Question about Whirlpool Duet GHW9150P Front Load Washer
Suds and F35 keep shuting down my laundry day:(
Suds and F35 error code keep shuting down my laundry day:( what can I do? Whirlpool Duet front loading washer. The washer starts then pours water into the washer within 2 mins. it shuts down. Suds flashes then F35 even with no soap in the washer. help please..
  • Whirlpool Master
  • 8,220 Answers
Remove the service panel and see if the filter has something in itSuds and F35 keep shuting down my laundry day:( - 77cb04b.jpgf032166.jpg
Posted on May 02, 2010
  • Dan Webster
    Dan Webster May 02, 2010
    Screws on the base are holding it on. get em off and remove the plate, behind the white box to the left is the tech sheet. It gives info on trouble shooting yer model.
  • sunlighter13 Jul 15, 2011
    Thanks for your help, I read many other posts with similar instructions but with your pictures I finally decided to tackle it and the washer works again.
I followed the suggestions of opening the lower panel and checking the filter. I found it completely clean but the machine still gave me the SUD code .... so, I detached the hose and blew it out. There was nothing more than still water in it but after running water through it and reinstalling it, the machine work fine once again.
Posted on Jul 17, 2011
If it wasn't for the pictures I may not have tried to fix this. When I removed the filter I found a comb, dime and smelly black stuff. I'm going to assume that this was my problem. I anyone else removes the filter make sure you have some towels handy to catch the water.
Posted on Jun 05, 2012
What is an F35 code?
The F35 error code is indicating the analog pressure sensor switch is either bad or blocked. Go to managemylife.com and put in F35 error code to see location and description of part.
Feb 02, 2011 | Whirlpool Duet GHW9150P Front Load Washer
F35 error code constantly causes washing machine to shut down and the SUDS error code does the same. Whirlpool rep states to unplug unit and let sit for 30 minutes to reset, yet still has the same problem...
Both of these indicate that there is a Problem with Pressure Switch.On Most of the Whirlpool Washer's ( Duet ), if you Open the top panel, then there would be 3 Screws. After that you would have an access to Pressure Switch.With the tub empty, remove the vinyl hose from the switch and blow backwards through the hose to clear any restrictions. If the fault codes return after doing this, you will likely need to replace the pressure switch.
Let me know,if needed further assistance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Mar 02, 2010 | Whirlpool Duet GHW9150P Front Load Washer
F35 and suds it turns off after 5 mins and whenever I put it on rince only it still cuts off.
F35 is a water level error.
The water level switch (pressure switch) has malfunctioned.
If you remove the top panel, three screws in the back, you will have access to the pressure switch.
Also - please be sure to use He soap.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.####
May 25, 2009 | Whirlpool Duet GHW9150P Front Load Washer
F35 code
Dec 26, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Error code f35 on my washer
The following list of codes indicates an electronics communication problem with the washer:
Duet HT® washer - F01, F03, F06, F11, F23, F24, F27, F28, F29, F30, F31, F32, F35, F42, F61, F62, F63, F64, F65, F70, F71, and F99
Duet® washer - F05, F07, F09, F10, F11, F13, F14, F15, F21, F22, and FdU
Duet SportTM washer - F01, F11, F23, F24, F27, F28, F29, F30, F31, and F33
To remove the error display, press Pause/Cancel twice.
If Pause/Cancel does not work:
  1. Unplug washer or disconnect power for one minute.
  2. Plug in washer or reconnect power.
  3. Re-select the cycle and press Start.
NOTE: If the error remains on the display, call for service.
Dec 19, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool Duet GHW9150P Front Load Washer Logo
1,808 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
