Question about Frigidaire FER311FS Electric Dryer
Drier stopped heating up this morning, is there anything i can do myself?
  • Frigidaire Master
  • 43,501 Answers
If you have a gas dryerdrier stopped heating up this morning, is there - 2_bing.gif.
The most common problem with a gas and no heat is the ignitor going bad...
Here is a tip that I wrote about that problem...
http://www.fixya.com/support/r4398592-gas_dryer_not_working_gas_dryer_not
If your dryer2_bing.gif is electric2_bing.gif..
There could be a number of different problems...
Check out this tip that I wrote about this problem...
http://www.fixya.com/support/r3866345-dryer_troubleshooting_electric_dryer_won
heatman101
Posted on May 03, 2010
TUMBLE DRIER STOPPED HEATING
Gas dryer?
If so, probably bad gas solenoid valves. They can safely be replaced without fear of releasing gas. Two phillips screws, two pull off wire plugs. That's it. Cost about $30 bucks depending on where you buy them. They are a universal part and will fit 99.9% of machines.
www.repairclinic.com
Best of luck...
May 18, 2015 | Dryers
Good morning, I'm writing from Italy because the dryer I both on June 2014 has a problem. On the position HOT it warms as it is on the position WARM; on the position WARM it doesn't warm ( the air is
check exhaust vent from drier to outside air. make sure ventilation is clear. If vent is stopped, internal out heat sensor will turn off the heating element to avoid fire. Heat will not be applied until the entire system has cooled down.
Jan 27, 2015 | Cars & Trucks
No heat from hoover hnv375
If not heat at all check for open heating element.
Sep 06, 2017 | Dryers
My kenmore 80 series drier was not heating up I replaced the heater element and the thermostats and there is still no air. Is there anything else that could be stopping it from hrating up?
yes, there is also the sloblo fuse that is near the thermostat. If you have an ohm meter, you can test it first by removing the lower panel and look near the thermostat for another wired component next to it.
Jan 23, 2011 | Dryers
Hotpoint condenser drier - not heating up
I am going to attach a link to a video that I would like you to take a look at. Many dryers are similar in setup and this may help you will the heating element. Sure hope it does and best wishes.
http://www.youtube.com/watch?v=f1rebeCMVsk
Sep 01, 2009 | Dryers
Td 4212 w Drier is not heating
Check if it still turns but no heat. If it's a kenmore or whirlpool, it's like a fuse in back of dryer. I would need mor info if it's not these models
Jul 28, 2009 | Zanussi TD4212W Electric Dryer
Amana electric dryer will heat but only when.../ LEA60AW
It seems there is some wire loose, check on the both side of heating element points.
The heating element is simply a long coil of special wire. You can check it for continuity with an ohm meter.
Good Luck!!
Thanks
Jun 22, 2009 | Amana Dryers
Tricity Condenser drier
clean the condensor itself
Sep 09, 2008 | Tricity Bendix Dryers
Whirlpool drier has no heat and won't shut off . . .
it was most likely caused by the timer not turning off and burning out the heating element or a temperature switch or tripping one side of the circuit breaker in the house. it really needs to be checked out by a professional. unless it is old then you might want to replace it.
  • best case scenario:
  • the breaker has tripped (turn it off then back on to find out)
  • the TIMER MOTOR is the only problem <$30
If the timer itself is bad then it will cost a lot more.
Jun 30, 2008 | Whirlpool LER5636P Electric Dryer
Frigidaire FER311FS Electric Dryer Logo
65 people viewed this question
Top Frigidaire Dryers Experts
Tim Whalen
Sal De
Are you a Frigidaire Dryer Expert? Answer questions, earn points and help others
