Question about Irons
Tefal Aquaspeed 160 Steam Iron
Auto Shut off has been activated and i dont know how to reset the iron
  • amesen May 31, 2008
    I wa s ironing with mine this morning nd yes I left it for a minute but cannot get it to go again. It is 13 months old but I woulod expect it to go for long than that. I dont do alot of ironing as there is just 2 of us and my husband would only have a couple of things ironed a week so its not hat it has had alot of use
I have been able to rest the iron by simply moving the iron back and forth. try it.
Posted on Mar 26, 2008
Our Tefal Aquaspeed110 Iron will not turn on when we plug in the power chord. Is there a fuse that needs to be replaced? If so, where may we get one and where in the iron do we find it please? Karl...
Majority of the iron don't have fuse, you should check the plug and cord. Often it is become open meaning no continuity circuit, no heating. To be able to check it unplug, you should use a analog tester. Also check thermostat dial control, when it is not in right adjustment it is also cause a no heating symptom.
Good luck.
Jul 17, 2011 | Tefal Aquaspeed 155 Iron with Auto...
I need to know how to descale my iron
Hi, Brown water and whitescale are often the result of the water you use in the iron... If you have scale, white vinegar will clean that... For brown water, empty the iron, rinse out the insides with bottled water, and then use the bottled water instead...
Also check out this tip...
Cleaninga Steam Iron White Scale and Brown Water
heatman101
Mar 13, 2011 | Tefal Aquaspeed 155 Iron with Auto...
My tefal aqua is not taking out creases but i can see steam coming out of the iron I have tried the instructions according to the manual for cleaning but still no good please help
Some creases cannot be removed with any steam iron.
Dampen the area with the creases or place a wet press cloth over the area and try again.
Feb 20, 2010 | Tefal Aquaspeed 170 Iron
I have the problem of water leakage for my iron
Here is a tip that will help you with that problem...
My Steam Iron is Leaking Water
http://www.fixya.com/support/r5301301-steam_iron_leaking_water
heatman101
Sep 30, 2009 | Tefal AquaSpeed FV5155003 Iron
Tefal iron stopped working
You better open your tefal iron,so you can fix the problem.When open look for the contact bronze in color must them place in the center,use a sandpaper to clean the contacts,when already clean test it if its okey going to hot again if not turn the udjuster to adjust it is a screw liked.
Hope it nay helps you;
Apr 22, 2009 | Tefal Aquaspeed 155 Iron with Auto...
Insufficient steam
Try a commercial De-Scaler.
If your in a hard-water area. the iron will be heavilly scaled-up.
If there is a steam surge button, on the iron. Face it downwards and push the button several times.
Mike @ Compurepair.
Feb 18, 2008 | Tefal Aquaspeed 170 Iron
Tefal Aquaspeed 150
yes unless the thermostats gone.
It,s not really financially practical to replace parts, will cost you parts-and labour.
cheaper to get a new iron, unless still warranted.
Mike @ Compurepair.
Oct 01, 2007 | Tefal Aquaspeed 170 Iron
How to dismantle a Tefal Aquaspeed 150
no, its not the Aquaspeed 170, but Aquaspeed 150. i succeded to unwrap the housing, but did fail in disconnecting or dismounting the power cord terminal.i could not disassemble the Iron to reach the heater. to dismantle, step 1 unscrew 3 visible screws. step 2 lift the heel cover away, by unsnapping 1 hooks at the right and one at the left side of the heel cover. i used thumnbnail to deform the heel cover for not to wear out the snap-in hooks. step 3 remove the dischalk stick (don't know the right wording in english) step 4 lift the top cover (which covers the spray jet part), 2 hooks at both left and right, use thumbnail or flat screwdriver, start at the top hook. step 5 take off the spray and steam buttons, 1 hook at the front side, 1 hook at the outer back side step 6 take off 2 screws: one keeps the upper half of the handle, the other fixes the water container at the heater plate. Attention: when unmounting the container, and turning the iron upside down, a small (4mm diam, ~10 mm length) silicone cylinder part will fall out, some kind of actor of a bimetal thermo switch in the ground plate, which probably controls water flow (not the electric thermostate) so far so good, i got my problem solved, but would like to know how to disassemble the container from the ground plate and how to replace the cable?
Apr 12, 2007 | Tefal Aquaspeed 170 Iron
Irons Logo
567 people viewed this question
Top Irons Experts
Are you an Iron Expert? Answer questions, earn points and help others
