Question about Miele 24 in. G646SC Plus Free-Standing Dishwasher
I HAVE A MIELE G646 SC DISH WASHER AND IT KEEPS LEAKING WATER INTO THE LOWER TRAY AND CUTTING OUT BECAUSE THE FLOOD SYSTEM KICKS IN.I HAVE THE MACHINE IN THE GARAGE WORKING UP ON TWO WORK MATE WITH THE UNDER TRAY OFF FOR THE FIRST FEW CYCLES THERE WAS NO LEAKING THEN WE FOUND IT LEAKING DOWN THE FILL PIPE.THE WATER IS LEAKING FROM AROUND THE AREA THE FILL PIPE FITS TO THE WATER SOFTNER BUT NOT ALL THE TIME.AN ENGINEER FROM MIELE SUGESTED IT COULD BE THE VENT INSIDE THE SIDE OF THE MACHINE BUT EVEN AFTER HAVING UNDONE THIS THE WATER STILL LEAKED OUT .THE STRANGE THING IS ITS A WHILE AFTER THE MACHINE HAS BEEN RUN AND THEN IT DRYS UP.I CAN'T SEE UP THE SIDE TO BE ANY MORE HELP .CAN ANY ONE SUGEST WHAT IT MAY BE .
  • 14 Answers
Have you made sure the water sofener filler neck locknut is tight to the bottom of the dishwasher?
i have had experience with one machine where spilled salt was not rinsed away after the softener was filled and this corroded a very small pin ***** sized hole near the filler neck
Posted on Aug 26, 2009
Miele G1182 dishwasher not working
Any water comming in to the dish washer area?? If not check the inlet water valve, they get clogged with sand from the water supply. They can also clog open, in which case the dishwasher will flood the floor with water afer about 3 to 4 imins of use.
Dec 19, 2012 | Miele Dishwashers
Miele dishwasher G646 SC plus water pump
I would suggest any appliance repair shop or appliance retail store should be able to order one in for you
Sep 06, 2012 | Miele Dishwashers
MIELE G646 Wonderful machine, but now 10 years old ! I noticed a small leak on the floor which appeared to be coming from the bottom of the door, on both sides. This was noticed after a programmed wash...
Clean gasket with clorox to remove any funk, and apply vasoline to gasket to improve seal. If you still have water leaking, you will need to replace the seal on the dishwasher. Should be able to order from an appliance parts dealer, or they may provide a univeral gasket that would fit your machine.
Jan 07, 2012 | Dishwashers
Soap dispenser on my Miele G646 Sci Plus doesn't open every time. Have cleaned the washer, run a full hot cycle with the washer empty; I always ensure the dish and surrounding is dry before inserting...
There are three common problems that cause the Soap Dispenser or Cup not toopen. I have a tip that will explain these problems in detail....
Dishwasher Repair Problem Detergent Cup does not Open
heatman101
Sep 12, 2011 | Dishwashers
Miele G646 SC plus I wish to remove the right hand side panel of my dishwasher. I have managed to do this with the exception of the top of this panel. Does the top surface have to be removed to release...
Hi - if i rember correctly on the sides front top panel is a plastic bung, pop this off and you would see the screws inside - oly problem is most of the later Mieles have torqx screws - anyway if you succeed the gently lift front & push backwards - the top will come off.
But the best ways is to empty the washer of water pull it away from the cabinets disconnect everything.
Lie the silly thing on its back on the bottom will be 4 screws normally this will drop the bottom panels & makes it easier for you to work on the machine.
According to the parts manual this would have a waterproof inlet valve system - typical design for Mieles.
JUST BE CAREFUL - Mieles are excellent machines, try not to damage other components - perhaps the leaks is coming from some other - Miele parts are as costly as the purchase prices.
Hope to see how you get on...
Jun 23, 2011 | Miele 24 in. G646SC Plus Free-Standing...
Miele washer leaking from soap tray (on rinse cycle). Can't figure out what's the problem. Please help.
Remove and clean fully soap tray. if persists could be machine leveling or water pressure too high going in so fast to tray that its unable to cope, in which case try reducing the water pressure. good luck
Feb 10, 2011 | Miele Touchtronic W1213 Front Load Washer
Need to know where to put washing liquid in my Miele G646 SC
Hi most washing liquids go direct inside the machine with your washing, if your using liquid there should be a small liquid device with the bottle that you also use to measure the amount of liquid and place direct into the machine drum.
Jul 19, 2009 | Miele W2203 Front Load Washer
Drain pump keeps running AEG oko favorit
This seems like the anti flood system (polystireen float / micro switch) at the base of the washer is triggered,\. This puts the washer in pump out mode and stops inlet of water via the inlet solinoid. Dry the water on the base and then check for any water leaks. (pipe leak
Aug 29, 2008 | AEG Favorit 50500 Built-in Dishwasher
Miele dishwasher
My O/H found a considerable amount of gunge in the inlet pipe; that seems to have solved it! Thanks for your interest.
Enid
Jul 21, 2008 | Miele 24 in. G646SC Plus Free-Standing...
Miele 24 in. G646SC Plus Free-Standing Dishwasher Logo
306 people viewed this question
Top Miele Dishwashers Experts
mpservices
Mike
Are you a Miele Dishwasher Expert? Answer questions, earn points and help others
