Fan will run with heater, not with AC - Heating & Cooling
    Novelist:
  • 135 Answers
Is the wire at the thermostat connected to the "G" terminal? The fan in the heating mode is controled by the furnace and in the cooling mode, the "G" terminal on the thermostat hooks up to the "G" terminal on the furnace and starts the blower.
Please rate me and contact me back with any other questions that you may have.
Sincerely,
Paul Gibson
Posted on May 03, 2010
Ok when I have my heat fan on my 2006 dodge charger 2.17 it dont run hot but when I turn it off it do our when I turn on the ac it run hot
If the engine is running hot you may be low on coolant. Check this first. If coolant level ok, the rad fan may not be working to cool the engine. If the AC is operational, when you turn it on, the radiator fan should come on telling you the fan motor is ok. You still may have an issue with a fan control related to temperature. This can be caused by a fan relay/wiring/temp sensor/ecm. Make sure the thermostat is functioning properly as well
Jun 21, 2015 | Dodge Cars & Trucks
Heater fan motors
The most common issue is the fan relay is NG or a bad AC/ heater switch (if we are talking about the AC/heater fan.
Apr 17, 2014 | 2005 Chevrolet Impala
When you turn the A/C on does the elect. fan suppose to come on evenin cold weather and whitch temp. switch runs it?
Normally the ac fan (in front of the condenser) will run as soon as the ac is switched on. This condenser gets hot when the gas is being compressed and needs to have the heat removed for the system to work IT will switch on regardless of the ambient temperature as it is connected directly to the ac compressor clutch. IF you are referring to the heater fan inside then it will only work with the heater fan on or with both ac and heater on but will not always work with just the ac on.
Dec 24, 2013 | 1991 Oldsmobile Cutlass Ciera
AC fan runs when heater is turned on in RV Dometic single zone
the heat and cool use the same fan. if compressor is running with heat then you have relay issue
Jul 05, 2013 | Dometic 3313192.000 White Single Zone LCD...
The heater/ac fan on my Toyota Highlander only runs on high. When set at any of the lower settings, it is just 'off'. Is this a problem with the circuit panel that controls the entire heating/ac system?
usually when you loose some fan speeds. it is the heater fan resistor. it has differant size coils for each fan sped. if they fail you loose that fan speed. good-luck !
Jan 10, 2011 | Toyota Highlander Cars & Trucks
I have two outside ac one for floor and other for upstairs and i button on heater auto and ac outside fan is running is that normal or not? and live on this new house for two years and cant find someone...
No the fan out side is for a condensing unit and compressor. The compressor should not run with the heat. I am almost positive that if this is not a heat pump that the compressor unit should not be running.
Dec 20, 2010 | Goodman GMS90703BXA Heater
98 Saturn SL2, AC/Heater Clicking
You need to replace the heater/AC blower motor the motor shaft bearing is defective..
Jun 18, 2017 | Saturn SL2 Cars & Trucks
FUSE BOX DETAILS
left to right...
1. empty
2. e flashers
3.horn, brake lights
4.clock, trunk light, inside light, radio
5. rad. cooling fan relay (AC only)
6. right side running lights
7. left side running lights
8. right high beam and indicator
9. left high beam and indicator
10. right low beam
11. left low beam
12. reverse,turn signal and inst panel
13. main and transfer fuel pumps, auxiliary air reg., ox sensor heater
14. license plate and glove box light
15. wipers
16. rear defogger
17. heater blower (no AC)
18. cig lighter
19. rad cooling fan (no AC)
20. Heater blower (AC)
21. rad cooling fan (AC only)
22. empty
23. Ox sensor, idle stabilizer,seat belt warning relay, (Digifant only, control unit, idle boost control, idle boost valve)
24. inst panel lights, heater control lights
25. reading lamps
26. empty
27. empty
28. empty
Hope this helps...;-)
Apr 17, 2009 | 1992 Volkswagen Fox
Heater/AC fan
blower motor resistor is the most probable cause of this i would go to the dealer after market part for this will leave you upset and you will just wind up at the dealer anyway
Aug 13, 2008 | 2002 Chevrolet Prizm
Heating & Cooling Logo
51 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
