Question about Video Game Consoles & Games
My controller is an hrap ex-se by hori and when i plug it in it doesnt know that its plugged in and the lights dont turn on to indicate its working they do blink a bit and turn on with console but for the most part are never on showing that the controller isnt receiving signal from the console
  • shoryuken248 May 03, 2010
    yes i see where you are going but do you know where i can get the drivers and also the controller is for xbox 360.
    ok i dont think its a drivers issue the problem here is the controller itself its damaged on the inside no driver is going to fix that im trying to figure out how to repair the damage inside thats all.
  • 11,896 Answers
The drivers will need to be installed or updated. Then then it needs to be restarted.
Posted on May 03, 2010
  • Nate Stansfield
    Nate Stansfield May 03, 2010
    Look for any swollen capacitors or resistors (caps are the round silver or black parts)
    Look for any burn marks on the circuit board. Burn marks indicate burnt out components.
    You can purchase an analog tester fairly reasonably cheap or an ohmmeter to test each component from the solder joint connections. Each component has an imprinted number on it that says the size and voltage and ohm it carries and/or handles.
    If the part is bad, solder it off, order a new one and solder the new one in place.
All gauges work except the speeddo and revcounter.but do move when the feel like it.lights on cluster dont come on on but all little lidhts work.ex indicator-battrey.extr
Bad connecting at the Instrument panel(IP) or bad IP. I pull the plug and reinsert it. About 40% of the time it fixes the problem.
Feb 24, 2016 | Cars & Trucks
My MSI GT680 Notebook charging system doesnt work. when I plug my charger into the wall the green light indicator comes on, then when I put the plug into the laptop the light turns off and it doesn
Hello! It seems that you have a problem with the laptop charger connector. It maybe in short circuit. You can try to look for some electronic workshop that works with reballing, BGA solder, etc., that might change it. In Portugal we have some, so I think in other countries you can find them to.
Apr 03, 2013 | MSI Microstar GT680R-008US 15.6" Notebook...
My 2000 toyota tacoma truck just won't turn on. My lights work, so I assume its not the battery or alternator..perhaps the spark plug or starter maybe the problem..it was running just fine yesterday..there...
So what does "turn on" mean?? either the engine turns over or it doesnt. If you hear 1 heavy click when you turn the key to crank, but it doesnt turn over, I would suspect you need starter contacts replaced, but only a starter/alt shop is going to repair it, most shops will only replace the starter. Sometime if yoiu just keep trying it will turn over. But dont let it go, get it fixed ASAP.
Mar 18, 2010 | 2000 Toyota Tacoma PreRunner
Wont do a back upwards angle
mine doing the same thing its either a bad zener diode or the transcodeing chip is dead I will let ya know if I figure it out if not I will probably graft in a wired controller pad directly to the buttons.
Mar 15, 2009 | Hori Fight Stick EX 2 Soul Calibur 4 for...
Someone broke into my car and pulled out my stereo system,ever since they did that my signal lights doesnt work?i checked the fuses and the signal bulbs but it seems to be fine.I went the auot zone and I...
hi from the uk if memory serves ? the indicator and hazard flashers are a combined unit relay that is to say the hazard warning flasher switch serves both indicators and hazard lights SO ? if your hazard switch is located in close proximity of where the radio was fitted and was ripped out may i suggest that you check this switch has not had one of he wires/terminals pulled off by ripping radio out as some times happens over here in uk i would suspect the power feed to switch is one of them hope this helps please come back with update or if you req more info/advice ?
Jan 18, 2009 | 1997 Honda Accord
Phone charged for 1 minute but doesnt turn on
try to change the main battery, and try it again. if it persists contact a technician and he may clean the cellphone board for. it may have a short circuited.
Sep 21, 2008 | Verizon Communications Motorola RAZR...
Ps3 joypad doesnt respond
Your controller may be broken. These controller dont last forever even though they dont use batteries. Sony says the controllers will breakdown in a few couple years. Hope i helped you out
Aug 01, 2008 | Sony Playstation 3 (PS3) Console
I CANNOT OPEN!!!
Hi, Try running you laptop with the battery and the AC adapter. If by plugging in your adapter there is no light indicator likewise or no powering up, then presumably there is a problem with the power supply circuitry in the motherboard. Normally the laptop should work with just the adapter, just the battery or both the battery and the adapter. If it will not perhaps your best bet is to seek professional repair service since this would require opening the motherboard. In most instances, this involves an smc fusible link, regulator transistors or even just cold solder or loose connections. Hope this be of some help/idea. post back how things turned up or should you need further information. Good luck and kind regards.
Sep 24, 2007 | Acer Aspire 5500 5570-2609 Laptop
Port 1 not working
Hello. Please check the port (by replacement) and the fuses on the main board. If you need more info please advice.
Mar 26, 2007 | Sony PlayStation 2 Slimline Console
Video Game Consoles & Games Logo
98 people viewed this question
Top Video Game Consoles & Games Experts
James Wishart
Are you a Video Game Console and Game Expert? Answer questions, earn points and help others
