Question about Dell Inspiron 2200 Notebook
My Del notebook isn't turing on. I press the power button and it just would flash for a second and not turn on.
  • maylissa513 May 02, 2010
    I tried but the flash light doesn't even flash. thanks though, Do u think I need a new battery?
  • 233 Answers
Try to take out the battery and use adapter, now try again to power up your notebook.
Posted on May 02, 2010
  • Deny Mulia
    Deny Mulia May 03, 2010
    If did not working using adapter that's mean you got problem with motherboard, my suggestion you open your notebook,take off all things then re-build your notebook. (it's a bit tricky) but you can do it.
    dm
Will not turn on, on light flashes blue then amber for a second then nothing and it keeps repeating
Hi Andy,
My name is Pradeep and I work for Dell's Social Media Team.
Please turn off the system and unplug only the power cable. Press and hold the power button for 15 seconds. Plug in the power cable and turn on the system. Let us know if the system is booting to windows.
Please let us know if you can hear fan noise from the tower.
Pradeep Lokesh
Social Media and Community Professional
Order Status: http://del.ly/61822hij
Download Drivers: http://del.ly/61832hid
Jan 04, 2016 | Dell Inspiron 3647 Small Form Factor 3.1...
I tried alt control del. the screen is froze as well as the mouse
The sequence is CTRL ALT DEL. Press the Power Down/OFF button for several seconds, the notebook t should turn itself off. Reboot.
Dec 16, 2013 | HP 2133 Notebook
My coby MID7012 isn't going to the home screen after I charged it. Its flashing coby over and over. But its not turning on. What do I do?
Sounds like you are in a "Boot Loop". Let's try to break the Boot Loop. Plug the device into the charger, then press and hold the power button for 60 seconds - make sure the device is OFF after the 60 seconds. Let change overnight. Next Day, unplug the device from the charger, then press and hold the power button for 30 seconds, wait 30 seconds, press and release the power button normally, the device should be out of the Bootloop.
Jun 12, 2013 | Dell Android 2.3 Touchscreen 7" Internet...
HP pavilion ze4300 will not shut off.
Two things you can do, you can hold down the power button, keeping it held down, should power it off. The other solution is to remove the battery, this should cause the Notebook to power down
Feb 28, 2011 | HP Pavilion ze4300 Notebook
My Acer Aspire One boots up but only runs for 5 seconds then click, and it goes blank. It has a charged battery and does this even when plugged in to the charger. I have tried to boot it up using F2 and...
hi there,
use at your own risk.
Follow every step carefully!
First format an USB stick with FAT.
Download the latest BIOS, and put both FLASHIT.EXE and the BIOS file in the root directory of the stick. Rename the BIOS file to ZG5IA32.FD, that’s important. Do not remove the USB stick.
Turn the AA1 off, make sure both battery and AC adapter are connected. Press Fn+Esc, keep it pressed and press the power button to turn the AA1 on. Release Fn+Esc after a few seconds, the power button will be blinking. Press the power button once. The AA1 will now initiate the BIOS flash, do not interrupt it under any circumstances. After a while the power button will stop blinking, and the AA1 will reboot shortly after. Wait patiently.
The BIOS has been flashed and all settings reset to default.
If for some reason you made a mistake during the procedure and it doesn’t reboot by itself wait 5 minutes before turning it off, just to be safe that it isn’t still flashing the BIOS.
Jul 11, 2010 | Acer Aspire One PC Notebook
My computer will not boot up
The AA1 has a built-in BIOS recovery routine, which makes it possible to flash the BIOS even if it doesn't POST and the system doesn't boot anymore. It's meant for emergencies and is also known as crisis disk mode. Use at your own risk.
First format an USB flash drive with FAT.
Download the latest BIOS, and extract all files from the zip file. Put both FLASHIT.EXE and the BIOS file with FD suffix in the root directory of the drive. The files must not be in a folder. Rename the BIOS file toZG5IA32.FD, that's important.
Turn the AA1 off, with the USB drive still connected, and make sure both battery and AC adapter are also connected.
Press Fn+Esc, keep it pressed and press the power button. Release Fn+Esc after a few seconds. The power button starts blinking at this point. Press the power button once. The AA1 will now initiate flashing the BIOS, do not interrupt it under any circumstances. After a while the power button stops blinking, and the AA1 reboots shortly after. Wait patiently.
The BIOS has been re-flashed and all settings are reset to default.
If the AA1 doesn't reboot by itself, but the power button still blinks, wait a few minutes before turning it off, and try again.
Jun 08, 2010 | Acer Aspire One PC Notebook
Starts then shuts off.
Go to ur toshiba website and enter ur service tag...u might see few recommended downloads...Der download the bios driver and save it in a usb and boot the system from usb...if the bios is corrupted this will rectify the problem..if else u need to change the motherboard...
Jul 13, 2009 | Toshiba Satellite A75-S206 Notebook
WHAT IS THE RESET BUTTON ON THE BOTTOM SIDE OF MY COMPAQ PRESARIO 2500 SPECIFICLY DO. IN OTHER WORDS IF I PUSH IT WILL I LOSE ALL MY STORED INFORMATION ON THE DRIVE?
This is straight from the manual:
Occasionally, Windows or the notebook might stop responding, so that you cannot turn the notebook off. If this happens, try the following in the order listed. Press the power button to restart.
• If possible, shut down Windows: press ctrl+alt+del, and then select Shut Down > Restart.
If the system will not allow a software shutdown, press and hold down the power button until the display shuts down (about 4 seconds) and then release the power button. Press the power button again to restart.
• Use a ballpoint pen or a straightened paper clip to press the reset button on the bottom of the notebook.
In other words: You will not loose any saved data if you reboot your laptop this way. All unstored information (open documents etc.) might be lost though.
Dec 20, 2008 | Computers & Internet
Turning on &sterio problems
Hi, my problem was that I had trouble turning my laptop on. It had been getting worse over the last couple of years. It was suggested that the power button should be replaced. While searching the HP site on how to do this, I ran across a solution that said to take out the battery, unhook anything else that might be connected to the laptop, and then press the power button for around 10 seconds to drain all remaining power out. Then put battery back in and try to turn on. It worked! My laptop now turns on and off just fine! Hope this can help someone else....Linda P
Nov 07, 2008 | HP Pavilion dv1000 Notebook
Frozen laptop
According to the manual
Using Emergency Shutdown Procedures
If the notebook does not respond to the Windows shutdown
procedure (Start > Turn Off Computer > Turn Off), try the
following emergency shutdown procedures in the sequence
provided:
■ If the notebook is running Windows XP Professional: Press
ctrl+alt+delete. Select the Shut Down button, then select Shut
down from the drop down list.
■ Press and hold down the power button for at least 4 seconds.
■ Unplug the notebook from external power and remove the battery pack.
Apr 14, 2008 | Compaq Presario X1000 Notebook
Dell Inspiron 2200 Notebook Logo
67 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
