Question about Poulan Pro 16-Inch 38 cc Anti-Vibration Chainsaw #PP3516AVX
Fuel mix ratio for poulan counter vibe 3400 chain saw; mix ratio
Dontbother 10 replied to my initial inquiry of a mix of 40:1 for the poulan chai saw. After much searching on the internet I I found a site that indicated a mix of 16:1(8oz/gal). To me that seems like a wide difference. Which one should I use?
For the homelite weed trimmer 50:1 is the recommendation. Iwill go with that unless instructed differently.
Anything else you can add will be appreciated.
Thank you
mike
    President:
  • 2,220 Answers
A different site that lists 40:1. http://www.acresinternet.com/cscc.nsf/ed1d619968136da688256af40002b8f7/4a98e23d38cbda9b88256bf80015de57?OpenDocument
Oil mix is controversial. Some think more is better, todays saws run much faster and carbon up much quicker. Ask the mechanics at a local saw shop. I will wager they say 50:1 regardless of the age of the saw. Me too! The Echo site now says use 50:1 regardless of what is printed in the OM. It is your saw Mike; run what you want.
If you have more questions or need additional help please reply below and I will get back to you. HTH & Good Luck.
Lou
Thank You for using FixYa.
Posted on May 03, 2010
Testimonial: "Thank you so much for the prompt replies. I'm going to try the 50:1 mix and see how it runs. Thanks again. Mike"
3400 owners manual states 1/2 pint (16:1) oil to 1 gal.reg. gasoline
1/2 pint (32:1) oil to 2 gal. reg. gasoline
Posted on Dec 19, 2012
My 3400 manual calls for a 32 to 1 mixture. It has worked fine since 1981.....
Posted on Nov 08, 2011
What is the gas/oil mixture for the poulan wild thing chain saw please?
Use a quality 2-cycle air-cooled engine oil. Poulan recommends a good quality 2-cycle air-cooled oil designed to be mixed at a ratio of 40:1 (A 40:1 ratio is obtained by mixing 3.2 onces of oil with 1 gallon of unleaded gasoline). When mixing fuel, follow the instructions printed on the container. Always read and follow the safety rules relating to fuel before fueling your unit.. Be Safe!
Sep 25, 2010 | Poulan Wild Thing 2375 18" Gas Chain Saw...
What is the proper fuel mix for a mcculloch ms1635 chain saw?
between 32:1 and 40:1 - Manufacturer recommends 40:1 Ratio - EXAMPLE: "Mix 3.2 ounces of Poulan 2-cycle air cooled engine oil to one gallon of fresh unleaded gasoline to obtain the recommended 40:1 fuel to oil ratio."
Sep 02, 2010 | McCulloch Garden
What is gas oil ratio for a 16 inch poulan chain saw
Oil Mix Ratio:
The following ratios have been recommended for the last 10-15 years.
Dolmar, Echo, Efco, Homelite, Husqvarna, Jonsered, Makita, Oleo-Mac, Red Max, Ryobi, Shindaiwa, Solo, Spear & Jackson, Stihl & Tanaka; all recommend 50:1.
1 gallon of premium fuel to 2.6 ounces of quality 2-cycle oil.
4 liters of premium fuel to 80 milliliters of quality 2-cycle oil.
McCulloch, Poulan & Wen; recommend 40:1.
1 gallon of premium fuel to 3.2 ounces of quality 2-cycle oil.
4 liters of premium fuel to 100 milliliters of quality 2-cycle oil.
Chinese chainsaws recommend 25:1.
Lou
Aug 13, 2010 | Poulan Wild Thing 2375 18" Gas Chain Saw...
What gas to oil ratio is needed
Oil Mix Ratio:
Lou
Jul 12, 2010 | Poulan Pro Chain Saw 46cc 20"
Is it gas&oil or just gas
Gas & oil my friend, it's a two-stroke motor. You mix the fuel at 22:1 ratio. The bottles come so one bottle goes in a gallon of gas. Hope this helps.
Jun 24, 2010 | Poulan 14Inch Chain Saw Chain 38 952051209
Gas/oil ratio for fuel in a poulan pro 46cc engine
The standard mix for most chain saws is 40:1 that's about 3-1/4 oz per gallon.
Jun 12, 2010 | Poulan Pro Chain Saw 46cc 20"
Fuel mix ratio for poulan counter vibe 3400 chain saw and for a homelite st-145 weed trimmer
Oil Mix Ratio: (last 5-10 years)
If me I would have the Poulan tweaked to run properly on 50:1 and use that in both. It will start easier and take much longer to carbon foul.
Lou
Apr 30, 2010 | Poulan Pro 16-Inch 38 cc Anti-Vibration...
I have inheirited a Poulan counter vibe 3400 it
Go to m-and-d.com then parts diagram then illustrated parts online then parts look up then select oem poulan then poulan then saw then look at list of models you will find 3400. Have worked on one or two of the 3400 and they seem to be a fairly good saw for home use.
Apr 07, 2009 | Poulan Garden
Need fuel/oil mixture ratio for a poulan 3400 chain saw. Much obliged!!!!
Hi, fuel/oil mixture is 40:1 for Poulan. Hope this helps.
Mar 01, 2009 | Poulan Garden
Poulan Pro 16-Inch 38 cc Anti-Vibration Chainsaw #PP3516AVX Logo
2,205 people viewed this question
Top Poulan Garden Experts
Roland W VanLue
Roland W VanLue
Phil Walker
Phil Walker
Are you a Poulan Garden Expert? Answer questions, earn points and help others
