Question about Garden
I have a Troy-Bilt TB90BC string trimmer. The engine starts & runs fine but the trimmer head runs slowly and stops under light loads. I removed the lower shaft & confirmed the cable connection is not rounded. Also, confirmed head spins under load when connected to drill at EZ Link connector. Is this a clutch problem? Can I replace the clutch without special tools?
  • TechDel May 10, 2010
    Thanks for the feedback. How do I dismantle the unit to inspect the clutch? Cannot find any good information about this on the web.
  • 64 Answers
It sounds like the clutch may have oil on the shoes or oil in the clutch drum if it has a clutch or the clutch is binding and not fully locking up.
Posted on May 04, 2010
Runs great, blower and trimmer heads will not turn/work. Tried using the blower attachment and the fan turned very slow
Contact the consumer desk.
TB22 EC Curved Shaft String Trimmer by Troy-Bilt
www.troybilt.com/.../troybilt/TB22EC-trimmer
Troy?Bilt Products
Rating: 3.7 - ‎232 votes - ‎$99.99 - ‎In stock
25cc, 2-Cycle Gas Trimmer / Attachment-Capable Design ... The TB22 EC gas string trimmer is both JumpStart™ and TrimmerPlus® attachment capable, making ...
Gas Trimmer ' TB635 4-Cycle Curved Shaft ... - Troy-Bilt
www.troybilt.com/.../troybilt/tb35-ec-curve-shaft-gas-...
Troy?Bilt Products
Rating: 3.3 - ‎32 votes - ‎$179.99 - ‎In stock
The TB635 EC curved shaft gas trimmer with SpringAssist™ technology features the new Click N Trim™ bump head, making line replacement easier than ever. ..... next one they put on - will only run for about 4 seconds. they've had for about 2 ... Both String Trimmer and Edger work great, easy to start and very low vibration.
Dec 09, 2015 | Troy-Bilt 4-Cycle Curve Shaft Gas String...
Motor starts and runs fine but trimmer heads only spins slowly
replace the centrifugal clutch at the motor end of the unit shaft
Jul 18, 2015 | Troy-Bilt Troybilt Mtd String Trimmer...
Troy bilt troubleshooting
Bushing is worn out. You will need to replace the shaft. Fairly inexpensive.
Aug 24, 2014 | Troy-Bilt 4-Cycle Curve Shaft Gas String...
Troy bilt weed eater
I have a troy built 2 cycle pro-line tb90bc spring assist trimer.
its getting fuel and it wouldn't start I took out the spark plug and it was wet with fuel. pls fwd any info to ss.beepat@hotmail.com
May 06, 2013 | Troy-Bilt Tb90bc 17-inch 31cc 2-cycle Gas...
TB70ss Trimmer runs but does not turn the string
Remove the angle drive gearbox near the string head and spin it to see if everything is moving properly. You may have stripped the gears out of it.
Sep 16, 2012 | Troy Bilt Tb70ss Gas Trimmer
Troy-Bilt TB70SS will not start
Hi. Go to any auto parts store and get a can of starter fluid. Have a helper squirt a little into the air cleaner while u start it up. Then continue to squirt the starter fluid to keep it running until the engine sounds good again. J.
Jul 07, 2010 | Troy Bilt Tb70ss Gas Trimmer
Troy-Bilt weed eater, Model TB90BC, had rotten fuel lines and primer bulb, I replaced but may have hooked them up wrong. How do I hook them up?
Prime and watch the fuel move up to the carb. This is the fuel line and it should be long. Make sure it goes to the bottom of the fuel tank.
Apr 04, 2010 | Troy -Bilt String Trimmer/Blower...
I don't know how to load line into the Troy Bilt Speedlock head
cut to pieces of string about 8 ft long. run your line through the holes on the side of the head. you will see 2 smaller holes on the inside. put the string in those 2 holes and begin turning your head to install the string.
Aug 22, 2009 | Troy Bilt Tb70ss Gas Trimmer
How to replace air filter on Troy-bilt TB20CS?
May be air filter but sounds more like your muffler is stopped up. First take the muffler off and see if it runs better without it. If so, burn the carbon out of the muffler and clean the muffler port on the engine. If not, then remove the four screw at the very end and disassemble. The ait filter is in that area. Diagram is located at
www.stollerlawnandgarden.com/.
Click on parts lookup in left hand column.
Jun 24, 2009 | Troy-Bilt 4-Cycle Curve Shaft Gas String...
TROY BILT TRIMMER MODEL TB70SS. HOW DO I REPLACE
Is the pull rope in the front or rear of engine.Thinking that the string is in the front,you must throttle housing and shaft from engine. remove starter housing. There sould be a screw holding the string and spring in place.
May 07, 2009 | Troy -Bilt String Trimmer/Blower...
Garden Logo
463 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
