'left' or 'volume down' function appears to be
Toshiba'l 26AV52U
'left' or 'volume down' function appears to be stuck on. When the unit is powered, the volume bar is on, indicating zero. Pressing up on the volume sends intermittent signal, competing with whatever the problem is. Tried removing batteries from all remotes. Blocked the remote signal receiver, and problem persisted, indicating problem with the unit. Tried the reset function (hold power for five sec) and problem persisted. Cannot reset factory settings, when the menu is opened, it scrolls left consistently through the categories due to the issue (no settings can be changed due to this).
    Sergeant:
  • 418 Answers
The volume down button on front of TV is stuck down or the switch is bad.
Posted on May 03, 2010
Testimonial: "Indeed that turned out to be the problem. It was my parents' TV, and they said they never even pressed the buttons on the unit. Luckily, it was still under Costco's free extended warranty."
Toshiba 32bl505b tv menu locked
Disconnect the AC power for at least one minute to reset the clock.
Adjust the volume to the minimum using the Volume down button on the front of the unit.
Press and hold the Volume down button on the front of the unit and the 0 button on the remote control at the same time, holding them down for at least 10 seconds.
The user menu will appear with the V-Chip cursor blinking.
Press the ENTER key on the remote control and the NEW PASSWORD menu will appear. Enter your new password.
The V-Chip is bypassed by holding the zero key on the original remote hand unit, and at the sane time holding down the volume down on the front of the TV set. This should reset the oide so you can enter a new one.
Jan 15, 2013 | Televison & Video
How can i reset the toshiba 61A60
Dec 24, 2012 | Toshiba 61A60 TV
Toshiba tv is frozen on screen that says set parental control pin
To get more details check this site. Do a search by entering the brand name of your TV by its search box at the top right of the display window.
Dec 18, 2012 | Toshiba Televison & Video
Toshiba (model 19av500U) volume goes up and down automatically
It may be the remote itself and not the tv, have you tried purchasing an inexpensive universal remote?
Sep 27, 2012 | Toshiba 19AV500U 19-Inch 720p LCD HDTV...
How do I override the password on a Toshiba cx32f60 tv? All channels above 13 are blocked. I want to unblock all of them. The remote is a Toshiba ct-9809.
Hello
Disconnect the AC power for at least one minute to reset the clock running inside the circuit.
Adjust Volume to Minimum using the Volume Down button on the front panel of the TV.
Press and Hold the Volume Down button on the front panel of the TV and the "Zero" button on the remote control at the same time, holding them down for at least 10 seconds.
Press ENTER key on the remote control and the NEW PASSWORD menu will appear.
Enter your new password. OK.
Nov 04, 2011 | Toshiba CX32F60 32" TV
Toshiba LCD TV 19Av505DG how to unlock the side menu
Hello
To unlock the TV do the following:
OK.
Aug 21, 2011 | Toshiba 26AV52R LCD TV
Cannot find unlock code for sdv398kc2
Hello
Just try this procedure with your tV. Most of the Toshiba sets can be unlocked by this way.
OK.
May 03, 2011 | Toshiba Televison & Video
I have a iphone 8GB and is on silent seen nd i don't know how to remove it on silent? pls can u tell me want to do?
To enable/disable the silent feature on an iPhone, simply look to the left-side of the phone. There will be 2 buttons there:
1. A small, switch that goes left/right. 2. A longer longer that can be pressed up/down.
Button #1 is the silent toggle switch. Moving it to the left enables silent-mode; to the right disables silent-mode.
Button #2 is the volume adjustment button which will raise the volume if pressed up and decrease the volume if pressed down.
Note: If you press the volume bottom down all the way, the handset will mute itself. When using the volume button, a volume indicator will appear on-screen to indicate how loud/quiet the phone is. If there are no white bars present on the indicator scale, then the iPhone is muted. Press up on the volume button a few times to increase the volume and disable mute.
Aug 11, 2010 | Cell Phones
Toshiba (Model : 36A43) - volume goes down automatically
I am having same problem on 32 inch same problem. After playing with board with no results,I tried front buttons and found that if I held the power button in ever so slighItly as not to turn it off, it fixed problem which is the micro on/off switch, I removed the switch and used the remote and everything is back to normal, I am about to insall a used micro switch after I finish typing this but I am sure this will clear up volume problen and menu going crazy problem if not I will just leave micro switch out and use the remote, and I will get back to this board only if that micro switch still causes the problem, so if I don't post in next hour the problem is fixed and I'm more than glad to help.
Jun 18, 2008 | Toshiba 32AF43 32" TV
Parental control
1. Go to the V-chip selection in the customer menu.
2. If the set has an active PIN code, the menu will display “BLOCK-ING ACTIVE”.
3. Press RECALL on the remote four times within five seconds.
4. The menu should then display “BLOCKING RESET”.
5. Input a new four-digit PIN code and press ENTER.
6. The next menu page will appear which allows you to scroll down to the various lock selections. If you want to remove the PIN code completely, instead of entering a new code, just exit the menu after pressing recall four times.
1. Disconnect AC power for several seconds to reset unit clock.
2. Adjust unit volume to minimum.
3. Press and hold volume down button on unit control panel.
4. While holding the volume down button, press and hold the “Zero” key on the unit remote.
5. The user menu will appear with the V-Chip cursor blinking.
6. Pressing the “Enter” key on the unit remote will open the “New Password” menu.
Have a great day!!
Bill
Dec 09, 2007 | Toshiba MV13L3 13 in. TV/VCR Combo
Televison & Video Logo
156 people viewed this question
Top Televison & Video Experts
