Question about Lexmark X5270 All-In-One InkJet Printer
Printer problem i have a HP officejet T45xi all in one and have not used it in a year trying to use it now replaced both cartridges. I am getting a message to insert a color cartridge but it is in. Can you help?
    Teacher:
    An expert who has written 2 tips or uploaded 1 video tip.
  • 123 Answers
You would first have to to a clean and test run on the printer. If the printer came with cleaning pads clean the cartridge where the ink comes out. put the pad on a table and wipe across the cartridge
Posted on May 02, 2010
Trying to replace ink cartridges on my HP Officejet 6600 with replacement cartridges from LD Products. The printer keeps telling me it is defective. I've tried 3 different ones and none of them will
The printer is checking for a valid printer cartridge and apparently can't communicate with the LD products cartridges. I wouldn't recommend buying 3rd party ink at all actually, most just shortens the life of your printer and clogs things up. You should try eBay and find some HP cartridges for less in my opinion.
Aug 08, 2014 | HP Officejet 6600 e-All-in-One -...
Is there a driver that will alllow a t45xi printer to work in win 8?
no
Officejet t45xi All-in-One Printer to keep your HP product up-to-date. ... HP printers not supported in Windows 8
Apr 27, 2014 | Computers & Internet
Where can i find win8 driver for t45xi
HP do not have a Windows 8 driver for this model
see HP Officejet t45xi All in One Printer Drivers > I don't see my Operating System
but for what it's worth here are some suggestions as to how to make this printer with Win 7 www8 hp com
23.January.2015
Apr 23, 2014 | HP Computers & Internet
I have a HP Officejet Pro L7580 ain. I did not used it for almost 2 years. Now I tried to used it again but sometimes I only get magenta or gray pages, not even black, and a parcial page with a lot of...
Hello
To keep the printer such a time time, dried ink cartridges, if it has ink, then put the cartridges into warm water and put them back after dry. otherwise you need to replace cartridges.
Refill is also an option.
Good Luck
Jan 17, 2011 | HP Officejet Pro L7580 All-In-One InkJet...
I need a installation disk
CLICK HERE
to get access to download the software for the printer by selecting your operating system.
Regards
Riztech
Aug 20, 2010 | HP OfficeJet T45xi All-In-One InkJet...
I receive a "Cannot connect to PC" when I try to scan using my HP OfficeJet T45xi printer/fax/scanner/copier using Windows XP Home Edition with SP3 on my Dell Inspiron 600M. I have downloaded and run the...
That is the correct driver.
Make sure you have a good cable (with bidirectional support). Check that the ECP mode is enabled for the parallel port in the Device Manager. Click Start > Properties (Control Panel). Click on the Hardware and then the Device Manager. Open the Ports section and look for the parallel port option (LPT1). Double click on this and look at the Resources tab. If the printer is connected in ECP mode, you will see two entries for the I/O ranges. This may need to be enabled in the BIOS (often reached by hitting F1 or F2 when restarting the computer before the OS loads). If you adjust the BIOS setting for the port, you will need to return to the Device Manager and adjust the Port Settings to Enable Legacy Plug and Play.
If you use a USB to parallel adapter, make sure you got one that supports bi-directional communication.
I hope this helps.
Aug 02, 2010 | HP OfficeJet T45xi All-In-One InkJet...
Hello, I have an HP Officejet Pro L7580 All In One printer. Sat for 2 years. Barely used when purchased 3 yrs ago. Just hooked it up again. Replaced all ink cartridges...now prints are very pixelated and...
Try doing running it through it's aligment process.
It is also possible that the contacts where the ink cartridges mate up with the printer are corroded. Try using an eraser to clean the corrosion off the mating surface in the printer.
Jan 22, 2010 | HP Officejet Pro L7580 All-In-One InkJet...
How do I conect cables with my gateway pc
This is an older printer and requires a bi-directional parallel cable to connect it.
Refer to this setup guide:
http://h10032.www1.hp.com/ctg/Manual/bpu02659.pdf
See step #7.
If you do not have a cable. A computer store may still carry them. You might even find a computer repair place to give you one.
Good luck and thanks for using Fixya.
Oct 14, 2009 | HP OfficeJet T45xi All-In-One InkJet...
"Cartridge Error: Cart. on left is not intended for this printer"
hi,
HP Officejet 5610 All-In-One InkJet Printer has few common problems. Such as Driver CD lost, Scanner does not work, Connection problem etc. For find all these software solution just click here....
http://www.hp.com/printer/prob676ijt65/solution
djiu9o15
Apr 19, 2009 | HP Officejet 5610 All-In-One InkJet...
New computer with Windows Vista
I have my HP OfficeJet T45xi working with Vista Ultimate. I used a cable coverter to switch to USB. I must install the printer with the USB cord unattached. Install as T40xi whose driver comes with Vista. Set to USB port 1 or 2. Plug USB into USB port 1 or 2 (only ones of six USB ports that worked for me). When Windows discovers the printer do not let it install the printer and tell it to not try again.
Works for me. Hope it helps you!
Feb 03, 2008 | HP OfficeJet T45xi All-In-One InkJet...
Lexmark X5270 All-In-One InkJet Printer Logo
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
