Question about Sony Playstation 3 (PS3) Console
Error code(80130804) keeps appearing on my ps3
I can connect to the internet directly but not wireless .when i do i get that error code
Take out the ethernet the router and everything else w8t a minute or 2 mins den disable the media server connection it should work it workd 4 me
Posted on May 03, 2010
I bought ps3 in cash converties second hand im tryiny to connect to wireless interent but error code is keep coming up
The internet signal is probably to weak. Connect your PS3 to the internet by using a Ethernet cable
Mar 03, 2011 | Sony Playstation 3 (PS3) Console
I have connected my PS3 to the internet wirelessly before but I have recently moved into a new home. I consistently get the 8013013d Error code when trying to connect to the internet... But my room mate...
Hello :D
8013013D "A connection error has occurred" - May be to do with the SSID of the Router or signal strength if the conneciton drops Putting the PS3 into DMZ may help - otherwise check WPA key PS3 can't handle WPA2 only WPA or none
May 21, 2010 | Sony Playstation 3 (PS3) Console
Error when connecting to the internet: error (80130804).
This means that your PS3 is not able to get an IP address from your wireless network/router. I would suggest set the IP address manually on your PS3 including the DNS IP address.
May 11, 2010 | Sony Playstation 3 (PS3) Console
Geting error code 80130804 on ps3 & can't connet to internet
when this happens u usally have to make anther user account and it will work perfectly
Apr 18, 2010 | Sony Playstation 3 (PS3) Console
Getting error code 8001000B when trying to connect wireless to internet any ideas please ???
Try these ...
1. If wireless try a cabled connection.
2. If connection is via a router plug the cable directly into the modem.
Could be a network / router issue
3. Check your connection option on the ps3 dash
4. Post more info and i try & help
Mar 10, 2010 | Sony Playstation 3 (PS3) Console
Cant connect my ps3 psp go to the internet using
Check to see if your router has backwards compatibility to wireless G because the N router uses 256bit encryption coding while the G uses 128 bit encoding. PS3,and PSP use the 128 encryption coding also. If the router does not support 128 bit encoding you will never connect with it.
Nov 22, 2009 | Sony Playstation 3 (PS3) Console
How to wire a ps3
Hey allisc,
In order to connect your PS3 to the internet, you will need one of two things: a hard-wired connection, or a wireless residential gateway. Please keep in mind that your options may be limited by the PS3 model that you own, and that a wireless connection is not possible with some models.
The most straight-forward type of connection you can make is a hard-wired connection - simply use an Ethernet cable to connect your PS3 directly to your residential gateway. By establishing a direct connection, the PS3 should not need any additional information in order to access the internet. The trade-off for the simplicity of a hard-wired connection is that the number of places you can physically place the PS3 itself are limited by the length of Ethernet cable used.
Should you wish to use a wireless connection instead, you will need to own a 40GB, 60GB or 80GB PS3 and a wireless residential gateway. The 20GB model unfortunately does not support wireless capabilities at this time. Please keep in mind that connecting wirelessly can often prove to be more complex than using a direct connection, as you not only need the name of your router, but information on any established security settings as well.
The most common security settings that may be in place are Wi-Fi Protected Access (WPA) keys and Media Access Control (MAC) filters. MAC filters are essentially a series of "blacklists" and "whitelists" that restrict network access based on hardware configuration. WPA keys however, are "passwords" that allow your computer or video game console to decipher a code used by residential gateways which prevent unauthorized users from using your personal internet connection.
Both forms of security may typically be set and changed by accessing the gateway directly through its default website. This default website can vary depending on the brand of the device, but many companies may use one of the two default addresses I've provided below:
192.168.0.1
or
192.168.1.1
Please keep in mind that in order to access the gateway's control panel you will need to have both the admin user name and password!
Once you have gotten access to your residential gateway's control panel, you should then be able to add the MAC address of your PS3 to the gateway’s MAC filters, as well as copy down any WPA key used by the network so that you may later enter it into your PS3's memory.
If you are still not sure how to proceed or do not feel comfortable doing any of this, I would strongly suggest contacting either your internet service provider (ISP) or a Geek Squad® agent at your local Best Buy™ store for further assistance.
Hope this helps you out.
Sincerely,
Aaron
Go Ahead. Use Us.
Jun 10, 2008 | Sony Playstation 3 (PS3) Console
80029c41 error code
When do you get it?? If it helps when your trying to connect to the internet i suggest you disconnect the PS3 from the wireless connection and try it again if not get a better and faster and more ranged wireless Connection.
Rate my Solution Please
I tried my best.
Apr 30, 2008 | Sony Playstation 3 (PS3) Console
PS3 -Connect to Internet using PC with wireless Broadband Card???
Yes you can but you need a router or ou need to connect the ps3 directly to your lan card the just set up a shared internet connection through windows
Mar 22, 2008 | Sony Playstation 3 (PS3) Console
HELP PLEASE
You need to sign up to the ps3 wireless play just like xbox live but without paying. go to the sony website to find all the info.
Sep 13, 2007 | Sony Playstation 3 (PS3) Console
Sony Playstation 3 (PS3) Console Logo
425 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
marley mcelhinney
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
