DVD Drives
Problem for DVD Drives
Generic problem for all DVD Drives
Unable to burn using a LG GSA H58N DVD bur...
By JurgenS on Mar 25, 2008
I have tried several burning softwares and upgraded the firmware of the unit but I am still not able to burn any DVDs.
I either gets something burned and then it hangs or it does not burn anything at all.
I suspect that Windows XP does not recognise that it is a DVD burner but I have not found any driver for it.
Best Solution
posted on Mar 25, 2008
Very Helpful)
Mabikire
Rank: Wiz
Rating: 84%, 45 votes
With the built in drivers for windows XP it can identify and use DVD-RW facilities of DVD burner. However depending on your bios your machine can fail to burn DVDs if your bios can not recognise that output.
While loading the CD that comes with the DVD-RW did you get an error message if yes then it means you BIOS is failing to recognise your DVD-RW as an output method try to update the BIOS. But before you do that if you can try adding the drive on a modern (after 2002) machine with xp and see if it can burn DVDs there without adding any drivers.
if it fails on that other machine then you can be sure its not your BIOS but a problem with drive (which I suspect most actually). But if it works then then you need to update your machine bios.
Was this helpful?
Yes
No
Popular Solutions for DVD Drives
Questions and Unsolved Problems for DVD Drives
Answer
Optiarc DVD RW AD-5170a ata device. Cannot start code 10 error? any ideas why.
Answer
for some reason now after i convert the disc and it burns from the computer then try to make... (More)
Answer
the program to run my cd rom has simply vanished from my computor
Answer
my gh20ns10 lg dvd drive cannot read dvd but can read cd
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For DVD Drives:
Top DVD Drive Experts
Rank: Guru Guru
Solutions: 14885
Experience: 40 years of automotive repair work, home appliance repair experience and general electrical repair.
Ask Me
Find more DVD Drive Experts
Top Computer & Laptop Repair
(513) 874-3306
We fix and repair laptop motherboard no video, no...
LaptopOnCall Inc.
(877) 934-6198
Send your laptop to us and we will diagnose the...
A+ Rated Oceanside Computer Sales & Service, LLC
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
