Question about KitchenAid 24 in. KUDI01FLSS Stainless Steel Built-in Dishwasher
Door spring seems to have broken
The door drops down when opened. Seems to have lost its spring.
  • 5,603 Answers
Yep! What happens is a "T" shaped metal piece that is "screwed" into the spring and serves as an adjustment of tension tears or bends and falls out of the spring(s). Usually one at a time.
If you are clever you can rebend and strengthen this piece and adjust the tension to normal.
Access this by removing the panel below the door where the toe kick is.
The cause of the problem will be obvious and one side will probably still be intact so you can see how they are supposed to be.
Posted on May 02, 2010
Garage door opener
With the door down ensure the wire rope on each side are exactly the same length.
Apr 30, 2012 | Craftsman 34 Hp Garage Door Opener Chain...
I have a dishlex 300 and when i open the door it just drops down could this be something with the spring or hinges in the door
tHE DOOR SPRINGS ARE BROKEN. IF YOU HAVE DROPPED THE DOOR TOO MANY TIMES THE HINGES MIGHT BE BENT TOO. yOU WILL PROBABLY NEED HINGES AND SPRINGS....A bit of a job for a novice....like my capitals sorry about that.......
Mar 01, 2011 | Dishwashers
Oven door not closing properly
If it is a drop down door with hinges on the bootom of the oven door, then it is likely to be weak door hinge springs, the usual solution is to replace both hinges.
If it is a swing open door, then the problem is related to a worn or broken door catch, or worn striker pin.
Apr 13, 2010 | Ovens
Garage door not opening properly.
Check the springs on your garage door. If one is broken, the opener will not have enough power to raise up and it will stop like that.Or the up and down limit settings have gone off or bad.
Dec 08, 2009 | Sears Craftsman LiftMaster Chamberlain...
Hi there. I have a Chamberlain Whisper Drive
I just had that problem this morning and the cause was that the springs that help hold the weight of the garage door were broken. This caused the garage door opener to raise the garage door a fe inches and then drop again. We called in a professional and $200 later we had new springs and everything works fine now.
Nov 07, 2009 | Chamberlain 1/2-HP Whisper Drive Belt...
I have a stainless steel Kitchenaid dishwasher and the door drops hard when I open it instead of requiring you to push it down if you want to open it fully. Seems like a spring is broken. Any ideas?
there a good chance the springs popped
or the ropes came off the pullys take off the toe kick and peek in on the edges you should see exactly whats going on
Oct 03, 2009 | KitchenAid 24 in. KUDI02IRBS Stainless...
Craftsman Liftmaster
Check your door springs. One of them is most likely broken and is what caused your drive gear to strip in the beginning.
Jun 18, 2009 | Sears Craftsman LiftMaster Chamberlain...
Sears Craftsman Garage Door opener
You probably have a broken spring on the door
Jan 18, 2009 | Sears Craftsman LiftMaster Chamberlain...
Door opens beyond position parellel to floor
Hi dougisommer
I'm Harvey the Master Plumber.
Your question is: The door springs seem fine but when we open the door and wheel out the lower dish rack, the door drops further and the rack rolls down to the floor. Reading other postings, it seems like a good name for this is a broken "door catcher." How can I fix this?
You may need a sevice tech for this. The 'door catchers' on the sides of the unit can only be accessed after removing. Not a job for the inexperienced.
Feel free contact me again!
Please give me a rating here at fixya.com before you sign off
Thank you,
Harvey your Master Plumber
Sep 11, 2008 | Maytag 24 in. MDB4100 Built-in Dishwasher
KitchenAid 24 in. KUDI01FLSS Stainless Steel Built-in Dishwasher Logo
254 people viewed this question
Top KitchenAid Dishwashers Experts
Mike
Are you a KitchenAid Dishwasher Expert? Answer questions, earn points and help others
