Stereo cuts out at half volume.
I have a Pioneer RX-590 home stereo. When the volume is turned up to about half way the stereo cuts out. I have cleaned the inside and the fan still works. Is there any way to stop this from happening (EX: mods, additional amp, extra fan)?
  • 1 more comment
  • atf_20 May 03, 2010
    By cuts out I mean that the music quits playing for like 2-3 sec and then comes back on. I did not think about load impedance. Is there any way to fix it if it is impedance?
    Brigadier General:
  • 8,546 Answers
You don't exactly define what "cuts out" means.... silence, protection or power off?
What makes you think it's thermal in nature?
Have you considered the speaker load impedance may be too low for the amp?
Posted on May 02, 2010
Testimonial: "Impedance was the problem I hooked up the speakers parallel and it fixed the problem."
  • David Dunn
    David Dunn May 03, 2010
    I can't find the manual. If YOU have it, I'm sure it details the minimum load. You need to compare YOUR speaker setup to its recommended load.
    Or, disconnect the speakers and see what happens when you raise the volume, then start attaching them until it fails again.
  • David Dunn
    David Dunn May 05, 2010
    Wouldn't parallel vs series make the impedance lower? Can you detail the before and after with speaker model numbers so we can understand the solution?
Been trying to get the radio station to program.it hasn't been working. On my RX-590
If you are using automatic channel search, disable it and use manual tuning to find the station then program it. If the signal you are seeking is comparatively weak compared to others, the tuner will skip it in the automatic search mode.
Oct 20, 2013 | Pioneer Rx-590 Home Stereo Double Cassette...
Stereo cuts out
the cd player is old and its giveing out when the pre amp gets hot u should get a pioneer old or new they stand up to anything
Feb 14, 2013 | 2005 Dodge Durango SLT
How do i connect an ipod to my sony str-de310 receiver
Connecting to a home stereo
  1. For most home stereo systems, connect iPod to your amplifier's sound input using a 3.5 mm mini stereo to RCA adapter cable.
  2. Adjust the volume on iPod to less than half to prevent overdriving your amplifier. Adjust the listening volume using your stereo's controls.
    Note: Depending on your stereo, iPod may need to be set higher than half in order to get a proper volume through external speakers.
http://support.apple.com/kb/ht2167
Mar 12, 2011 | Sony STR-DE310
Setting the clock on my damn stereo
Pioneer stereos clock setting
1)turn car iginition "ON"
2)turn stereo ON and then OFF.
3)Press SRC or Joystick until blinking clock appears
4)Set clock by pressing rt,left &top,bottom keys around volume knob (joystick).
i hope this helps.
Apr 18, 2009 | Car Audio & Video
Volume on jvc home stereo receiver cuts off at a certain level
I had the same problem and found that when I moved the speakers apart further...It works as well as it always did before my 8 speakers were introduced..I think the sound was interfering with itself.. Try it !!
Jan 18, 2009 | Audio Players & Recorders
Overall Problem - Panasonic RX-ED707 won't work properly at all
only 1 reason for that faults :
there is a flat connects the top panel which has all the controls with the other circutes in the stereo...
so you have to open it and care for the cd unit it damage easily then check the flat for loseness or cuts
it happened to me also and that works perfectly
good luck
Nov 14, 2007 | Panasonic RX-ED707 Boombox
297 people viewed this question
 Grubhead
Grubhead
