Question about Frigidaire FRS3R5EMB Side by Side Refrigerator
Frigidaire Frs22wnb leaking water from the water dispenser.
My water dispenser has been leaking water, it's a pretty heavy flow. Almost as much as when I am getting water. I had to cap off the line to the dispenser since it won't stop. How can I fix this, and what would be the cause?
catriver
  • 878 Answers
SOURCE: slow water flow
dadcanfix. There are two possibilities here. One could be the water valve itself, clogged or not seating or opening properly. The second would be the water tank on the refrigerator side, partially frozen. I believe they have a kit now with coiled tubing that replaces that tank because of the trouble they had with it. Remove the refer drawers and take a hair dryer and go over the tank lightly. See if that improves the water flow. Catriver..post back.
Posted on Mar 21, 2007
  • 183 Answers
SOURCE: Frigidaire GLRS237ZA Side by Side Refrigerator
Faulty ice maker unit. Regards Advisor
Posted on Aug 23, 2007
22yooper
  • 828 Answers
SOURCE: frigidaire water leaks
I suspect that when the water valve was replaced, that the plug's were reversed that provide the power to the valve. Exchange the two plugs on the water valve and you may find the problem is fixed.
Posted on May 26, 2008
Krazytech
  • 725 Answers
SOURCE: Frigidaire plhs267za side/side water dispenser leaks while ice maker cycles
You have a bad diode on the water valve connection frigidaire has a kit for this fix..
5303918287, 5304418384 DIODE KIT frigidaire
Posted on Sep 07, 2008
vanni7
  • 163 Answers
SOURCE: water dispenser and ice maker not working
Hi!! tony , yes you have a bad water valve its located on the bottom back of your frig..Replace your water valve..Good luck..
Posted on Jan 03, 2009
Water dispenser leaks on fsc23bbdsb3 frigidaire
The valve that shuts the water off is leaky. Replace it or the washer . The lever also may not be set right to stop water flow.
Feb 03, 2013 | Refrigerators
Frigidaire refrigerator water filter area leaking
There has to be a loose or disconnected water line. Check the water dispenser inside the door and behind the door and then go from there.
Jul 23, 2012 | Frigidaire GS26HSZDW Side by Side...
Water is trickling down through where the ice dispenser depressor sticks out of the freezer door. The ice is getting soft. Water is trickling down under the framing for the ice /water dispenser on the...
By not being there seeing the amount or flow rate i'm not sure but from where your saying it's coming out, It sounds like this is either condensation from behind the framing or the flap that closes when your not getting ice is not closing. This could be a broken spring but if the flap is closing. There is a heater blanket behind the framing that heats and dries the condensation out. If it goes out, water will leak out from where your describing. Try going to www.partselect.com and enter your model number. This should bring up diagrams of your unit. See if there is a heater that goes in your model. if there is, I'm pretty sure it will be bad and need replacing.
Dec 21, 2009 | Frigidaire Refrigerators
Leaks from soap dispenser
I don't have a front load, but it sound like a gasket has come loose. Is it for liquid dispensing? Are your clothes comming out clean? If you get inside of the washer and see where the dispenser attaches to the outside drum, my guess is it is either broken and you need to buy a new part or however it is attached has come loose. Not knowing the inside drawing of this washer, my suggestion is to find a mechanical schematic of the machine and go to the root of the problem,the dispenser itself. I am pretty sure it has just loosened up, whether it is a press fit or mechanically attached by screws to it. good luck.
Oct 24, 2009 | Frigidaire ATF6000ES Front Load Washer
Ice maker doesnt make ice
* Check the temperature setting
* Assure that there is enough room for air flow in the freezer or freezer
* Check for air flow restrictions in vents
* Test the temperature control
* Clean the condenser coils
* Check the door seals
* Test the door switch
* Test defrost heater
* Test defrost timer
* Test evaporator fan
* Check for a clogged drain tube
* Check for refrigerant leak
Aug 08, 2009 | Frigidaire Gallery Series GLHS269ZDB 36"...
Frigidaire side by side refrigerator and water and ice don't work
check the screen in the water inlet valve its probably plugged. That or your double soliniod valve is not working
Apr 09, 2009 | Frigidaire FRS26ZSG
Water dispenser and ice maker not working
Jan 03, 2009 | Frigidaire Gallery Series GLHS269ZDB 36"...
Frigidaire water leaks
May 25, 2008 | Frigidaire FRS26H5AS Side by Side...
Mar 03, 2008 | Frigidaire PLHS267ZA Side by Side...
Water leaking from left side ice/water dispenser
If you describe a constant flow of water from the ice maker then the solenoid valve is either leaking by when it's upposed to be off or the motor module is stuck in the "fill" position. If it was stuck in fill you would be getting a LOT of water all the time so if you only have a trickle then the solenoid valve may be letting water leak by it. The diagram here shows the parts for a better idea of what you may need to look at (and where it's at). http://www.partselect.com/Schematics/Frigidaire/SZGBPCQH.gif
Jan 08, 2007 | Frigidaire FRS26R4C Side by Side...
Frigidaire FRS3R5EMB Side by Side Refrigerator Logo
136 people viewed this question
Top Frigidaire Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
