Question about Cyberhome CH-DVD 300 DVD Player
I have no signal with the video component (Y, Pb and Pr)
I bought a video component (Y, Pb and Pr), I connected them to the TV and the TV sais there's no signal. What is going on?
    Sergeant:
  • 418 Answers
You may have to set-up the DVD player for component (Y,Pb,Pr) output instead of S-video. You may have to set DVD player to progressive-scan or 720p or 1080 video out, also.
Posted on May 03, 2010
How to you conect a kawasaki dvd to a hd tv
The best connection the kawasaki dvd has is a Component connection. This connection separates the Red, Green and Blue colour signals. Your HD TV should have a component input, just look for Red, Green and Blue RCA inputs labelled "Pr", "Pb", and "Y".
You don't need the red, green, and blue colored RCA's specifically for this type of connection. The colors are there to help make it easier to connect. You can use any coloured RCA as long as you have the Pr on the DVD connected to the Pr on the TV and likewise for the other two connections.
In addition to these connections you will need two more RCA's (Red and White) for the audio signal. You will need to connect the audio output of the DVD, to the audio input corresponding to the same Component Video input you are using for Video. This should be fairly self explanatory when looking at the DVD's and TV's connections at the back.
Oct 27, 2012 | kawasaki 5-DVD Home Theater System - 1152...
I've tried connecting a Sony DVD player to my TV using Pb Pr V cables. I get a picture, but no sound.
The cable u are using it is the S-video cable?Yes,this cable dosen't support audio.Must used a RCA component cable like R,W cable connected between the tv and the DVD player to get sound.
Mar 14, 2011 | Sony BRAVIA KDL-40V2500 40 in. LCD HDTV
Y/Pb/Pr outputs are green; needs
There is no calibration for the component video that I know of, check your cables you may have a bad Pr cable or the Pr/Pb ones may be mixed up.
Y (the green one) is for luminance, plug in ONLY this connector and you should see a black and white picture.
Now connect the Pr. You will now see red tones.
Now connect the Pb. And you will see blue tones.
Reverse the Pr and Pb and see what happens.
Oh and make sure you don't accidently have one plugged into a composite video or digital audio port.
Still not looking right?
Go into the input menu of the TV and change the component (or colourstream) input from RGB to Y/Pr/Pb. (most TVs do not have this feature.
Hope this helps!
Jan 24, 2010 | Samsung SIR-TS360 DirecTV DTV Receiver
How to connect a dvd player to lcd tv
Your DVD player's output is Composite Video (the yellow connector) plus stereo audio (the red and white connectors, for right and left audio)
The inputs on your TV are for Component Video, which splits the video signal into three cables (Y for brightness, Pb and Pr for blue and red, respectively)
Check your TV to see if it has a composite input (single yellow connector, labeled "video" or "composite")
And be sure to let me know if this helps!
Oct 24, 2009 | Televison & Video
Connection for y pb pr cables
The color-coding used for the RCA connectors is nearly universal:
  • composite video - yellow
  • audio - red (right channel) and white (left channel)
  • component video - green (Y), blue (Pb) and red (Pr)
Also, these jacks are normally labeled in print as well, although it's sometimes hard to read the text on some equipment.
Match the connectors on your converter box to the corresponding connectors on the TV. If your converter box was one purchased with the $40 US Government coupon, it may not have the component video outputs. The only coupon-eligible boxes are the most basic models, and they sometimes have only RF (channel 3 or 4) and composite video outputs available.
May 03, 2009 | iLO 3200 32 in. LCD Television
Dvd won't send picture/audio to tv
for video, 3ways and any of this should work.
Step1, video out of dvd to video in on top at video1 section on tv. or
Step2, svideo out of dvd to svideo in at video1 section on tv. or
Step3. using component video DVD unit component video out to TV unit component video in at video2 Y to Y input of TV Pb to Pb input of TV Pr to Pr input of TV
for audio, connect left/right audio of dvd to left/right input of tv. Input section of TV is in the middle. on tv back panel from left to right is antenna input, IN section - this is it, use this for all your connections. let us know if you have any issues. thanks.
May 02, 2009 | Panasonic DVD-S27 DVD Player
Connecting tv to surround sound
Look at the back side of the TV .
There will be [more than one] composite video in & out
How composite video port looks like typical 3 RCA jacks - std color of ports are Red, White & Yellow. The yellow one is the one - which carries video signal. You can connect - a RCA cable from output of SC-HT730 [yellow] to back of TV.
Most probably there will be at least one Component video behond your TV set [ if the set is HD Ready one] - in other words, If your TV supports component in.
Component Video ports are namsed as Y Pb Pr - if you have so, connect output from SC-HT370 to back of TV.
Recommendation: choose component video - if that is supported in both. That gives much better picture quality.
Dec 16, 2008 | Panasonic SC-HT730 System
Monster Component Cable labled Y/Cb/CR to TV that has Input Y/Pb/Pr
Y PB PR is the analog version of the Y CB CR color space; the two are numerically equivalent, but Y PB PR is designed for use in analog systems whereas Y CB CR is intended for digital video.
Aug 31, 2008 | Televison & Video
Surround sound
Hi
Your receiver is capable of video conversion, so there should be no problem using your component cable.
Does your TV accept component, or only S-Video? If you can run component to your TV, the best quality signal path would be using a component cable from your Verizon box to your receiver, and component from your receiver to your TV.
Make sure you have set up the video input correctly, so that it is set to accept the incoming signal on the correct sockets.
Mar 21, 2008 | Audio Players & Recorders
Mitsubishi WT-46809 Problem getting HD from DirecTV
I have the same exact problem. Same model, etc. Is there a resolution?
Sep 16, 2006 | Mitsubishi WT-46809 46" Rear Projection...
Cyberhome CH-DVD 300 DVD Player Logo
146 people viewed this question
Top Cyberhome Televison & Video Experts
zappal
Electro Med Services...
Are you a Cyberhome Televison and Video Expert? Answer questions, earn points and help others
