Question about Dishwashers
Zanussi dishwasher My dishwasher takes up to four hours on a cycle which is supposed to take Eighty minutes..what is wrong ?
Chances are you either have a broken heater element or programmer as the washer is not moving itself on correctly
Posted on Nov 15, 2008
Zanussi diswasher ZDI6053N does not finish its cycle.It has to be turned off manually
Your dishwasher is a sophisticated device that registered most failures. The End of cycle LED flashes if there are alarms memorized. So, count how many times the End of cycle LED flashes.
For example:
One flash - i10, the problem with water intake
Two flashes - i20, a problem wit drain water
Three flashes - i30, activated anti-flooding device
..... and so on
Dado
Sep 01, 2014 | Zanussi Dishwashers
Zanussi dishwasher ZSF6161 starts program then stops after 15 minutes
check this steps and fix it. God bless youFloat Switch
The float switch may be hung up and this can cause the dishwasher to be stuck in a cycle.
Timer / Control
If your dishwasher gets stuck in a cycle first try shutting off the breaker for at least 5 minutes if this does not correct the problem you will need to replace the timer /electronic control.
Apr 02, 2013 | Zanussi Dishwashers
Fridgidaire/Electrolux dishwasher stuck knob
It definately sounds as though the motor in the timer assembly is dying, or the gears in the assembly are wearing down to the point that the gears can't turn the way they're supposed to. Replace the timer.
Apr 17, 2012 | Frigidaire Dishwashers
Whirlpool Dishwasher GU3600XTSB 3 - 4 hours to complete washing
Wash time is determined by the cycle you select, the incoming water temperature and the installation location. The new machines will heat the water to a predetermined temperature and it takes roughly 1 minute for each degree of rise, If the incoming water is at 120 deg and the wash cycle wants 165 than it will take 45 minutes just for that one cycle to complete, Factor in an outside wall with poor insulation or lower water temperature and it could take even longer. Eric
Dec 30, 2009 | Whirlpool GU3600XTS Dishwasher
My dishwasher works but is taking a long time to finish the cycle it is a zanussi DA 6373
Your dishwasher may pre-heat the water. If so, and if the water entering the dishwasher is cool, the heater may take up to half an hour to heat the water.
To avoid the wait, increase the incoming water temperature before turning on the dishwasher. Do that by running the kitchen sink faucet until the water runs hot. Or increase the temperature of the hot water to the entire house at the hot water heater.
Nov 12, 2008 | Zanussi Dishwashers
Zanussi ZDT6252 stops 1min into cycle
You need to reset the computer on the bottom. Had the same problem with mine. The Blinking led means the heating element is bad and will not operate.
Dec 30, 2007 | Zanussi 23 in. ZDT6252 Built-in Dishwasher
Zanussi Aquapulse DE6544 not emptying
Zanussi Aquapulse dishwasher - is filled with water inside, is not washing and the lights keep flashing on and off - has anyone any idea what may be wrong with it?
May 27, 2007 | Zanussi 24 in. DE6544 Built-in Dishwasher
Too long for a cycle
There are a lot of reasons could cause this issue. Could you provide us more details (if you have) which cycle's stage "takes" this time (filling water, washing process,draining etc... ) You answer will allow us to direct you the solution. Good luck !
Jun 27, 2006 | Zanussi 24 in. DE6744S Free-standing...
Dishwashers Logo
215 people viewed this question
Top Dishwashers Experts
