Question about Magellan RoadMate 3000T GPS Receiver
Power jack may be loose, when I plug the charger and hold the cable at jack position tighly(put a plaster or keep hand continuously) then GPS is working, otherwise loosing power and GPS is turned off. Could this be a loose connection or something else.
    President:
  • 1,111 Answers
The power port is broken inside..this is a very common problem with this model and many others.
you could buy another battery like some other so called expert will advise, but i suspect youll have the same problem after the battery dies.
plug it in to a know good charger(preferably a care charger that has the light built in to tell you its working) then press and hold the power button for up to ten seconds....if it does not start up, its probably because of the power port, but there is allways a chance it could be a faulty board or LCD
you can find the power port you need on ebay..just search ebay for them HERE normally the guys that sell the part will repair them...just ask the ones that are selling the part you need, if they would repair it.
i do repair these and have the part all the time but im not allowed to post direct links to me, but feel free to post back with other questions
that is a direct search for the part you need and not directed to any certain seller...if that search fails, let me know...anyone that has that part will be able to help you further
let me know if you need more help
bill
Posted on May 04, 2010
My nuvi 260W displays the computer plug in sybole then turns of both while move and sitting still an d is connected to power supply. I have bought new connector for power supply.
Whenever you see the computer to GPS symbol pop up while using the DC car charger, this is an indication of a loose USB jack (bad connection) between the jack and the printed circuit board.
You should only see this symbol when connected to the PC using the USB cable. You should never see it when using the charger. Please see this link for more information and how to have it repaired:
SHARCNET USA Out of Warranty GPS Digital Camera Repair
Apr 09, 2014 | Garmin nuvi 260W GPS Receiver
Why wont my naman hold a charge
Sounds like the internal battery went bad or your charger cable has a short in it. Test the cable by plugging it in the power source (wall or car) and use a voltmeter on the jack if possible.
Dec 22, 2011 | Navman GPS
Gateway kav60 not charging. i have to wiggle the cord and sometimes it refuses to charge.
I guess you've got a broken laptop power dc jack or power cable.
Symptoms of a broken Laptop DC power jack:
- The laptop only operates when you hold the DC power plug in a certain direction (DC jack is broken or loose).
- The laptop only runs on battery power (no power is getting through the DC jack).
- The laptop gets no power at all.
- The laptop will not charge the battery.
- The laptop switches from AC power to battery power intermittently due to a loose or broken power jack.
- The laptop suddenly shuts off.
- The DC jack may feel loose.
- Sparks come out of the back of the laptop when you insert the power plug into the DC jack.
Apr 21, 2011 | Lifetime Gateway KAV60 Replacement Laptop...
I have a compac presario cq60, I've recently got a brand new charger and battery both from hp as they both needed replacing. I've put the new battery in and plugged the charger in but I noticed that the...
First thing to check is that the battery is inserted properly. Take the battery out, make sure there's nothing on the contacts, and then put it back in. The problem could also be that the charging jack on your laptop is loose. If you hold the charging cable plug in the laptop with a little (not a lot) force, or push it a little to the front or back, does it stay charging? If it does then the jack is loose. Your temporary fix is to hold it the way you did while testing to see if it was the problem. Be aware, this fix is strictly temporary, eventually the jack will get loose enough and not make contact at all. Consider calling Compaq customer service and checking to see if it's covered by warranty.
Mar 24, 2011 | Computers & Internet
My magellan screen went blank and I can't get it back on even with the cord plugged in......I was told to hit the little reset button on the bottom of the device that that hasn't helped. Any suggestions?
you might have a bad power connector (usb port) but lets assume its ok for now. plug the gps in to its charger and let it alone for a few minutes, then hold the power button for up to 15 seconds. if that doesnt work, keep it plugged in to the charger and then try the reset again holding it for about 10 seconds. if neither of those work, either the power connector is bad or the screen is bad or might just need the ribbon cable reseated.
Aug 15, 2009 | Magellan Maestro 4210 Car GPS Receiver
Garmin nivi 200 won,t turn on
The mini-USB jack needs to be either resoldered or replaced. When the jack is loose, you will not be able to charge the internal battery. The jack becomes loose from overuse. The jack needs more mechanical support to the pronted circuit board. I have fixed this problem many times.
- Jim
Aug 01, 2009 | Garmin Nuvi 350 Car GPS Receiver
Garmin 200w goes into usb mass storage mode when pluged to charge
Steps:
1) Disconnect the nuvi from the charging cable.
2) Press and hold the battery meter icon for 8 seconds. This puts the nuvi into "system test" mode.
3) Plug in the power cable.
4) Click "Exit." The nuvi will reboot, but remain in GPS mode!
Jun 08, 2009 | Garmin nuvi 200W GPS
Ironically, 5 days after the paid warrenty expired (2 years and 5 days after I bought this piece of equipment), the A105-4254, it suddenly died on me! It always had a "loose connection" to the AC...
It is not the power cord but the input jack itself. You will need to bring it to someone that can solder in a new connector. This is what they look like from the inside. Most local computer or electronic stores can make the repair for you. Should be around $50-$75. Make sure you don't pay too much.
Jan 23, 2009 | Toshiba Satellite A105-S4254 Notebook
Garmin charger problems
19A259741 is the serial number. The model number should be to the left of that on the decal label. It's sounds like you have a Nuvi 2xx series.
The mini-USB jack is loose. Either is has come loose from the board or the connections within the jack are loose from everyday wear and tear (use).
If the jack is loose from the board and it needs to be resoldered or replaced if the jack is worn out.
- Jim
SHARCNET-USA
Dec 05, 2008 | Garmin nuvi 200W GPS Receiver
Power Cord Falls Out of Socket in Laptop
The DC jack in the machine has come loose or is worn out and needs replaced. Be careful, if the soldier on the jack has broken loose it can cause an electrical arch and do sever damage to the machine.
Jul 07, 2008 | Toshiba Satellite A135-S2276 Notebook
Magellan RoadMate 3000T GPS Receiver Logo
193 people viewed this question
Top Magellan GPS Experts
Jungle Ghost
Jungle Ghost
Are you a Magellan GPS Expert? Answer questions, earn points and help others
