Question about Kidde Nighthawk Combo Gas/co Detector
Periodically emits 3 loud beeps. Displays 888.
  • 5,603 Answers
The CO detectors require replacement of the battery periodically.
Unlike smoke detectors, the detector element itself also requires replacement as well as the battery and is sold as a module with the battery attached.
Posted on May 02, 2010
    Scholar:
  • 43 Answers
Combo Gas/CO Dectectors need to be replaced after 5 to 7 years of service. The sensors may not operate efficiently and will make the units give false readings.
Combo Gas/CO Dectectors are designed to give you protection against the harmful effects of Gas or Carbon Monoxide Poisoning.
If your unit is new, bring it back for a replacement. If the detector is used, make sure the unit has power and the battery has been replaced with a new one. Perform the reset function as per the manufacturer instructions. If that fails, do not hesitate, REPLACE the Gas/CO Combination Detector.
Buy your new Combination Gas/Carbon Monoxide Detector online.
Posted on Jul 27, 2010
    Problem Solver:
  • 17 Answers
"888" should only be seen for less than a minute when your first plug in the alarm. It should then turn to "0". If you continue to get "888" on the display, you should contact Kedde.
Why is my ASUS X551MAV NOTEBOOK PC beeping at me?
Hi! this is Alex Walker expert to analyse issue and fix it for you call me on +1(518)348-9393 I will be glad to assist you thank you
Aug 18, 2017 | ASUS Computers & Internet
The pet itself is emitting a loud beeping noise and wont move or respond to button presses
Take it back to the store where you got it and get them to either fix it or replace it.
Oct 16, 2014 | Toys
Dell Laptop not powering up - emitting 3 beeps
see p.47 of your manual
ftp://ftp.dell.com/Manuals/all-products/esuprt_laptop/esuprt_inspiron_laptop/inspiron-15-intel-n5010_setup%20guide_en-us.pdf
This says 3 beeps means "Possible system board failure - Chipset error" which sounds serious. Are you certain it is three beeps ? The manual recommends contacting Dell (see contacting Dell on p76). Inspect each chip on the m/b for damage (you may not find anything). You might try disassembly and reassembly of the computer (see Service Manual on Dell website) if you are competent to do this, and cleaning it out with a can of compressed air.
14.April.2014
Jul 26, 2012 | Intel Dell Inspiron 15r N5010 Laptop...
How to program a 7752V VIPER REPLACEMENT REMOTE
Open driver door.
Push and hold "f" key until remote beeps.
Push remote start button once so "pair" appears on screen. Push and hold "f" until remote beeps three(3) times to select pair mode.
Insert key into ignition an turn to "ON" position.
Push and release "valet" button on antenna, push again and hold until remote emits a series of beeps and displays "passed"
Feb 08, 2011 | 7752V Replacement Transmitter Supercode...
I have a red vertical line on my dell inspiron laptop.How do I remove it?,please
Try connecting an external monitor to the Dell Inspiron 9300and see if the vertical line is also present on the monitor. If themonitor display is fine, then your laptop’s LCD display panel isdefective. If the monitor also displays the vertical line, then yourproblem is with either the video card or motherboard located insideyour laptop.
Another answer:
run the PSA diagnostics. to do so, press and holdany non-keyboard button( like the internet hotkey or access directbutton or even the speaker mute button) and then press the power buttonand power up your system. if your inspiron doesn't have a non-kbbutton, then press the <fn> key.
release both the buttons and the diagnostics begin to run.after thediags finish. if the monitor is working fine, it'll simply say"passed". however, if it fails it would emit a few beep codes.carefully check those beep codes:
1.) if you get a 3-3-3 or a 3-3-4 error beeps, then we use the LCDbuilt in self-test (BIST). boot to PSA diagnostics again. Watch thescreen and listen for the color bar test prompt tones emitted by thePSA Diagnostics. Press <N> or wait approximately 30 seconds tofail the color bar test. The system will emit a 3-3-3 or 3-3-4 PSAerror after failing the color bar test. Wait for two iterations of thefailure code then press <Y>.
Watch for the BIST color generation and listen for the single beeps that indicate LCD BIST is running.
NOTE: Patterns of flashing color should appear on the screen. Withevery color change, an audible beep will be heard. If the patterns ofcolor do not appear, and the beeps are audible, an LCD failure may bethe issue. If the patterns of color appear, a video card or motherboardfailure may be the issue.
2.)if you get an error code apart from 3-3-3 or 3-3-4 :Ensure thesystem is powered off. Press and hold the <Fn> key and press thepower button to power the system on. Release both buttons.
The PSA diagnostics sequence begins. Make note of any alert tones or error messages.
error codes:
123- memory fails
141,142,143,144,145,146 hard drive error
147- IDE optical drive fails
148 optical drive built in test fails
122-memory test initialization test failure
111- fatal diagnostics exception.
i really hope you dont get any of these. these will help you determine,if you need to change the LCD. when you call dell, they will run youthrough these steps anyways. so if you finish them beforehand, you wontpay much to talk to them. cheerio then.
http://answers.yahoo.com/question/index?qid=20060722190406AAHejuS
Jul 30, 2009 | Dell Computers & Internet
Whenin use, my c80 emits a series of 3 loud beeps
You have triggered MOB (man over board) press and hold the MOB button in for 30 seconds.
Jul 17, 2009 | Raymarine C80 GPS Receiver
Code 217 & 219
It's only the final steady number that is the reading. When you push TEST it will show 888 and beep annoyingly a few spaced times and then it will display a number between 100 and 400 (around 200 ,,, I had 217) that is just the detector testing to see if it can display numbers. These are NOT CO levels. Then it goes back to 888 and finally displays a steady number. If it's 0 then you're clear. All o f this from the owners manual.
Mar 28, 2009 | Kidde Nighthawk Combo Gas/co Detector
Kitchenaid built in Microwave model YKHMS155LSS-0 Starts by itself, displays PAN, beeps intermittently and sometimes displays an F1 error
Dougmcduff have you resolved this problem with you kitchenaid microwave turning on periodically??? I have the exact same problem. Any solutions? I called Kitchaide and no help there.
Mar 10, 2009 | KitchenAid KHMS155LSS 1000 Watts Microwave...
Kenmore HE3 washer emits steady, constant beeeeeeeeeeeeeep
Depending on how your washer controls the beeper, it could be a stuck relay or a fried transistor.
Jan 17, 2009 | Kenmore 3.8 cu. ft. HE3 Front Load Washer
Kidde Nighthawk Combo Gas/co Detector Logo
2,264 people viewed this question
Top Kidde Home Security Experts
Are you a Kidde Home Security Expert? Answer questions, earn points and help others
