Question about Boss CHAOS CH450 Car Audio Amplifier
Red light it wount make any nosie and the red led light is on
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 155 Answers
Get a better amp bro
Posted on May 06, 2010
My sansung tv ....dose not turn on it makes a beeping nosie and turns off the led light turns red .....any chance any one ones wuts wrong
Most common proble is Bad Capaciotrs on Power supply Board they will be vented or swollen on Top 1000uf 16v 2200uf 10v 3300uf 10v
Samsung Parts 1-800-627-4368
PTS 1-800-844-7871 this company rebuilts boards
May 31, 2011 | Samsung LT-P227W 22 in. HD-Ready LCD...
Fan motor is macking nosie and the lamp light on front panal is flashing
Buy a new fan and replace it.Tries websites like Partstore.com,Ebay.com to buy a new fan for the replacement.Tv should be working again,if tv still have LED "LAMP" light indication still flashing.The tv projection lamp life are over.Replace the tv projection lamp too.
Apr 03, 2011 | Mitsubishi WD-65731 65" HDTV
Red light comes on but the unit wount turn on
The red light is associated with the memory (constant 12 volt power). You also need switched 12 volt power (power with key turned to accessory)for the unit to turn on. If you installed the system yourself, you are looking for 12 volts on the red wire of the Jensen unit. If power exists at the unit, check the fuse of the unit and the fuse of the vehcile.
Feb 03, 2011 | Jensen Vm9214 Car Video Player
My tv wount stay on it goes off after a few seconds
The tv "LAMP" LED light indication flashes or lighting up?The projection lamp has not been change in this tv like a 1 1/2 or 2 years?The projection lamp life is over.replaced the projection lamp.
Sep 17, 2010 | Proscan PS60690 60" Rear Projection...
One flashing red light on xbox360 ( not red ring)
The specific type of hardware failure can be determined by a "hidden" error code
Turn the xbox 360 on, and wait till the 3 red lights are flashing.
Press and hold the sync up button (the small white one), while holding that button press the eject button.
The LEDs will now blink the first number in the code (as described below).
Release the eject button and press it again.
The LEDs will now blink the second number of the code.
The LEDs will now blink the third number of the code.
The LEDs will now blink the forth number of the code.
The LEDs will go back to the 3 red flashing lights.
You should be able to determine the difference between the 3 flashing lights and the error code lights by the rate in which they flash.
Here is how you interpret the LEDs to get the code number:
All four lights flashing - 0
One light flashing - 1
Two Lights flashing - 2
Three lights flashing - 3
Once you get this code, go to: http://forums.xbox-scene.com/index.php?showtopic=484726
To get the reason for the code.
Sep 15, 2009 | Microsoft Xbox 360 Console
Problems with my sony xm-2100 gtx amp
check your wires and your ground wire it might be touching something causing it to spark and your amp to go on protect mode also check your fuses..also sometimes this works put your db and all your settings on your amp low as it can go sometimes its just to much power n hits like an impact.
Jun 09, 2009 | Sony XM-2100GTX Car Audio Amplifier
42 Vizio LCD Tv-
Replace the power supply will fix the problem. Is the Vizio LED light on?
Jan 19, 2009 | Vizio GV42L 42 in. LCD Television
Computer won't turn on. keeps making long beeping nosie. Red and green light on top
If you can open the Cabinet and unplug the RAM (memory Card) and then insert it after 10 min. Restart PC Again, it will work.
Let me know the status. Have a Nice Day!
Scott
Nov 06, 2008 | Acer Computers & Internet
Sound no picture?
I have no solution for this problem and I'm not sure I can fix it without taking it to a repair shop. The replies I got yesterday did not help.
Jul 30, 2008 | Toshiba 62HMX84 62" Rear Projection HDTV
Boss CHAOS CH450 Car Audio Amplifier Logo
53 people viewed this question
Top Boss Car Audio & Video Experts
xxxxxx xxx
hoyzee1
Are you a Boss Car Audio and Video Expert? Answer questions, earn points and help others
