Question about Toshiba Televison & Video
We just purchased a toshiba DVD video recorder DR430KU and can not get it to work with our Samsung bit screen tv .. we have satilite tv
    Problem Solver:
  • 7 Answers
I had a similar problem. After disconnecting my devices and rehooking them again. Was that you may need to reset the DVR to channel 3 or 4. Or go to settings and see if you see a a menu that reads "Reset to Factory Setings." Try clicking that and see if you can record from you DVR after you do it. It may be that your DVR was on the wrong channel of the DVR. I found this true with mine, it was set to channel 3. How it jumped to that channel is a mystery. Make suire your connections are correct in the back of the T.V. Red to Red, yellow to yellow, or white to white and "In to out." On the back of my HDTV it was so different. The cables from my DVR were R, Y, W. But on the back of my T.V. it was Green to Yellow, Red to Red Stereo, and White to White Mono. My instructions did not match what I had on my T.V. that is why it is very confusing. And 2. the instructions are too small for me to read. I called Customer Support for Toshiba T.V.'s. They told me to call Customer Support for Toshiba DVR. Which I did and they were also not able to help me. Then they told me to call Toshiba Customer Service for Toshiba DVR. I went back and forth. I did mention that before or the old way used to be that when you had an old VCR, you always had to put or switch the channel to Channel to 3 or 4. But they did not know what I was talking about.
I finally reset the DVR to factory settings myself. I am almost 100 per cent sure that it will work now. Good luck, and I sure hope this helps.
Posted on Feb 07, 2013
SOURCE: Samsung DVD Recorder R155
Sounds like you recorded from a camcorder attached to AV2 (front of DVD player). Press the STOP button, then open the menu and finalize the disk.
Posted on Oct 26, 2008
dvdcdlaser
  • 1285 Answers
SOURCE: DVD VHS Recorder setup.
hi there, a little late.....but here we go........do you have cable? if yes connect the cable from the cable box out to dvd in and connect the dvd out to tv in.......pls note the dvd and tv must be set/tune to ch #3.(and you cannot record HBO)......you dont have cable just tv and dvd you need rca wire (red,white & yellow) also the F connector wire....in back of dvd connect the 3 wires audio in video in (is your tv/monitor a flat panal these connections might be on the side) if not its in the back plug in to out on tv....(this is so you can record)....plug the F conncetor wire from dvd to tv......on this connection you can set the dvd to ch #3 or any ch you want to record...........
Posted on Jun 25, 2009
dvdcdlaser
  • 1285 Answers
SOURCE: how to finalize a recorded dvd disc?
on the remote is there quick navi button (this will take u to the finalizing screen)
Posted on Jun 26, 2010
  • 11800 Answers
SOURCE: Unlock Toshiba DVD Video Recorder
In this recorder the region is hard coded in the firmware and cannot be changed thru customer commands. Unfortunately there is no region free firmware so if you would be able to obtain one all you would manage is to change the present region to another one.
Posted on Dec 08, 2010
  • 1456 Answers
SOURCE: My Toshiba DR430KU dvd recorder
Hello
Secure the audio/video connection cables that attach the source device you are trying to record from. Try this step if you do not see a picture when trying to record from a source device onto the Device. After unplugging the cable and checking for any damage, plug the cables back and attempt to record the content to see if this resolved the problem.
Secure the power cable that attaches the device to an electrical source if the unit will not power on or if it intermittently loses power. If you think a malfunctioning surge protector may be at fault, you can 'bypass' the surge protector by plugging the device into an electrical outlet. Replace any surge protectors that appear to be malfunctioning and have an electrician examine any outlets that appear to be "dead."
Insert the disc that you would like to record
Press the "Edit Menu" button on the remote control while playing the disc or while playback is stopped.
Use the up and down arrows to select "DVD-Video Finalizing" in the on-screen menu, then press "Enter."
Under "Menu Create" select "None," then under "After play final title" select "Stop." Select "Next" to move to the next screen.
Select "Writing" in the lower right of the screen.
Select "Yes" or "No" to tell the machine if you want it to power down when finalizing is complete. Finalizing will then begin and a progress bar will appear.
Contact your electronics dealer or the Toshiba service department if the disc still does not finalize.
Posted on Apr 19, 2011
My dvd recorder toshiba dr430ku plays regular movies no problem it wont burn dic now
Contact the authorized service center for Toshiba. Its laser pick up/burn unit is faulty. Replacing it is a very skilled work. If you wish to get some details; visit the site linked here. Pull up older posts. http://electronicshelponline.blogspot.com/
Jan 09, 2017 | Toshiba Televison & Video
Error Message: Cannot record in VR-mode?
To be able to help you, tell me these things: What type of disc are you using (-R,+R,-RW or +RW), was the disc previously used in another recorder or computer, are you attempting to record in VIDEO or VR mode and have you done any formatting to the disc?
Jul 17, 2014 | Toshiba Dr430ku Dvd Recorder - Black
My toshiba dr430ku recorder does not record
Check the user manual that you are using compatible discs.
Jan 30, 2013 | Toshiba Dr430ku Dvd Recorder - Black
Trying to record with my DR430KU Video Recorder from my Sharp T.V.Set
The input to the recorder needs to be set correctly. Describe in detail your connections between the TV and recorder and I can tell you what you are doing wrong.
Nov 19, 2012 | Toshiba Dr430 Dvd Player/recorder
I'm trying to hookup my Toshiba DR430KU to an older tv that require an RF Modulator. I get a skewded sideways picture. Does This DVDR compatable with a RF Modulator?
Probably not. Better picture results are achieved with either S-Video, standard RCA AV cable (yellow-white-red), or YUV component cable (red-green-blue) (component output does not have audio - this requires extra cable to be connected). The video via either one of these 'AV' connections is stunning (based on a standard 16:9 LCD TV using a Panasonic DVD recorder).
RF tends to be lower quality - as opposed to AV/digital input. AV input/YUV component handles digital better. No one connects their DVD devices to their TV via RF (either directly to the antenna socket or with a modulator/attenuator) anyway. Because a VCR is mostly analogue, it will work fine with an RF connection, but DVD is digital, and so won't work as well, if at all.
RF also goes through the tuner in a TV, creating cross-interference, whereas AV is a direct input and is separate to the tuner.
I would say an RF modulator would not be designed to handle the output frequency that your DVD device generates. Throw the modulator out, or perhaps get another TV, or use RCA cables instead if the TV has AV inputs. Whichever is cheaper and easier, but don't use RF accessories except a standard antenna if/as required.
Apr 27, 2011 | Toshiba DR-430 DVD Recorder
How to finalize a recorded dvd disc?
May 29, 2010 | Toshiba DR410 DVD Recorder
Televison & Video Logo
402 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Henry  Thomas
Henry Thomas
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
