Question about Hunter Ceiling Fan Light Remote Control
Model 21728 Hunter ceiling fan lights do not work
Model 21728 Hunter ceiling fan.
the fan itself responds to the remote. however when I went to turn on the light with the remote, there was a blue flash like a bulb burning out. After replacing the bulbs the lights still do not come on. Is there a fix for this?
  • 51 Answers
SOURCE: Hunter ceiling fan
Sounds like the remote receiver units (located where the mains connect to the fans) took a surge and have failed.
Posted on Jul 25, 2007
Buffalo12980
  • 625 Answers
SOURCE: controller circuit for Hunter ceiling fan bad
try home depot they sell hunter.
Posted on Aug 31, 2007
SOURCE: minka aire concept II ceiling fan bulb replacement
I found that the minka website has the installation manuals online.
www.minkagroup.net/http://www.minkagroup.net/minkaairemanuals.asp The glass cover on a Concept I fans turns counterclockwise. I had to use rubber gloves to get a good grip on the light cover.
Posted on May 03, 2008
SOURCE: changing light bulbs in Hampton Bay model AC 527 Ceiling fan
I have the same fan
Only try to turn the glass cover in the opposite direction that is posted for close. You will want to do this after the light has cooled. It tends to sieze when it lense heats up.
Good Luck
Posted on Aug 23, 2008
SOURCE: hampton bay ceiling fan , model # 55295
I had the exact same problem. To solve it, I had a friend hold the area of the fan that the globe screws into. I wore rubber dish gloves to get a good grip and pushed up slightly on the globe as I turned counter-clockwise. My friend held the other part and turned clockwise a little as well. It took a lot of pressure for it to finally come loose and then we just turned it about another 90 degrees and the globe slips right out of the groove.
I couldn't believe how hard this was to do.
Posted on Feb 14, 2009
My control won't activate the light on my Hunter fan. The light comes on via pull chain fine, and the control works the 3 speeds on the fan, but the light won't respond.
Check the wiring on your receiver to make sure the light wire is connected.You have to have the light on with the pull chain and then use the remote to turn it on/off.
Jan 06, 2013 | Hunter 52" Ceiling Fan With Light And...
Hunter ceiling fan fan is working but lights are not
Make sure light wire is connected at the ceiling & at the bottom. Otherwise it's probably the receiver. 1-888-830-1326 ( Hunter parts )
Jan 05, 2013 | Hunter 52" Ceiling Fan With Light And...
Hunter Quiet Breeze Model 21728, I have dual switch wiring and cannot match the wires in the owner's manual description with the wires that the unit have. Can anybody help - how to connect the wires?
The wires that should be in the light box (in your ceiling) should be red, black, and white. Red is typically for the light. Black is typically for the fan, and white is your neutral. The fan should have 3 different wires to connect.. They are likely color coded. The manual should explain which wire is for what...
Sep 20, 2009 | Hunter Dryers
Wacky remotes
change the frequency on both so they are not the same they have to be changed in the fan transmitter and receiver
Jul 30, 2009 | Hunter Fan Co. 60 In.Brushed Nickel...
Our fan light comes on all by itself in the night. the fan itself does not always respond to the remote, mostly when turning on. I had to replace 85112-02 a couple of times when the fan was new. Now what?
Your power is going off and back on during the night (that, or a poltergeist is pushing your power switch. :-). The Hunter 85112-xx is programmed to turn the light on when power has been off and is restored (this is so you can turn it off/on with the wall switch as well as with the remote). No way that I know of to get around this. I find it VERY annoying.
Jul 10, 2009 | Hunter Ceiling Fan Remote Receiver...
Hunter Fan - Remote
Most likely the fan turns on with a wall switch and then as long as the power is there [ wall switch left in on position], the remote works
Apr 26, 2009 | Universal Remote Control Hampton Bay...
Hunter fan/light with remote installed turns on by itself
Many times this is caused by stray frequencies in the neighborhood. And, sometimes changing the frequencies on the remote and receiver reduce the occurrence.
But it sounds like this may not be the case, here. If not, the receiver in the fan is the culprit and should be replaced. No danger, just annoying.
Apr 01, 2009 | Hunter 52" Ceiling Fan With Light And...
Hunter ceiling fan type 3 not responding to remote
Sounds like the black wire from the fan is not properly connect(lose)
Here is an example wiring diagram
Mar 15, 2009 | Hunter Low Profile III 20807 Ceiling Fan
Remote Chewed Up
i had similar problem with remote , went to home depot to buy a new fan and saw they had new remotes and receivers for the hunter fans , i bought the kit ( which had a remote and a receiver for a non remote ceiling fans) and was working again . salesman was very helpful .thanks.
Dec 30, 2008 | Hunter 52" Ceiling Fan With Light And...
Ceiling fan remote will not turn on light
common problem , i went to home depot and bought a new remote for my hunter fan , and it worked again , salesman was very knowledgeable and helpful . thanks. explain the problem to him , he can help .
Dec 28, 2008 | Hunter 52" Ceiling Fan With Light And...
Dryers Logo
146 people viewed this question
Top Hunter Dryers Experts
Paul Bade
Thomas Perkins
Thomas Perkins
Are you a Hunter Dryer Expert? Answer questions, earn points and help others
