Question about Emerson NR303TT CD Shelf System
Needle skips and runs over record to the end and will not return
I gave my brother one of these units I have one and it works fine, when he plays a 33 record the stylus skips and he said the record just runs across and will not return back.
  • TimmeJT Dec 25, 2008
    I bought this for my son for Christmas and thought I got a good deal. He wanted to play old vinyl LPs but the needle just slides across the record. We tried new records and old. Skips a little less on old LPs but still skips and doesn't return. Guess it's back to the store unless someone has an idea...
2 Suggested Answers
SOURCE:
Duncan
  • 219 Answers
SOURCE: Problem playing 45 Records to their entirety.
There is an adjustment on the tone arm that you use to set where the tone arm picks up at the end of the record. This adjustment is normaly at the back (pivot point) of the tone arm and will be on the side probably. By the way, the tone arm is the part that the stylus is mounted to that swings back and forth to reach all the surface of the record. Make your adjustment and then test and continue doing this until you get it just where you want it. It is a process of trial and error. Good luck.
Posted on May 21, 2007
Record player repair
The top arm that swings over the spindle will control the automatic return. Leave the unit off. Swing the overhead holding top arm over and manually load a record. Now switch the top arm over the niddle spindle. Make sure that the switch is set for 7", 10" or 12" (45, 78, or 33). Manually place the tonearm at the start of the record and flip switch to 'play' (not reject or auto). It should play the whole record and automatically eject at the end and then shut off. Leave the arm swung over the middle after you loaded the record. Good luck. Let me know if you have any more questions.
Aug 18, 2014 | Audio Players & Recorders
Marantz tt 530 turntable
The needle skipping is caused by (A) a worn stylus. (B) not enough pressure. Which is solved by adjusting the weight on the end of the arm. It can only really be solved by trial and error. You increase the weight slightly, then play the record. You keep doing this till the record stays in the grooves but doesn't make a rumble sound. If it starts to rumble reduce the weight.
Aug 20, 2013 | Audio Players & Recorders
Needle skipping towards end of record
If you lower the tonearm to the record surface, and it just slides towards the center, chances are the stylus(needle) is either broken or covered with dust. Clean and inspect. For more information, please visit my website at audioserviceclinic.com. Thank you.
Nov 28, 2012 | Stanton STR8-100 Turntable
Tone arm gets caught up and skips repeatedly
Is there a counterweight on your arm or is the an adjustible spring setting? You need to move the counterweight toward the needle. You dont need much but the needle end needs to be heavier than the back side. If your anti skating is a magnet ... reduce the force on that as well.
Let me know what happens.
a
Sep 25, 2009 | Audio Players & Recorders
Technics sl 1200 MK2 WEAK SOUND
Regarding the poor sound quality (and possibly the skipping):
check the needle condition, see if exchanging it with a needle (or the entire pickup head) from a working turntable does any good.
Check the pickup connection pins (contacts on the pickup head and on the end of the wires coming through the arm from the unit), see if there is any dirt or oxydation and clean the contacts if necessary, also check for any damage to the wires.
As for the skipping - a heavily worn needle may affect the sound quality and cause skipping as well - if cahnging the needle (or the pickup head) doesn't make a change, try to realign the weight on the tone arm so that the pickup head will become a bit heavier, this could help somewhat (before you actually try to realign the weight, try to put a small coin or a small weight of some kind on the pickup head while it is playing a record, if the skipping goes away, you need to realign the tone arm weight).
This could also be a problem with the tone arm lifting mechanism (may be obstructed by something or damaged so it won't let the tone arm sit properly onto the record and "grab" the groove).
I just mentioned a few things you might want to check, but don't take anything for granted, the problem may as well be elsewhere in the unit.
regards
Triarcuate
Sep 22, 2009 | Technics SL-1200 Turntable
Sl-dd33 turntable
If your needle just started to skip across the LP, then that means your stylus is damaged/worn and needs to be replaced. It's very hard to see the diamond tip on the stylus, and it might not even be there at all. So checking it might not yield any results. This is what happens when the needle is worn. It will skip across the record.
- OPTiC
Turntable Technician
www.1200s.com
Aug 27, 2008 | Audio Players & Recorders
The record player skips
Hi There,
From your description it sounds like there is insufficient weight on the needle end of the pick up arm.
The pickup arm is very delicate in its balance at the "rear arm end" fulcrum.
This weight is adjustable to allow the needle to press on the music track to an exact pressure and it is adjustable so that this pressure does not damage the music track.
There should be a wheel type thingy at the rear end of the pickup arm.
This wheel is usually marked in Grams, and to make the needle end heavier to stop "skipping' you turn the wheel to wards the + sign.
This + sign means more weight on the needle.
There also should be a - sign, and the wheel, when turned in that direction, the weight on the needle is reduced.
You need to be aware that a needle really needs to exist in the cartridge as they can be broken off very easily and if there is no needle present there, then there is no way you will get any music from the turntable.
So check there really is a needle there...use a magnifying glass to see....
If thats OK then place the needle end of the pickup arm on to the record surface and turn the weight wheel until the needle just lifts from the record surtface.
Now that this stage has been received turn the weight wheel in the reverse direction by around 5-7 grams in the heavy + direction.
The needle should now be resting on the records surface and not lifting at all.
It should play like this,,,BUT please ensure the record player is on a perfectly flat surface the
needle wont work on any incline at all...
If you turn the amp on in the phono switch position and carefully hold the needle over the record and touch the needle with your finger you should get a scratchy sound from the speakers.....
This is a basic test to ensure the amplifier and all the wiring is in place and doing its job..
Im Sorry you had a run around from the repair company but some of them are not interested in repair work any more they just want to sell new hardware...
It pays to ask if they are Pepared to repair stuff for you , then get a commitment of a reasonable repair date and time in writing.
If this date and time is exceeded then you dont have to pay for the repairs do you??
As they have missed the service level agreement you had with them for the reapir date and time..
Hope this helps
From
YUBEUT..
Aug 13, 2008 | Teac GF-350 CD Shelf System
Fisher price 1978 record player
The Fisher Price record player has a device that prevented kids from pressing the needle down and sctratching the record. If you look at the cartridge where the needle is inserted, you will see that it floats up and down. The problem is that this keeps the needle from having enough pressure to play the record. Pennies just make the cartridge recede further into the arm. If you wedge something above the cartridge, the needle won't float and the it will play your records. I've had four of these and none of them worked until I figured this out.
Aug 02, 2008 | Audio Players & Recorders
Technics SL-1350 Direct Drive Turntable
Hi
Check that the cuing lift isn't touching the arm as it gets to the end of the record.
John w
Dec 16, 2007 | Audio Players & Recorders
Emerson NR303TT CD Shelf System Logo
294 people viewed this question
Top Emerson Audio Players & Recorders Experts
Mike Duncan
Mike Duncan
Are you an Emerson Audio Player and Recorder Expert? Answer questions, earn points and help others
