Question about Philips 27PT543S 27" TV
Hi I have a problem with my philips crt tv...can u assist me? It is a 2003 TV set and just powers off after every 5 minutes... it starts off normally but all of a sudden it shuts down... I need to start it again, it plays for another 5 mins and again shuts down...
  • 3 Answers
Can you solve this problem? please refer your correct model number of your set, Normally few faults are find out with the problem of opto coupler and LOT. If any one of the cathode is not in correct drive set will shut off
Posted on Jun 20, 2010
Sounds similar to a problem I had , haveing bought and install components to repair/upgrade the power supply I still had the same problem. I solved the problem by adjusting the LOPT line output transformer be carefull of the high voltages even when powered down, the lopt has one adjustment just turn it as little as possible, power up and see it solves your problem, I'm not sure in which direction but try anti clockwise first. Mind only needed the smallest of adjustments. Make a note of where it is before you make any adjustments. My TV been as good as gold for a couple of years now
Posted on May 07, 2010
WHEN TV TURN OFF SCREEN LIGHT SHOWS SKY CLOUDS BACK GROUND COLOR WHY
Hi, Your tv is start to spoiled. But it is quite normal if your tv is back to normal after about 5 minutes. If after 5 minutes the screen stranger background still persist, unplug your power chord. This will totally cut the power supply for your tv.
Jan 20, 2011 | Hitachi 60V500 60" Rear Projection...
Hi...I have a problem with my Sony Trinitron 29
the power supply section should be resoldered....must be loose contact..in power section...
Jan 26, 2010 | Sony FD Trinitron WEGA KV-29LS35 29" TV
My Philips 36'' CRT TV won't turn on.
Hi - Yes. There are high voltage components in your CRT TV that only a certified TV repair shop should repair. And the cost of that would likely be over $100 so you are definitely better off getting a new LCD TV. You will also save a great deal of electricity with your new TV, my 55" only uses $19 worth of electricity a year. And the picture is much better as well.
Have fun shopping!
May 05, 2017 | Philips Televison & Video
Philips flat screen tv will not power up.
Symptoms of a Defective or dying Power supplies on LCD TVs.
1. Light(s) on the front panel are behaving not normal example, blinking, amber color or
not steady, fainting, etc.
2. TV not turning ON properly.
3. TV turns OFF by itself.
4. Needs to be unplug to many times to make it work.
5. Humming or high pitch noise heard through speakers or at the back of the TV.
I repair these power supplies. Write to jah2mil@hotmail.com if you require further assistance.
Dec 20, 2008 | Philips 32PFL3403D/27 32 in. LCD TV
Takes 5 minutes for tv to stay on
the IF transformer of the video section is in trouble (change value) try to adjust using a plastic or wood stick look for AFT .
Sep 16, 2008 | Philips Magnavox 27MS343S 27" TV
Turning on TV after power outage
Not sure what you mean by "older", but I assume it's a CRT display. It takes some time for a picture tube to come up from a completely cold start. It has to get all of those electrons hot enough to start flying around, and also build up a high voltage on the screen. You don't notice it in normal operation because the power button doesn't really turn everything off, but just puts the set in standby mode. Unplugging, though, lets everything cool off completely.
If you're talking real antiques, with tube-type amplifiers, then the warmup time could be even longer. I remember as a kid watching the blank screen for a couple of minutes before a picture appeared.
What you describe sounds like normal behavior for a CRT television. Not sure what's up with that flickering red light, though.
Jun 26, 2008 | Televison & Video
TV DEAD
On some models the reset is unplugging for a minute or two and plugging back up. Otherwise you have a blown fuse where the power goes in. If you decide to replace the fuse do no go over 5 amps. If the replacement fuse blows there is a short in the set and needs a repairman.
Jan 02, 2008 | Philips 19PR19 19" TV
Assistant
check your sleep timer settings thats the most comman prob
Dec 18, 2007 | Philips 27PT81S 27" TV
Tv PROBLEM
More than likely you have loose connections on the power supply board. Fixing the connections should take care of the problem.
Oct 03, 2007 | RCA F35731MB 35" TV
Tv out of Focus
Well you did start out good, thats cool, now we have to define focus, Is ir blurry around the edges as well as the whole Picture? If it is, it could be the picture tube, A bad solder connection on the tube socket, and yes it could also be the flyback transformer.
Oct 06, 2006 | Philips 27PT8420 27" TV
Philips 27PT543S 27" TV Logo
156 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
