VM Motherboard
Booting problem
the blinking led on the keyboard suggests some probems with the power supply ...
Do u hear any beeps from the comp ?
U can try to disasamble everything and reasamble them... also see that u have a propper isolation between the motherboard and the case. And if u can messure the power supply;'s parrameters
Mar 10, 2008 | Intel D915GAG Socket 775 Motherboard -...
Hello!!
are you using an expanded vifeo card? if you are using the, temporarily remove this then use the onboard video card. because the problem is in your video card. if the onboard functioned then try to install other video card
Dec 05, 2007 | EliteGroup P4VXMS (P4VXMS-R) Motherboard
ASUS Premium Vista M2N32-SLI (M2N32-SLI PREMIUM VISTA) Motherboard Logo
271 people viewed this question
Top ASUS Computers & Internet Experts
David
David
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
