Question about Panasonic PT-53WX42 53" Rear Projection Television
Resistor Thanks for sending the Panasonic part number and description of the resistor we need. I've had a tough time locating a 100 Kohm 1/10 watt @ 5% tolerance metal film resistor, and when I look on the Panasonic part site, it says that the part ERJ6GEYJ332V is only a 3.3K (M.RESISTOR CH 1/10W 3.3K). I just want to be certain that I am ordering the right thing. I appreciate your help.
  • Panasonic Master
  • 8,617 Answers
Sorry I got the last4 letters in the part number wrong. Its a 100K 1/10 watt metal film but the part number is ERJ6GEYJ104V the other part number was for R7058 which is 3.3 K. Small print on the parts list. Order that number its for the 100k ohm resistor that you need.
Posted on Mar 25, 2008
How do you set a resistor to 2200 ohm
Connect two resistors in serial eg 1kOhm +1.2 kOhm. You may not need exact 2200 assumung that standard resistors tolerance is 5% - check with Ohmmeter if it's between 2,11 and 2,32 kOhm. But if it's special and value is critical then get trimmer (small adjustable resistor) and adjust value to Ohmmeter indication. Watch out required power.
Mar 01, 2014 | Gardner Bender GB GMT-312 12 Range Pocket...
PT-47WX52F with bad resistors at R832, R7060, and R7066. Changed IC's before, but now these resistors are bad. What type of resistors are these, and how can I obtain them? Thanks
R832 is a 8.2MEG 5% 3/4 watt resistor
R7060 & R7066 are both .27 ohm 5% 1watt resistors,
You can get the full set of panasonic resistors from www.tvrepairworld.com under the Panasonic repair kits its listed as the PT47WXC43 Resistor Kit that kit also fits the WX52 and WX42 models panasonics.
Aug 11, 2011 | Panasonic PT-47WX53 47" Rear Projection...
Panasonic T.V. model number PT-47WX42F no picture or sound
R800 open on power board next to the relay.the resistor value is1.5 ohms 10 watt resistor.
Jul 15, 2009 | Panasonic PT-47WX42 47" Rear Projection...
Need resistor value for RK62 on DP2X board for 57SWX20B
RK62 is a 2.2ohm 1 watt metal oxide resistor hitachi part number 0700054M any 2.2ohm 1 watt resistor will work although it does have to be metal oxide(flame resistant) for safety purposes.
Mar 24, 2008 | Hitachi 57SWX20B 57" Rear Projection...
Toshiba convergence
this sounds like me to be a output resistor..these are usally half watt resistors next to the convergence ics. the fact that you can move the convegence hairs side to side indicates that the ics are still good. i have tried to located the resistor on schematic... i know that they are the big one next to the stk ic these are the big ones on the big heat sinks. 1 watt i beieve. im going to keep looking
Mar 15, 2008 | Toshiba 42H81 42" Rear Projection...
CONVERGENCE ic CHIP
if you can remove the rear panel assy. look for the convergence ic's they start with stk--- and you got the part number you need a source panasonic is 814 source and the number on the ic's stk 390 ----/
Aug 22, 2007 | Panasonic PT-53WX42 53" Rear Projection...
CT-27SX11E Fixed but need advice on R value
i would not recomend replacing the 7w with the 5w, beacuse the resistor will allways run hot, hotter then the resistor should be. the resistor could possible melt anything that touches it & will not last as long as the original before it goes bad. find a 7w, if just for safty reasons.
Nov 01, 2006 | Panasonic CT-32D12D 32" TV
Panasonic PT-53WX42 53" Rear Projection Television Logo
46 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
