Question about Jugs Small Ball Pitching Machine
I have a two wheel jugs pitching machine. The
I have a two wheel jugs pitching machine. The bottom wheel does not turn when the machine is turned on.
It it something to do with the wiring
Posted on Jan 13, 2014
2 Suggested Answers
  • 60 Answers
SOURCE: my jugs pitching machine is making a rattling
It could possibly be one of the bearings starting to go, is the machine well used or new?
Posted on Nov 05, 2010
Hat is the max speed for a Jugs MVP
I think it's 70 mph not positive but pretty sure
May 06, 2014 | Jugs Mvp Pitching Machine
How to remove wheel from jugs pitching machine
Pretty sure you can take it to a tire shop and get that done
Apr 02, 2014 | Jugs Small Ball Pitching Machine
Blowing fuse on small ball pitching machine
Are you using the right size fuse I would call jugs and ask them what fuse it takes you could also have a wire that's exposed and touching something metal look for that too
Mar 09, 2014 | Jugs Small Ball Pitching Machine
I have a jugs jr pitching machine and can't get the speed to adjust
Take off the cover and make sure the wire is connected to the knob and check the wire maybe it's exposed an not working properly
Mar 03, 2013 | Jugs Small Ball Pitching Machine
Fix jugs pitching machine wheel
What's wrong with it need more info
Mar 31, 2012 | Jugs Small Ball Pitching Machine
Jugs 101 pitching machine , bottom motor will not run ,no current at connector on circuit board
Just had this happen on my machine. Opened up the control box and found center disc capcitor was loose from cold solder joint. However we also found the hot lead for the motor at the wiring block on the circuit board had a cracked solder joint. Simply reheated with solder iron and applied little extra solder and it working again.
Jul 21, 2011 | Jugs Baseball 101 Pitching Machine
I have a 2 wheel combo pitcher and when i drop the ball into the shoot it just bobbles around.It will not throw it
You most likely need to use medium grade sandpaper and use it one the tires. They need to be sanded down in order for the machine to shoot the balls out.
Jun 04, 2011 | Jugs Small Ball Pitching Machine
When in operation the machine itself is out of balance.
pull off the wheel and run the machine. you will be able to see if the hub is out off balance. if it spins true the you have a rim or tire out. this can be fixed by having a tire shop balance it for you or call Jugs and get a complete replacement,tire and rim ,shipped mounted and balanced.
it is very unlikely that the motor shaft is damaged unless it was droped trying to load it into a truck.
it most like;y is the tire and rim that is out
Nov 29, 2010 | Jugs Small Ball Pitching Machine
My jugs pitching machine is making a rattling noice in the motor area
Oct 27, 2010 | Jugs Small Ball Pitching Machine
Jugs Small Ball Pitching Machine Logo
761 people viewed this question
Top Jugs Baseball & Softball Experts
Andrew Taylor
Andrew Taylor
Thomas Perkins
Thomas Perkins
Are you a Jugs Baseball and Softball Expert? Answer questions, earn points and help others
